What Sort of Gearing Works Best for your Needs?
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
Thought this might make for some interesting conversation.. lets say you can spec your bike with any sort of ratios you want. What are you picking?
1. What sort of terrain do you ride on?
2. What sort of bike is it?
3. How hilly is the area you ride in
4. Whats your current ratio spread and how does it suit your needs?
5. How would you change it?
- Mostly pavement, some gravel and dirt paths
- Road bike
- Mostly flat, some long hills, nothing crazy steep
- 40/52t front, 14-34t rear (2x5)
- 36/52t, 11-34t (2x8)
While my current gearing is totally sufficient for my needs and actually quite useful, I find myself being in top gear (52/14) all the time on flat terrain in non windy conditions. I'd like for slightly lower and slightly higher gearing on both ends of the spectrum. Something like 2x7 or 2x8 would offer some ideal spacing in terms of snatching through the gears while accelerating from a stand still.
Interestingly enough, I found a Biopace Mountain LX crankset made by shimano (28/38/48) . Never seen that sort of spacing before. Typically lower end mountain bikes come with 22/32/44. Woukd be interesting to give this unique ratio spread a try.
- Road bike
- Road bike
- Road bike
Quoted: 4227 Post(s)
Liked 2,489 Times
I use fixed gear and singlespeed bikes for all of my riding....My cycling season never ends and I ride all year round. The area I ride has rolling terrain mostly gentle hills but we also have some big hills out in rural areas which can be a big challenge especially for somebody who rides singlespeed.. The type of riding I do includes: commuting to work, road riding, gravel riding, mountain biking, snow biking.
Likes For TomM:
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Road 50/34 with 11-28
Gravel 40T with 11-32
Passista
Quoted: 883 Post(s)
Liked 739 Times
Road,
52/42 and 13-21 7sp - that's more than I need, a 50 big ring would be enough. Pavement, flat terrain.
52/42 and 12/23 9sp
MTB (but used as gravel) 26/36/48 and 12-19 7sp. Dirt roads, flat terrain. A 46 would be better.
52/42 and 12/23 9sp
50/34 and 11-32. I think my older bike is 11-30.
It's not hilly here at all so most of my favorite combinations are geared for speed, not for climbing.
Likes For Reflector Guy:
Quoted: 2512 Post(s)
Liked 752 Times
+1. My latest (cargo) bike adds a 22T to the front of that!! Nothing it can't climb, and it keeps up with the Hipsters (I'm 61) on the level. My road bike has 50/39 x 11-28 but I rarely take it to the big ring. I'm about to preach the gospel of the granny gear and warn those who will hear, about the evils of overgeared production roadbikes. They are a great evil loosed upon the land. Resist them with all thine resistance. When you are old enough to find the "Over Fifty" forum interesting you will see the sad, sad, testimonies of those who were rocking the 88" fixed gears in their mis-spent youth but now have no knee cartilage. A word to the wise is sufficient.
Likes For Leisesturm:
Sunshine
Quoted: 11048 Post(s)
Liked 7,596 Times
Quoted: 7677 Post(s)
Liked 3,564 Times
If 52x14 is too low for you, you wouldn't like it for road use but it is great for off-road---gravel and dirt, mild single-track.
Drip, Drip.
Liked 193 Times
I have one of those on my shelf ... had issues with one crank arm, and swapped it out until another came in the mail, never ut it back. Did a ton of miles on it as a commuter---excellent around-town/carrying a load gearing with a normal cassette.
Does something with more teeth than 34 in the rear cassette make sense for road and gravel use?
What about for singletrack? Would you prefer a 1x? 2x? Or the good old 3x like on the biopace? And what sort of rear cassette?
I'm mainly.tempted to try the 3x biopace crankset because the arms are 175mm versus 170.
What do you think of 11 vs 12 or 14 for the top gear? I've read that 11 isn't too useful for anyone but the racer group or something like that.
Quoted: 913 Post(s)
Liked 2,096 Times
- Road bike
- Road bike
2. All road.
3. From flat pave to steep gravel.
4. 46/30 11-30 11 spd. Perfect
5. Nothing.
Quoted: 832 Post(s)
Liked 1,972 Times
Road 50/34, 11-34 11 speed
46/30, 12-27 10 speed
Hilly Terrain, most rides average 100+ ft climb per mile.
Older/heavier rider 210 lbs, so needed some help on climbs with gearing. Advantage is I can ride longer in the mountains/hills with this gearing.
Quoted: 1062 Post(s)
Liked 665 Times
Road: 1x9
Road: 1x1
Road (shopping and hauling): 1x3
Road (winter shopping and hauling): 1x3
I live in a region of endless rolling hills. And I'm a fairly slow cyclists. All of my bikes have swept bars. As I tell people, the hills in our area can be steep, or they can be long, but they can't be both. So there's always relief ahead if it gets really steep
The 1x9 is what I take out for longer rides (30+ miles) if I'm being sensible. But I also like challenging myself on the 1x1 along similar routes. The other bikes are self explanatory.
Road: 1x1
Likes For Gresp15C:
Quoted: 4560 Post(s)
Liked 2,804 Times
All of them. Give me all of the gears. I will find a place to use them.
That Biopace will probably feel like smaller rings. That's the interesting effect I feel with my old school 52/42 Biopace on one road bike. The 52 subjectively feels more like my 50T round ring, and the more ovalized/eccentric shaped 42T feels more like the round 38 or 39 small chainring on my other road bike.
It's fairly subtle, but climbing in my bike with 42T Biopace small ring and 28T biggest rear cog feel about like the 38 or 39 round chainring (not sure which is on it at the moment, I swapped 'em recently) and 28T rear cog.
Not everyone cares for Biopace or other eccentric chainrings but I like 'em, although it's tricky to set up to prevent knee twinges. I prefer Biopace with shorter cranks, around 170mm. With longer cranks I felt some knee twinges that I don't get with 172.5 or 175 cranks on round chainrings.
It also depends on the orientation of the eccentric chainrings. Some folks found Biopace works better for them with the rings re-oriented, rather than the factory default. With older 5-bolt spiders choices are limited. More recent oval/eccentric chainrings offer more variety in mounting to suit the rider.
Quoted: 7087 Post(s)
Liked 11,206 Times
I'm guessing that you are rather new to cycling and are still pedaling at a painfully low cadence. You don't need higher gears; you need to learn how to spin. Your knees will thank me when you are...my age.
Likes For Koyote:
Quoted: 645 Post(s)
Liked 797 Times
- Road bike
- Road bike
Klaatu..Verata..Necktie?
Quoted: 10529 Post(s)
Liked 12,106 Times
- Exclusively road
- All 4 bikes are road bikes - 2 steel, 2 CF
- All rides contain several hills 5-6%, 1/2 mile in length, with occasional climbs 7-8% average for 3-4 miles. And the accompanying descents, of course
- Two steels are 53/39 x 12-30, one carbon 50/34 x 12-28, all 10sp; other CF 52/36 x 11-34
- Nothing. I already changed the first 3 to what I wanted and the 4th is great as it is.
2. Hybrid with front suspension (dual sport type).
3. Mostly flat, longer climbs are rare, but there are some short and steep ones.
4. 44/32/22 front, 11-32 9s rear. I could do without the lowest gears; the high end is about right.
5. A subcompact double (46/30) on the front would probably make sense, but I don't care enough to replace my current XT crankset, which, while an older model, is still really nice. The couple hundred of grams of possible weight saving means nothing to me. I might get an 11-28 cassette though.
Nothing unique about that gear spacing, that's a typical hybrid/trekking triple crankset. Other common verison is 48/36/26. Shimano still produce them at all price levels from Tourney up to XT.
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
Road/touring bike has a 42/34 front with 12-26 in the back.
Fatbike has a 32 tooth front with a 10 speed 11-34 in the back.
Fargo is a dingle speed. 55 and 70 gear inches.
SS road bike 70 gear inches.
SS trail bikes are 50-55 gear inches.
I like speed
- Pavement
- Road bike
- Flat to rolling hills. Climbs are 6-8% on average.
- 50/34 front, 11-32 rear on the Cannondale. 50/34 front, 11-30 rear on the Orbea. Both are 11 speed.
- I wouldn't change anything right now as the compact gearing works well. I typically find myself cruising somewhere in the middle the cassette and the big ring the majority of the time.
- Road bike
Mad bike riding scientist
Quoted: 6256 Post(s)
Liked 4,280 Times
1. Look at a map of the US. That’s the terrain I ride. I ride mostly in the mountain west but I’ve ridden everywhere but Florida and Alaska
2. Mountain and road.
3. See 1 above. I have mountains to the west and plains to the east of where I live. But for butt kicking hills, go to the eastern US.
4. 785%, 760%, 714%, 691%, 550% and 424%. I use them often
5. The 424% to something more useful
- See number 1 above.
- Touring, mountain (3), cruiser and fast road bike.
- From no. 4 above in order:
-Touring, 46/34/20, 11-36 9 speed
-Mountain bikes 44/34/20 11-36 10 speed
- Cruiser(ish) bike 44/34/22 11-34 9 speed
- Commuter (cyclocross really) 48/34/22 11-34 9 speed
- Fast road 50/39/30 11-28 10 speed
I’ve spent decades getting the gearing I want. I wouldn’t change anything now and I deal with old equipment (I have a huge inventory of 9 speed parts) because the current fad is just dumb in my opinion. It stems from people not knowing how to adjust their bikes and not knowing anything about gearing. And that includes the manufacturers.
Stuart Black
Stuart Black
Likes For cyccommute:
