Anyone ever hear of issues with 3T Apto Team stems?
I bought 3 of them from chainreactioncycles.com recently (not totally sure what size I need). I figured I could sell the 2 I don't need when I figure it out... or keep them, it was a good enough deal. But now 2 of the 3 faceplate (the screws thread in to the faceplate.) stripped with 5.3 newton meters of torque. I'm not sure I'm confident in trying the 3rd.
I even bought the Apto stem tool from them, reasonably priced.... but $20 shipping for that small tool in a 6"x9" padded envelope just to go from one side of the USA to the other was ridiculous. (but I thought I needed it :/)
I probably shouldn't worry. but now I'm questioning 3T quality and I also bought a Superergo team (Carbon) drops and a "Palladio LTD 280mm Carbon Seatpost".
I did send them a message on their web site, so we'll see what they say or do.
This seems weird to me, so has anyone heard/had an issue with the Apto team stems?
IDK it's a Craftsman microtork made in the USA (to what ever extent that matters) with oz in on one side and newton meters on the other. To be clear it's the aluminum of the face plate that stripped.
according to a quick google search "±4 percent" mine is from the early to mid 2000's (barely used) IDK if the acuracy has changed on newer models or not.
Blamester
Well obviously that's too much torque. So what do 3t recommend? I don't use a torque wrench on a bike. But i am carefull.
I torque up a little and check will the handlebar move. If it does move i torque a little more.
Don't tighten one bolt up all the way. Tighten in stages going from one bolt to the next.
I always use the short end of the allen key to put on the intial torque so everything is even to begin with and not over done.
Keep an eye on the gaps between the faceplate and the stem. Nice and even all the way around.
Like you have found out just because you used a torque wrench doesn't mean it is correct. The torque wrench should be used for confirmation not to actually torque the part. And the torque wrench and value applied need to be correct.
You could also have defective parts.
Quoted: 859 Post(s)
Liked 1,096 Times
Your torque wrench could very well be out of adjustment being that old even though barely used if it was dropped or misused in any way or just off to begin with. I have a USA made Craftsman clicker from a little over 20 years ago that started going off after only about 4 uses, I would have stripped a cylinder head if not for my experience sensing more force than was marked on the torque wrench was being applied. Nothing against old Craftsmen products but torque wrenches can go out of calibration for various reasons. Of course it could be a dud stem too. I agree with blamester's advice in post #4 as well.
Well, they got back to me with what seems like a 'that sucks bro'
"Thank you for reaching out, we are sorry to hear about the damaged faceplate.
If the bolts on the Apto faceplate are not set correctly it is possible to strip the threads. We recommend the use of a 4mm hex ball end tool to start threading the bolts into the faceplate and reach torque with the Apto torque wrench adaptor. "
I have never had this issue with stems before, so IDK. Maybe the torque wrench is out of calibration. it has only been used like 8 times and kept in it's box other wise. None of the other bolts on my bike including the ones holding the stem to the searer tube have had an issue. (Maybe I'm lucky?)
Replacement faceplates are a little over $14, I might have bought one, or two even... if it wasn't for the ridiculous $20 shipping.
Didn't even offer to help out and offer the 30% off crash replacement that they offer on their parts. *shrugs
I'm going to have to decide if I'm going to sell the last Apto stem and just buy a different stem or try the last faceplate.
Quoted: 942 Post(s)
Liked 527 Times
Torque wrench has to be out of whack or it was set incorrectly. 5.3 Nm is not a lot, on the other hand if the wrench was wrong it should have been easily felt if you were going too tight.
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 253 Times
I bought 3 of them from chainreactioncycles.com recently (not totally sure what size I need). I figured I could sell the 2 I don't need when I figure it out...I even bought the Apto stem tool from them, reasonably priced.... but $20 shipping for that small tool in a 6"x9" padded envelope just to go from one side of the USA to the other was ridiculous. (but I thought I needed it :/)
Is it this stem? 3T Apto Pro Stem 2018 I just bought one from CRC for low money. It is marked for 5 Nm torque, but I didn't use a torque wrench, went by feel.
If you bought three stems, can you not just use another faceplate and write off one of the stems?
BTW, I bought this inexpensive stem from Amazon for $11 (it was a return), worked just fine.
Good luck.
Quoted: 859 Post(s)
Liked 1,096 Times
Try your LBS to see if they can order the faceplate and skip the shipping costs. Looks like retail is around $15 so worth a try. I noticed they give instructions to start the bolts with a ball end wrench and then you need the socket extension to get a straight shot with a torque wrench. Seems like a bunch of extra faff for clamping your bars. I'd trade them in for something else.
Quoted: 942 Post(s)
Liked 527 Times
Are we talking about stripping the head or the threads? If the head, yeah then angle and proper tool bit play a role. If threads then we are talking about why it stripped at 5.3Nm torque.
Quoted: 1955 Post(s)
Liked 2,200 Times
Have you tried Amazon UK?
I needed to buy something that was from the UK and the shipping cost was nuts. The same item was on Amazon UK without the high shipping cost.
Because of that, I decided called up the UK supplier and was able to get the shipping down to a reasonable amount.
I forget what they called it, but it was for small items being shipped overseas.
John
John
Not sure what you mean about shipping across the country. CRC is in the UK. Unless you are too!
Chain Reaction is in the UK, but if you spend $100usd+ they ship free even all the way out here in Cali. Usually fast through DHL as well, <5 days on average. (over the 4 or 5 orders I have made in the last few years anyway.)
No I got the team variant. (next step up from the pro)
Because the bolts thread into the faceplate from the stem body side, it's hard to get a hex wrench into the bolt head, so I can see the danger of cross-threading and then stripping.
Good luck.
Good luck.
That's the 3T Apto torque wrench adaptor and 4mm 1/4" drive alternative. (1/4" socket with 5" or 6" extension and screwdriver handle) before either one is used, the bolt has been started if not snugged up.
John
John
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
The best way to kill click torque wrench accuracy is to leave it set on a weight. They should always be returned to zero after use. Some have a marking called rest instead of zero..
Likes For Bill in VA:
