Roubaix Help!!!
Roubaix Help!!!
I bought a 2017 Specialized Roubaix Pro frame on ebay. It was a new frame and it came with the three Future Shock springs in a bag. I unscrewed the top off the Future Shock and greased up the yellow spring and put it in. I put the stem on and pushed down on it and I heard a clank noise. I pushed three times and got three clanks. I called the dealer I got the frame from and they said that I should run the bike without a Future Shock spring. He said the springs are just for fine-tuning. I've never heard this before. Can any Specialized Roubaix owners confirm you can run Future Shock without a spring.
Bikes: Focus Arriba, Specialized Roubaix Expert, Bianchi Impulso Allroad
Quoted: 109 Post(s)
Liked 82 Times
I've never heard of running the FS 1.0 without a top booster spring. Comes fitted from the factory and the fine tuning comes from swapping the medium (black) spring for the firm (yellow) or light (blue) springs
There is also an internal spring that is not easily replaced.. some call it the bottom spring. Check out the video above, it may be helpful.
OP: I have the 2018 Roubaix Sport. When I first got it, it took me a while to pinpoint that the "clanking" noise I was hearing was the FS 1.0 spring you're referring to. I believe that spring is just a "booster" for fine-tuning the dampening of the sealed main spring. I took the spring out, and have been riding sans spring for about 18 months. No issues. And it's quieter. I do, however, ride on level, pretty good roads -- so I'm not really taxing the springs anyway. Actually, I didn't notice much difference ride quality-wise between having the spring, and not. I was mainly after getting rid of the noise.
I took it to my local Specialized dealer and he took the Future Shock apart. Greased it up, tightened everything, put it back in and it stilled clanked. He said it would be replaced under warranty. I asked him what version it would be and he wasn't sure. I'm hoping it's a 2.0, but I would be happy with a working gen 1 version.
Quoted: 1286 Post(s)
Liked 1,382 Times
Quoted: 1071 Post(s)
Liked 804 Times
Chances are they will not upgrade to a 2.0 as it is not officially sanctioned by Specialized. I upgraded mine to 2.0 this year and is a better unit, work with your dealer to see if there is anything they can do. Perhaps pay an upgrade fee, it is defiantly worth it.
TIA
p.s. -- I have a 2018 Expert
Quoted: 590 Post(s)
Liked 445 Times
I don't have any clanking from my 2016-2017 Zertz Roubaix, nor the COBL-GOBLR seatpost that came on it. That's all the suspension I need. RIP Zertz.
Quoted: 1588 Post(s)
Liked 1,227 Times
Mine was replaced under warranty with FS 2.0 thanks to the efforts of my dealer. Blissful silence; ultra-smooth and sensitive in operation. The new assembly fit into my 1.0 bike seamlessly.
Likes For badger1:
Liked 804 Times
