Cannondale Front Derailleur Options
Bikes: Miyata 710, Univega Viva Sport, Centurion LeMans, Peugeot U09
Quoted: 212 Post(s)
Liked 111 Times
I am working on a Cannondale R400 Triple. I believe its a 2001. I'm having trouble with the shifting on the front cogs.
The original deraileur has been replaced with a Microshift R10. I'm thinking I should go back to something like the original shimano. I need a clamp-on for a 28.6 tube that will handle 3 rings in front (30/42/52), 8 in the rear (12-25), and work with the Sora STI Dual Control brifters. Rear derailleur is a Shimano Sora RD-3300 Long Cage.
My choices seem to be the Claris FD-2403, the Sora FD-3403 or the Sora FD-R3030. Any thoughts or suggestions appreciated.
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 275 Post(s)
Liked 419 Times
Do you have a boss on your frame for a downtube shifter, with a cable adjuster mounted on it? Or is it just a cable stop?
You could do what Lance and Pantani did. Friction downtube shifter for front shifting. And switch your left STI to a plain brake lever.
It's far superior for road triples. Far more flexible too. You might find your current mech would then work well.
This would also let you use a lower granny. 28 or 26. That range might be nice.
Likes For Soody:
Quoted: 212 Post(s)
Liked 111 Times
Just a cable stop. Personally, I would prefer downtube levers, but I need to keep this one as close to stock as possible.
Quoted: 212 Post(s)
Liked 111 Times
After checking, the Microshift I have now is listed as incompatible with my front chainrings.
I also checked again on the seat tube, which is 31.8 not 28.6.
I have tried every adjustment I can think of, and there is always a problem with the chain rubbing on the inner or outer plate in some (or many) gear combinations. Tightening/loosening the cable or adjusting the limit screws doesn't do it.
As far as replacements, someone pointed out that the specs for the FD3403 say min difference between top and intermediate is 11 teeth. In my case it is 10, correct? So, that would not work.
For the FD-3030, the "max ring teeth" is 50, whereas mine is 52. Again, no good.
Any suggestions on other models? I am now looking at the Shimano FD-5504, FD-5503 and microSHIFT R539. These seem to be compatible.
Likes For kross57:
Phyllo-buster
Quoted: 2300 Post(s)
Liked 2,066 Times
Yeah, gotta be 31.8. I used to run a Campy Racing Triple front gear on my R500 and it was brilliant.
Quoted: 212 Post(s)
Liked 111 Times
I ordered a FD-5504. I'll let you know how it works out. Thanks to all!
