Older Shimano Chainrings
Still Wheelies Motorcycle
Bikes: Masi, Novara, Specialized
Quoted: 19 Post(s)
Liked 46 Times
I'm getting back in the saddle after a long hiatus, and spent a couple of days cleaning, lubing and replacing the tires on my old friend.
I noticed the chainrings are getting pretty worn, and spent a couple of hours on the internet, looking for a replacement pair (42t and 53t). I found some on Ebay, but they were in even worse shape than mine.
So I thought I'd put it to the hive-mind here: Does anyone have a source for NOS or good-quality aftermarket chainrings for the Shimano 600 Ultegra - 6400 series? Its 130 BCD, with 7 speed cassette.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
QBP is out. They're the largest bike parts distributor around. I saw a few on Amazon, try there.
Quoted: 1635 Post(s)
Liked 1,839 Times
Your Ebay search-fu needs some work. NOS 42T/53T chain rings, from the same seller no less:
https://www.ebay.com/itm/New-Old-Sto...D/391805754229
https://www.ebay.com/itm/New-Old-Sto...D/391809326462
Really Old Senior Member
Is this Steve P. in CDA?
Chain rings will have various cut outs & shift ramps spaced somewhat equally around the ring.
Are you confusing these with wear?
Likes For Bill Kapaun:
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
IIRC, Shimano 6400 series pre-dates pinned and ramped chainrings. Any rings using the same bolt pattern and bolt circle diameter ought to suffice as replacements.
Likes For JohnDThompson:
Quoted: 19 Post(s)
Liked 46 Times
Icemilkcoffee: Awesome! Thanks for the links. I have them on order. Agreed my eBay search skill seem to be lacking... thank you for your time and effort.
Bill: No this is not Steve. I live in the woods, a ways north of CDA. We call that part of the state "Southern Idaho" LOL. Better hardware storres in CDA than up north, that's for certain!
As for the ramp teeth, yes I'm aware of them. These rings have several thousand miles on them from when I was pretty hard-core back in the day. I'll continue to use them, but I was alarmed that I might not be able to replace them when they finally get too worn down.
Thanks to you both for the quick and helpful replies!
Quoted: 4236 Post(s)
Liked 3,963 Times
When using non ramped and pinned rings consider trying the Shimano trick of "W cut" teeth tops. On the middle or big ring file down about 1/3 of a pair of teeth tops, at an angle that grabs the chain plate. in a few locations about the ring will allow for quicker chain pick up and derailing back. This is about 40 year old stuff. Andy
AndrewRStewart
AndrewRStewart
Quoted: 19 Post(s)
Liked 46 Times
I can just imagine what a wonderful childhood growing up in a nice place like CDA was like.
Not only being 20 years behind you of my DIY bike repairs, I'm still 20 years behind the present.
I started fixing my own when I was thrust in to a bike, bus or walk situation. I was in financial hardship and going legally blind.
I started flipping bikes to earn a few $ to help. I learned the pitfalls of trying to take a BSO and make it something you could sell with a good conscience and not lose money.
I stayed with mountain/hybrid bikes to keep things simpler, since back problems kept me from riding a road bike. I didn't want to sell anything I couldn't test ride and know it functioned at least decently. I finally reached the age to get early retirement (75%) so I could buy a lens implant.
I don't have the personality skills or speed to work at an LBS. Why ruin a decent hobby?
The last 2 years have been unkind to my health and can only make an occasional trip to the grocery store if the weather is warm enough and minimal breeze.
I had/got through bladder cancer 2 years ago, but the BCG (immunotherapy) following caused chronic fatigue. Dec. 28th I went in for a needle biopsy to confirm lung cancer, but the "mass" had shrunk from 22x41mm to 8x9mm. They canceled it! They think it's a lung infection of some type and will give me another CT scan in about a month. Meanwhile, I'm extremely short winded. I'm sure hoping I can recover to my normal COPD state.
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
I use Vuelta chainrings on some of my bikes. Perfectly good quality and reasonably priced.
https://www.vueltausa.com/components/chainrings.html
Quoted: 19 Post(s)
Liked 46 Times
The original Shimano items are pretty expensive for a semi-consumable item.
Quoted: 101 Post(s)
Liked 46 Times
I should have posted a different link - that one is for their ramped/pinned rings that get pretty expensive as the teeth increase.
All the ones I have are the cheaper plain jane rings; here is the link, and of course you can likely find them cheaper from eBay sellers than what you see here:
https://www.vueltausa.com/components...ings-flat.html
Habitual User
Quoted: 5067 Post(s)
Liked 8,368 Times
For future reference, FSA rings will work fine, too. As has been mentioned before, pretty much anything with the 130BCD pattern will get the job done.
Quoted: 19 Post(s)
Liked 46 Times
