quick link for sedisport chains?
The sedisport chain I have is supposedly known as what is a 6-8 speed chain. Rather than breaking the chain Id like to be able to use a quicklink(makes cleaning and rear wheel removal much easier). Ive tried the sram quicklink for the sram chain (6-8speed) that I use on the same bike and it is not wide enough. I purchased a kmc one which was rated at 7.3 mm across, where the sram one I had measured 7.1 mm, it actually fits on to the sedis chain, but is too tight for the links to pivot.
Does anyone know of quicklinks that are slighter wider, Ive looked at most of the products and they rarely give a width, just say they are for 6-8, 9, 10 ,11 speed chains
Clark W. Griswold
Quoted: 4495 Post(s)
Liked 4,177 Times
So Sedis was purchased by Sachs who then later got purchased by SRAM. I know when Sachs bought them out they had quicklinks but I don't know of any specific modern quick links that would work. You could try Connex/Wipperman since you have yet to try that one but you might just need to use a pin as finding NOS would be tough. I don't mind breaking a chain, it doesn't take a long time and isn't that hard and if you are good you don't have to push out the old pin entirely and can push it back pretty easily.
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
I have many SedisSport chains in use here. I've never found it necessary to use a quicklink. Just use your chain tool to push the pin back in when you re-connected the chain.
Likes For JohnDThompson:
Are the "new rules" just for newer chains?
Is it best to pick a different pin each time or undo the same one
Thanks.
Clark W. Griswold
Liked 4,177 Times
Im not fussed with the extra effort of using the chain removal tool, just thought current thinking was that pushing the pins out and rejoinig was frowned upon as weakening the chain etc?
Thanks.
Thanks.
Old fart
Liked 3,454 Times
Wider chains for 8 sprockets or fewer on the rear cluster have longer pins that don't need to be riveted in place. Pins on those chains can be safely re-used.
Quoted: 581 Post(s)
Liked 921 Times
My experience has been that Shimano HG chains, starting with 7 speed I think, required a new pin for each reassembly. Perhaps they aren't quite as fussy as 9 speed+ chains but it still makes a big difference.
I also found that Sram quick links worked perfectly on my 7-8 speed chains from Shimano, Sram, and KMC. Perhaps OP has an older 6 speed chain, which would definitely have the older reusable pin construction.
I understand from the comments above that there is no real problem with pushing out the pins on the sedisport chain, but for the convenience of a road side puncture, getting the chain off quickly speeds up the repair. There is only one orientation that my wheel will get past the chain, bottom bracket dyno and mudguards, and its really difficult to find it/replicate even when having the luxurty of the bike on a proper work stand, never mind roadside laying on its side in the dark and the rain
Clark W. Griswold
Liked 4,177 Times
Perhaps you are right, the sedisport chain I have perhaps is strictly a 6 speed and is slightly bigger/different than what is marketed today as being 6-8 speed(the shimano chain the bikeshop sold me as an "identical" sized replacement requires new pins each time), and hence why the 6-8 speed quicklinks ive tried so far wont fit.
Quoted: 581 Post(s)
Liked 921 Times
veganbikes In my experience removing the wheel from a single speed or coaster brake bike or bike with some sort of chain case can be a bit of a hassle (poster says he has a dynamo too), and there is no 'smallest cog' in which to shift. But I agree that removing the chain doesn't seem like it would be the simplest way - the last time I had to fix a flat on such a bike I just pulled tube out of the tire and patched it instead of trying to get the wheel off.
Jeez that sounds crazy. All you need to do is shift down into your smallest cog at the back give the derailleur a little slack and then take the wheel out. No need to fully remove the chain unless you have some really funky bike but I have yet to see a system where a chain needs disassembly to fix a flat.
Liked 3,115 Times
Wear gloves & leave the chain alone.
-Oh Hey!
-Oh Hey!
Clark W. Griswold
Liked 4,177 Times
