OK, I just don't get the mullet concept...
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
The most common mullet config seems to be a knobbier tire on the front, and a slicker one on the back. I ride in SoCal on loose over hardpack, lots of steep climbs. If anything, it's my rear wheel that loses traction, not the front, as I try and launch myself up over some pitchy section. I know technique is a big part, but that aside, what is going on with the mullet set up, and what am I missing? Is it not about climbing traction?
Randomhead
Liked 3,786 Times
I'm sure I don't know anyone riding a bike like you describe, but it could be tire clearance issues in the back. This seems to be the motivation for most mullet systems on other types of bikes.
Likes For unterhausen:
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
Less weight in the front = less traction. A knobbier and wider front tire can help with that especially in speedy turns.
Quoted: 3325 Post(s)
Liked 2,171 Times
Typical mullet I’ve seen is a mix of 27.5 and 29 wheels on a mt. bike. I don’t get that either.
Quoted: 582 Post(s)
Liked 1,027 Times
Bigger front tire for more float and traction is a MTB thing. Front does most of the braking, tracking, and bump absorption.
Rear slipping can be mitigated by spinning, we thought slicks were a terrible idea when they first came out. After learning how to keep the rear tire engaged, we realized how faster they were.
Quoted: 284 Post(s)
Liked 313 Times
Yeah, I'm aware of the bigger up front, smaller out back approach. But I've been seeing some gravel folks with a knobby front, smooth rear, same or very close tire size (for example, a WTB Sendero 47 front, Byway 47 back, or similar). Currently I use Ventures and if I stay seated I can get up most anything on my local terrain without the rear sliding out (which wasn't true when I ran the slicker ByWays). But I was just wondering if the added knobbies up front really did much in a climbing context. Sounds like it's more about hooking up in other ways--cornering, etc...
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
I'm running a 2.35 on the front and a 2.25 on the rear, but the same tire/tread pattern on my 29r XC. Larger front will float over softer areas better. I would never run a slick on the rear... IMO that's just stupid for the dirt.
Randomhead
Liked 3,786 Times
Did someone already say all gravel is local? I don't think I would run a slick around here because the tread would be shredded pretty quickly. I have lived in places where dirt roads were smooth and beautiful to ride on. Anything knobbier than slicks would be overkill.
It's all kind of moot right now for me, all the forest roads have 15 inches of snow on them
I have had occasion to wish I had a bigger tire on the front of my fat bike.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
When turning and/or going downhill, traction is more important in the front. Losing traction in the front is more catastrophic than losing traction in the rear. Of course going uphill traction is more important in the rear.
A a slicker, less knobby, rear tire increases efficiency.
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 390 Times
Mullett is the term when you use two different sized wheels (27.5/26 or 27.5/29). The point of the gripper and fatter front tire is that it helps you carve turns and deal with downhills better. Loosing traction going uphill could be because of lots of situations. A gripper front tire won't do much to help climb. Sounds like you need a grippier rear tire.
Quoted: 284 Post(s)
Liked 313 Times
Bikes: Kona Unit, Kona Kahuna, Kona Dew DL, Scott Big Jon, Trek Checkpoint ALR4, KHS Urban Soul, Haro Team Issue, GT Force Expert Carbon, Bernardi Quadra.
Quoted: 31 Post(s)
Liked 48 Times
As far as I know,Mullet on a gravel bike is mixing SRAM AXS Road and MTB components, a road crank and shifters with an MTB cassete and rear derailleur. Mullet on a mountain bike is a 29 front wheel and a 27,5 rear wheel, I've never heard of mixing wheel sizes on a gravel bike before.
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 398 Post(s)
Liked 788 Times
I thought all gravel riders had mullets, beards, flannel ****s and major body odor? I'm surprised this is even a question.
Quoted: 86 Post(s)
Liked 51 Times
Unfortunately I’ve seen mullet used to describe three totally separate things in cycling: mixed wheel sizes in MTBs, then drop bar bikes using drop bar sram shifters with MTB sram derailleurs, and now mixed tread type on gravel bikes. Despite the OP being crystal clear in their question, people cannot help but post about one of the other uses.
The reason here is that with a gravel bike there’s a reasonable chance that you might ride 20 miles of tarmac to get to the dirt section. Of course the slick or semi slick rear is going to be worse in dirt, no one will argue otherwise. But it might be a lot better for rolling resistance and squirm on pavement. It’s about the best overall compromise for mixed rides that really truly are mixed. Maybe you suffer or walk some in the dirt in exchange for suffering less on the ride to and from.
Most MTBers I know drive those miles so they might have little idea how awful full knobbies are on long road rides (especially those flirting with mullet setups for more exxxxxtreme whatever). And the AXS ‘mullet’ shifting setup, again I’ve mainly seen this on bikes that are really drop-bar mountain bikes.
As a matter of fact on my current 650b gravel wheel set I have a WTB Venture front and Byway rear. However IMHO WTBs are ass and I’m looking forward to replacing with one of the recent file-tread tires (Pirelli, Spec, Vittorio etc) that roll better than the semi slick WTB on pavement and outperform it in dirt to boot, with the same tread front and rear.
Disco Infiltrator
Quoted: 3133 Post(s)
Liked 2,115 Times
Likes For Darth Lefty:
Quoted: 1873 Post(s)
Liked 693 Times
2019 Salsa Warbird
2019 Salsa Warbird
Disco Infiltrator
Liked 2,115 Times
https://www.mtbr.com/threads/surly-g...ppler.1154577/
Genesis 49:16-17
Genesis 49:16-17
Quoted: 166 Post(s)
Liked 252 Times
It’s really going to irritate you when this thing shows up
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I sometimes ride with a wider front tire. This gives me
- better flotation, and steering in soft conditions
- a little bit of suspension up front. (riding at below 25psi will smooth out a lot of bumps).
- more trail and stability for a rougher route.
People address some of the above by using a front fork, or a shock absorbing stem, or even more exotic stuff with Trek & Specialized frames.
I like a smaller faster tire on the rear, because 70% of my rolling resistance comes from the rear tire - and my bike is very smooth riding in the rear.
Maybe work on your technique? I don't have traction problems with a slick or near slick on the rear (except muddy slick/wet conditions). Pick the right tire pressure, have a smooth pedal stroke, a little body English. When racing, I'll ride up stuff on near slicks that others are walking up.
