Quick release seat clamps
I’m thinking about getting a quick release seat clamp, but I wasn’t sure how secure do they keep the seat post compare to a regular clamp with screw?
I want to it to be secure so it doesn’t shift up or down or side to side .
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2137 Post(s)
Liked 1,650 Times
All of the manufacturers recognize the inherent flaws of the design and recommend the use of super glue with their products.
Likes For Paul Barnard:
Likes For Awesomeguy:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Another way to secure the quick release seatpost clamp is to set it where you want it to be, and then heat it up with a torch to ~450 degrees, and then flow silver solder into the threads and smaller gaps. Then it'll be secure.
Likes For Phil_gretz:
Likes For Herzlos:
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
And I thought I was a dick.
The only reason for a quick release is you remove it to transport.
I would imagine they are no more likely to slip than a quick release wheel.
Clark W. Griswold
Quoted: 4453 Post(s)
Liked 4,117 Times
The only reason to use a QR collar (on a non-folding bike) is if you have an Angell-Breeze Hite-Rite! Once your seat post is set, there is no need to move it and if you are thinking of sharing the bike, tell them to get their own or just mark where your height is and their height is with a pen or scratching tool.
They were also used before dropper posts to get the saddle out of the way on descents without the need for tools. It's definitely not as versatile as a dropper but I have one on my older mountain bike and it's never shifted at all. It holds just fine without any need for glue, solder or wise-ass responses. As mentioned above, I just scratched a line onto the seat post at my proper riding height and I can quickly get it back exactly where I need it.
Likes For JW in AK:
Quoted: 590 Post(s)
Liked 445 Times
A quick release seatpost is a great way for someone (either friend or foe) to mess with you and remove it while you're in the convenience store buying Gatorade. I've seen people put a cable lock thru the seat rails and secure it to the frame to avoid such shenanigans.
On Your Left
Liked 2,434 Times
got it.
Likes For GlennR:
Quoted: 716 Post(s)
Liked 807 Times
QR seatpost clamps are prone to allowing the post to slip. There is no reason to use one unless the bike is a rental and needs to have the seat height adjusted on a regular basis.
Bikes: yes, i have one
Quoted: 1151 Post(s)
Liked 1,193 Times
I used one just fine when I commutted. I have one bike but used to switch the seat with one that had a pannier rack. Fast switch, real easy, never failed.
Likes For phughes:
Quoted: 1063 Post(s)
Liked 1,322 Times
Actually we did used to use them to lower the seat on mountain bikes when you wanted it out of the way. I didn't stop at hills as you describe, but there were times when I wanted it out of the way. My first mountain bike came with a quick release seat post clamp in 1984. A dropper post is much more convenient I am sure. I don't ride mountain bikes right now though, but still have my original.
Bikes: Way too many
Quoted: 936 Post(s)
Liked 610 Times
More than likely it's seat up to ride to the trail, then seat down to ride the trail, and seat up to get back home.
I use it as well to take the seat out to fit/remove a bike trailer bracket.
Likes For Herzlos:
Quoted: 430 Post(s)
Liked 714 Times
The "clamp" is built into the seat tube on my old GT mtn.bike, but it does use a quick release. To access some of the trails I ride, I have to go a little ways on a mup, then I have the seatpost higher. When I reach the trailhead, I'll lower the seat a little. I've used carbon "paste" on the post and the quick release does have to be tight, but no problem with the post slipping (the carbon "paste" helped!)
Quoted: 2581 Post(s)
Liked 3,095 Times
Those of us who were riding single track at speed in the early to mid-1980s learned quickly that keeping the saddle at full road bike height would sometimes result in the rider being bucked off the bike. Thus, we learned to drop the saddle at the start of the ride and return it to full height at the end.
I'd love to know who came up with idea of installing the quick-release seat post clamp. Wasn't anybody I knew. The Hite-Rite came along a couple of years later.
Likes For Trakhak:
Quoted: 1955 Post(s)
Liked 2,200 Times
The older ones were like a mini internal cam quick release with a skewer.
They were offered by a lot of companies including the ones that make components most people ride, even from Italy.
John
John
aka Phil Jungels
If you want one, fine! Go ahead and get one! They work absolutely fine... Never had mine slip - ever! And nobody has ever messed with it. It's really handy for when you want to change the height of the saddle, for whatever reason you want to.
An honest question deserves an honest answer.
Those other guys must think they are on the road bike forum!
Advocatus Diaboli
Quoted: 4765 Post(s)
Liked 1,543 Times
Not sure, but I'd wonder how these work if frame/post are carbon fiber? People talk about correct torque values being used to prevent damage etc, and I don't see how you determine equivalent torque value with a hand QR clamp,
With a mighty wind
Quoted: 1114 Post(s)
Liked 912 Times
The one time I did it was with a regular bolt, not QR, on a long descent. The dropper post is a massive improvement for sure.
Advanced Slacker
Quoted: 2764 Post(s)
Liked 2,543 Times
A quality QR clamp works fine. I have one (Salsa) on my wife's bike because it can make loading it easier with certain bike combinations. Will likely do the same on my road bike as well.
Used to be standard for any MTB I owned, but they have all been replaced with droppers.
Advanced Slacker
Liked 2,543 Times
I saw this plenty when riding places with long downhills. Living in Tahoe I did it enough to wear out a CF post. Most people I rode with would do this on long descents. When taking someone on a new trail, telling them when it was a good time to drop their saddle was common.
This was in the early 2000's before droppers were a thing and is why droppers were invented.
