Do you have to degrease your chain if you're caught in heavy rain for about 2 hours?
Was riding around and pelted by moderate to heavy rain. Just wondering, should I just re-lube it and save the time on degreasing?
Quoted: 3326 Post(s)
Liked 2,171 Times
Good practice to wipe dry and re-apply a light lube.
Quoted: 1062 Post(s)
Liked 665 Times
In my view, bikes are not as delicate as we tend to think. I park my bike in the garage and let it drip dry.
Chain care rituals seem to range from nonexistent to bizarre.
Likes For Gresp15C:
Quoted: 38 Post(s)
Liked 34 Times
I use a "dry" lube, so washing the bike or riding in any amount of rain means that I need to dry and re-lube the chain, or else I get flash rust on at least the chain sideplates within a day or so. I don't de-grease unless the chain was due for it anyway.
Likes For ScottRiqui:
Let's Ride!
Quoted: 327 Post(s)
Liked 37 Times
depends on your lube?!. dry vs wet. I use what is called pro on my commuter from now defunct Nashbar. It says putting in gentle rain but the mountain bike gets dry lube.
Quoted: 4876 Post(s)
Liked 4,042 Times
I use two lubes. Tri-Flo for my summer bikes and Finish Line MTB wet lube for my winter bikes. Hard rain and TriFlo? I lube when it's dry and use a lot. The wet lube? It's usually fine but I would probably run the chain through a rag and give it a light lube. (That's if I am a good boy, but the bike just forgives me then gets dirtier to spite me if I forget. The summer bikes will complain quite audibly when I try to ride them.)
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
I ride almost daily in rain or heavy sea mist (think salt). I wax my chains so it isn't quite the same problem, but I still run a dry rag over the bike before putting it away. The wax is much more resistant to wash off than any oil I've ever used.
Likes For Bigbus:
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
I'd prefer to have a chain covered in grease because this will protect the chain from rusting every single time you get caught in the rain
Overdoing projects
Quoted: 787 Post(s)
Liked 1,284 Times
Oh is that what you're supposed to do? I usually just put it away like that and ride again the day after. Even a friend of mine who would ride 40km (25 miles) each day for his commute would only lube the chain once it would start creaking or he noticed an increase in drag.
Alternatively, sounds like you might like a full chaincase or a belt drive bike if this is something you do more often.
Likes For JaccoW:
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 337 Times
For a number of years I parked the bike outside at work, under the open sky. I hardly knew whether it rained during the day or not. The rain mattered as I rode as cared whether I needed to put a rain cover over my luggage. Yes, it rains and snows outside and the air is commonly not at room temperature.
Quoted: 2639 Post(s)
Liked 1,987 Times
No need to futz with "cleaning" beyond a simple wipe down. A hard rain will wash the lube out, but there's still a chance road schmuck will be on the chain. Bounce the bike to shake off the water, wipe it off with a rag or paper towel, a relube. It'll be ready to ride in the morning (rain or shine!).
Disco Infiltrator
Quoted: 3133 Post(s)
Liked 2,116 Times
I keep one chain in the crock pot, one ready to install, and one in the rain.
Lest anyone take this for actual advice, I have not really tried chain waxing
Genesis 49:16-17
Genesis 49:16-17
Very Senior Member
Quoted: 413 Post(s)
Liked 343 Times
Before I arrived on the coast, I used to just put some 30wt oil on my chains, wipe them off with an old rag and not worry about them for 6 months. But now, between the salt in the water and sea mist and all the sand that coats everything, if I didn't wax I would be someone's best chain customer, not to mention cogs, chain rings, etc. After having cables rust and break I've even taken to waxing the new cables before installing them. Oil just washes out. Even SS spokes rust here.
Quoted: 1082 Post(s)
Liked 1,343 Times
Liked 1,343 Times
I used to commute in the Winter, which meant slush with loads of salt. I had no chain issues, none. No rust. None. I did not degrease after every ride, nor did I even wipe the chain down every time. I kept it lubed well though.
So the answer is the same. No, you don't need to degrease after rain or salty rain. Rain doesn't add grease. Rain adds water, and other contaminants, but not grease. Keep an eye on it, wipe it down, and keep it lubed.
Likes For phughes:
