Rim or disk brakes?
Quoted: 523 Post(s)
Liked 231 Times
Did you mean to ask mechanical disc or hydraulic disc? Metallic may refer to the pad material for disc brakes. One type is semi-metallic.
I've had one set of hydraulic disc brakes (Hope brand) that was far better at stopping than any rim brake bike I ever rode. The downside was it was a very expensive set if it needed replacement.
Advocatus Diaboli
Quoted: 4795 Post(s)
Liked 1,547 Times
yes, indubitably
Quoted: 18574 Post(s)
Liked 16,027 Times
*yawn*
F-, assuming that is even possible.
Can’t wait to see how many take the bait.
Likes For indyfabz:
Quoted: 1110 Post(s)
Liked 1,050 Times
A decent set of hydro discs are the best stopping and what I now tend to prefer in a new bike. Quality rim brakes are more then adequate to the task of stopping and will do just fine. Unless its a mountain bike or cross, then I always prefer disc for dealing with mud.
Likes For AdkMtnMonster:
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1253 Post(s)
Liked 338 Times
Ain't nothing better than SA DRUM brakes, fit and forget. 25,000+ miles with NO worries, no adjusting, no rim scratch or screech, no fade, no heating, 100% the same in any weather, very little chance of needing cleaning. I went over 20,000 miles with not changing the cable either.
Cable TRP Spyre is next best on other IGH's, like my Rohloff14.
Likes For GamblerGORD53:
Quoted: 2432 Post(s)
Liked 641 Times
The SLX discs on my MTB are the most amazing brakes I ever had.
The RS505 discs on my road bike are no better than rim brakes, except in the rain which I avoid. Actually rim brakes are slightly better. I won't buy another disc road bike.
Bikes: 2022 Salsa Beargrease, 2020 Seven Evergreen, 2019 Honey Allroads Ti, 2018 Seven Redsky XX, 2017 Trek Boon 7, 2014 Trek 520, 2006 Gary Fisher Montare
Quoted: 697 Post(s)
Liked 910 Times
Cantilever with carbon rims.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,099 Times
I use retro rockets. Calibration has been a bit tricky, though, and I don't recommend trial and error.
Likes For livedarklions:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Aero braking... because, who doesn't like aero?
Likes For Phil_gretz:
Bikes: Garmin/Tacx Bike Smart
Quoted: 649 Post(s)
Liked 296 Times
Dammit. I missed at least the first half of my bag of popcorn.
I'm looking forward for the return of coaster brakes.
Likes For dmanthree:
Quoted: 2639 Post(s)
Liked 1,989 Times
O.P. looks like a newbie, it could be a legitimate question.
Answer depends if OP is Catholic, Presbyterian, or atheist. It's a question about religion, at least for some people. You need good, well adjusted brakes to stop you on a bike. There are good and bad examples of each. If you're just looking to buy a new bike, give it a test ride. Make sure the brakes will stop you. Think about coming down a hill to a stop sign and there's a cement truck rumbling down the cross street toward the intersection. Comfortable with that scenario? Yes, you're good to go; no, keep looking.
Likes For pdlamb:
Quoted: 4227 Post(s)
Liked 2,491 Times
The only advantages that disc brakes provide is they prevent your rims from wearing out. Disc brakes are only better in certain conditions like winter time when there is snow, ice and a lot of road grit which is very hard on the rim's braking surface...If majority of your riding is on clean pavement then rim brakes are all you will ever need. A good quality rim brakes which are properly adjusted with good quality brake pads can have as much stopping power as disc brakes.
Tragically Ignorant
Liked 9,099 Times
Bikes: 1978 Raleigh Competition-1974 Raleigh Folder-1983 Austro Daimler-198? Fuji Monterey-Surly LHT-Surly Karate Monkey-Surly Cross Check
Quoted: 43 Post(s)
Liked 97 Times
For what it's worth... https://www.bikeradar.com/features/r...-need-to-know/
Likes For Charliekeet:
Quoted: 6348 Post(s)
Liked 4,948 Times
Depends. But in the grand scheme of things it probably won't really matter for the riding you will do.
If it does matter, then you'll have your answer. And it will be tailored to you and you alone!
Likes For rydabent:
Quoted: 3352 Post(s)
Liked 1,056 Times
The two overridding reasons for disc brakes is-------------one they dont wear out expensive rims, and two, they work better in the wet.
Guest
Quoted: 1346 Post(s)
Liked 3,271 Times
