Moving shifter from downtube to handlebars in 1995 bike?
Quoted: 97 Post(s)
Liked 40 Times
I have an old classic TREK 1000 with 7 sprocket cassette with friction shifter levers on the downtube. The bike is a great rider but having to reach way
down to shift gears in some situations is very dangerous and makes me not want to ride the bike in any hilly areas.. I have been considering getting some kind
of handbar shifter and would like to use an STI shifter to combine with the brake lever and while I think I can find some 7 speed shifters either new
or old and used I am worried that I might not be able to locate and anchor the shifter cable housing the way bikes are supposed to. I dont think the
bike is worth the expense of having someone weld to the aluminum frame so I wonder if there are any clamp on devices or something that works with
radiatior hose clamps etc. I am trying to decide on whether to keep the bike original in which case is is only useful for long level and unchanging roads
where shifting gears is not needed. or risk screwing it up and have it not work which will result in me trying to convert it back to original.
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 162 Post(s)
Liked 135 Times
I'm not sure if there's anything unusual about the shifter bosses on a 95 Trek 1000, but shifter boss adjusters are the usual answer:
https://problemsolversbike.com/produ...usters_-_33831
Likes For John Nolan:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Shimano ST-A070 or MicroShift R7
I've used both, and like the MicroShift paddle configuration better. You'll need cable stops on the downtube, the kind that fit over the existing shifter bosses.
Quoted: 574 Post(s)
Liked 611 Times
Here is a guy showing you haw to do it on a 90s Trek 1000:https://www.youtube.com/watch?app=de...ature=youtu.be
SE Wis
Quoted: 2755 Post(s)
Liked 3,426 Times
If the free hub can take an 8 speed cassette, perhaps consider going 8 speed. Check if the rd could do it, but I suspect it would. Shifters would probably be the same cost?
no matterwhat, does he have to look into the throw/pull for the fd?
I considered this for my older 7 spd tourer many years ago but I don't think microshift was around then. Just left it as is, but spent decades riding dt so have no problems using it safely. That said, dont ride this bike much and don't miss dt at all, especially in city riding.
Quoted: 97 Post(s)
Liked 40 Times
Ok many thanks for the help. So I get shifter boss adjusters and micro shift shifter ( I only want to do the rear gears setup as I rarely even in hilly areas use the front deraiuler
and I will leave it on the downtube if possible to save money. ( I assume you can convert only one side ? ) or does the new shifter boss replacement convert both sides ?
Now the question of the rear deraileur and rear sprocket set. I can keep the existing 7 sprockets and they will work with a new Microshift 7 speed shifter.... Correct ?
I think if I get much more than this money wise, I would just as well take the same money and buy a used bike with handle bar shifters already on it. and sell the Trek 1000
in its original form. It is significantly lighter than any of my other bikes so I think it must have been a little bit high end at least compared to my other bikes.
Quoted: 862 Post(s)
Liked 1,105 Times
SE Wis
Liked 3,426 Times
Vintage Trek Bicycle Catalogs and Bike Brochures, Fisher, Klein LeMond
Quoted: 1439 Post(s)
Liked 1,094 Times
Zip tie Karen
Liked 1,542 Times
As @dsbrantjr said ^, you can convert only the right shifter. The downtube bosses are sold in pairs, unless you can scrounge one at your local bike shop or coop parts bin. You understand that the feel of your brake hoods will be drastically different between the right hand and left, don't you? This would bother me unacceptably. What is your budget for this conversion? You'll have to factor in cable housing and inner cables as well. You need to think this through.
As to compatibility, yes, MicroShift will index Shimano equipment properly.
Quoted: 97 Post(s)
Liked 40 Times
Thanks for that historical link. Based upon serial number I have determined my Trek 1000 is a 1990 model. Some of the components
have been upgraded and as it sits fully ready to ride it weighs 23 pounds which is much lighter than any other of the dozen bikes I have
owned over the last 40 years. I hate the shifters however and unless I am riding rail road tracks or at the beach where I never shift,
I always ride other bikes with the shifters I like.
Quoted: 97 Post(s)
Liked 40 Times
As @dsbrantjr . What is your budget for this conversion? You'll have to factor in cable housing and inner cables as well. You need to think this through.
Clark W. Griswold
Quoted: 4495 Post(s)
Liked 4,174 Times
This is what you want: https://www.gevenalle.com/product/audax/ you can use your old shifters and have proper brake levers that are just brake levers which normal STI levers don't afford.
Don't bother with tourney shifters unless absolutely desperate.
In terms of the STI on bars and down tube in place because shifting is rarely done on the front derailleur so to save weight they kept the front downtube shifter as it weighs vey little and allows them to cut weight out. Now more and more are having to add weight to the bikes as the UCI minimum is quite outdated but back in those days the minimum wasn't as bad with the bikes of the day. Still outdated ATMO but harder to achieve.
Quoted: 1956 Post(s)
Liked 2,200 Times
Most everyone here has done this. Here are my thoughts.
If it is a 1990, the 1000 came with has a 7 speed Suntour Blaze. Not knowing your upgrades, having a Shimano drivetrain on your Trek is the first question. If it is Suntour; derailleurs, hubs, a freehub (Suntour cassette) just complicates things... a lot.
If you upgraded everything to Shimano (index compatible), then it is just a matter of adding downtube shifter boss stops with barrel adjusters, new cables and housings, and the shifters of your choice.
However, if in your upgrading you decided to use Shimano Dura Ace 74XX derailleurs, you have more issues.
You should really list your drive train components.
John
John
Likes For 70sSanO:
Quoted: 862 Post(s)
Liked 1,105 Times
BITD-Back in the day. As veganbikes mentioned when the STI shifters first came out they were very heavy compared to downtube shifters and since carbon fiber frames where in their infancy at the time dropping weight was far more difficult with most still using steel frames in the pro's. Soooo, some pro's would use just the right STI shifter and particularly on mountain stages.
Quoted: 1636 Post(s)
Liked 1,842 Times
Likes For icemilkcoffee:
Clark W. Griswold
Liked 4,174 Times
But also of higher quality and allows you to continue to use the same downtube shifters. I never said they were cheaper though.
Quoted: 4560 Post(s)
Liked 2,804 Times
They may also be a bit more reliable. Indexed front derailleur shifters can sometimes drop a chain, which is disastrous in a race, especially on steep climbs where we lose momentum quickly. My bike with Microshift R7 will occasionally drop the chain on a front derailleur shift, but I can always horse it back onto the chainring. It's happened only once on a group ride and another fellow put a hand on my back to help keep up momentum while I horsed it back onto the chainring. Good to have experienced riding partners.
Not that many pros opted for the combination of a downtube shifter on the left for the front derailleur and integrated shifter/brake for convenience with the rear derailleur. Lance Armstrong, notably, did on a few mountain stages.
I haven't seen many, if any, cyclists opting for the downtube FD shifter for tackling KOMs on genuine climbs, Everesting challenges or those British autumn hill climbing contests. Most go for the convenience of brifters. But those are basically time trials, not racing in a peloton. Different techniques and strategies.
BITD: back in the day.
Monkey Boy
Bikes: '22 Surly Straggler, '15 Breezer Downtown EX, '19 Motobecane Record (fixie)
Quoted: 77 Post(s)
Liked 90 Times
If you haven't purchased the shifter boss adjusters, send me a message. I have a pair that you can have (pretty old dura-ace) if you pay for postage. I think I even tossed a third in the same bag. Just let me know.
Artist | Musician | Bass Player
Life is what happens to you while you're busy making other plans. (o.o)
Quoted: 97 Post(s)
Liked 40 Times
had done some upgrades to the bike. Here is the current configuration. to start..... from what I can tell, the things they did not
change are the brake levers and brake calipers. which are Diacomp BRS Blaze brake calipers and brake handles and the
Front Deraileur I think is original Suntour Blaze. ( I can make out "Blaze" for sure and Suntour possible from the little markings still left.
Changed / Upgraded:
I cannot tell if the rear sprockets are original but there are seven of them.
The front two Sprockets are Shimano Biopace with Shimano 600 crank arms.
The rear Deraileur is a Shimano 600, Shimano 1050 lever shifters on downtube
Mavic Rims front and back.
John, as far as what you said complicates things, how can I tell what kind of rear sprockets it has ?
Liked 1,842 Times
What complicates things is the Suntour front derailleur- it's probably not compatible with the STI shifter. You will need to swap it out in favor of a Shimano front derailleur that is designed to work with STI shifters.
