Rear dropout chain tension screws
Quoted: 5 Post(s)
Bought a 2nd hand Planet X pro carbon frameset last week and it came without the chain tension screws in the rear dropout. Contacted Planet X and it's not something they sell separately.
Not sure on the size, M3 or M4 at a guess but am I right in thinking I can use any generic suitable length screws?
Thanks
Thanks
Quoted: 111 Post(s)
Liked 69 Times
Thanks
Thanks
Those aren't really to adjust chain tension, but to make sure that the axle is in the right spot to center the rim in the frame - that's my understanding, anyway.
The spring helps to hold the adjuster in position, and the flat end touching the axle helps to protect the axle threads.
Your LBS should have those, or you can easily find them online.
In the meantime, if your frame is 'square' you can probably just slide the axle all the way back and lock the QuickRelease tight.
EDIT: My apologies - I saw this in the 'new posts' listing and didn't pay attention to the sub-forum : Track Bikes
Please ignore the above....
Quoted: 4857 Post(s)
Liked 4,002 Times
That's not a dropout. It is a track end. A dropout is by both definition and purpose for being, a slot that opens forward or down to enable a derailleur wheel to easily "drop out" for fast racing tire (now wheel) changes.
Quoted: 5 Post(s)
Exactly the same bike as in your last pic VikBC Biker. I've always known that as a horizontal drop out. Anyways, it's the bolts in the rear drop outs / track ends i'm referring to?
Quoted: 18427 Post(s)
Liked 4,544 Times
Liked 4,544 Times
It does look like the Campy style adjuster screws might fit, although perhaps too small.
I'd take the frame to a hardware store to test screw sizes. At least that will get you the right thread diameter and pitch. Also verify the threads are still good.
Are those really for tension? I bet they are a bit of a pain to use as they'll have to be loosened and tightened every time the chain or wheel is mounted or removed.
Personally I removed mine for mass start racing, and haven't ever had an issue that would compel me to put them back in.
I know a few folks who only put them in for standing starts, but I think that's mostly paranoia.
Thanks
Thanks
If you are a really strong rider there are alternative devices to prevent axle slip.similar to this https://www.amazon.com/BESPORTBLE-Bi...784778&sr=8-16
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
They are designed to keep the wheel from slipping forward during a high torque effort like a standing start or rolling jump.
In fact, that’s the preferred method for stopping this from happening as opposed to making the wheel nuts gorilla tight. This is why some manufacturers even make track disks using allen bolts which cannot be torqued down as hard as track nuts.
You can fabricate something using bits from a local hardware store. Look in the metric section. You may have to buy two nuts for the machine screw and tighten them against each other to make a tip that you grip with your fingers to manipulate the screw in and off. I’ve made such before. It all costs less than $5.
Elitist
Liked 92 Times
Also, your final product cannot be too long. Because, if the wheel has to go all the way forward and the tensioner all the way nearly out, then your heel will touch it.
It’s not catastrophic, just annoying.
So be prepared to cut the machine screw to some optimal length.
Liked 4,544 Times
That makes some sense to prevent wheel slippage. However, I have never had the NDS slip (10-speed bikes), so is there any reason to have the screw on the left other than symmetry?
this is the most overthought thread on something simple in a long time I love it
Just buy a couple of metric bolts the right size from your local lowes/home depot (in the drawers in the fastener section) there is some concern about thread pitch, but likely they'll be right on smaller size bolts. Buy some correct nuts for them.
Thread in the dropouts to correct length for clearance, thread the nuts on as your "stop" (or use loctite purple/blue, just something to keep it from turning in transport/etc)
Or just skip it... tighten down the wheel's nuts properly. Unless you are pulling big starts or using crappy locknuts you'll be fine.
Elitist
Liked 92 Times
On the other end, Tiemeyer used Ti...and don't have any tensioners or allowance for such. And I never slipped a wheel using my Tiemeyer frames. And any big sprinter using a Tiemeyer probably didn't have any either. Ti is the key.
The one's that came stock with my bike weren't long enough so I got my longer ones at the hardware store. It doesn't have the knob, but I basically made my own by using a couple of nuts. I used to think they were unnecessary, but it really makes adjusting the chain tension quick and easy so I've grown to really like them.
Liked 4,544 Times
Test completed with in this case, DS chain stay rub (you can tape up the stay if you wish).
We really need Robert Förstemann on this board to run the test.
Use the screws. Your track ends and axle nuts will last longer.
Likes For Baby Puke:
Elitist
Liked 92 Times
Yup. “Track nuts” are significantly different than regular nuts that you get from a hardware store. Also, to those not familiar, you’ll appreciate buying fresh ones periodically. I suggest Dura Ace, even if you don’t have DA hubs. Just order the correct thread pitch for your hub.
