Mystery Crankset
Old bikes, Older guy
Location: Fiscal Conservative on the Lefty Coast - Oregon
Bikes: A few modern, Several vintage, All ridden when weather allows.
Quoted: 255 Post(s)
Liked 178 Times
Mystery Crankset
Hi folks,
Does anyone recognize this crankset? It's on a Schwinn Le Tour, number on head badge is 60639. Small label on inside of pedal end of arm, RR3CCB175.
The crank arm bolts are strange. The inner is a 8mm Allen socket & the outer is a 10mm Allen socket with a "gear" like image on it.
Thanks and regards,
Van
Thanks and regards,
Van
Remember: Real bikes have pedals.
...and never put a yellow tail on a Red, White and Blue kite!
Quoted: 4569 Post(s)
Liked 6,554 Times
Looks FSA/Sugino to me.
Mr. Anachronism
Quoted: 526 Post(s)
Liked 257 Times
That is a strange one, that I've never seen on a Letour.
Not that it will help your ID, but I believe the head badge number you've provided has one too many digits.
Quoted: 3467 Post(s)
Liked 2,843 Times
Likes For repechage:
Quoted: 255 Post(s)
Liked 178 Times
Hello again,
A bit more info. Yep, the HB number is correct. This is a real Franken bike. It has an Altus front derailleur, DeerHead RD & Suntour Accushift bar ends. The crankset has a 130 BCD. Possibly only the FD is original.
Now, how do I get the damn thing off?
Cheers,
Van
Cheers,
Van
Quoted: 1119 Post(s)
Liked 1,352 Times
I don't know but I bet the cap comes off with the big hex and the bolt comes off with the small one.
Easy enough to find out; however if the cap is really an outer bearing for a flanged bolt so it self-extracts, it (should be) left-hand thread; so do the same as you would do for an unknown fixed cup - go each way, trying a little harder each time. If it's left, snug it back down and use the inner one.
Quoted: 179 Post(s)
Liked 337 Times
60639 is the zip code in Chicago where Schwinn was located. Is the crank length 175 mm? Looks newish...
72+76 Super Course, 74 P-10+ 79 Tandem Paramounts, 84 Raleigh Alyeska, 84 Voyageur SP, 85 Miyata Sport 10 mixte and a queue
is just a real cool dude
Quoted: 32 Post(s)
Liked 34 Times
Pretty sure that's a Truvativ/Sram crankest of some sort. I had a polished triple on an old Cannondale and I thought was a purdy looking crank for a mid level crankset. They came in both cartridge style bb and external bearing bb.
Likes For Henry III:
Ride, Wrench, Swap, Race
Quoted: 1573 Post(s)
Liked 1,314 Times
Self-extracting bolts, so leave the larger 10mm alone(!) and just unscrew the inner 8mm bolt to pull the arms off.
These usually come off without much effort since the taper fit bottoms on a ledge instead of wedging ever tighter.
Quoted: 1628 Post(s)
Liked 635 Times
Nuke it from orbit, it's the only way to be sure.
Likes For Lascauxcaveman:
Quoted: 255 Post(s)
Liked 178 Times
Hi folks,
Mystery solved! The crankset is a Truvative or at least the BB is. Once I figured out how the self extracting bolts, the arms came off easily, but had to take it to the co-op to get the BB out. Thanks again for your feedback.
Cheers,
Van
Cheers,
Van
Likes For Senior Ryder 00:
