Carbon seatpost install questions.
Bikes: 2014 Fuji Traverse 1.3, 2020 Electra Cruiser 1, 1995 Giant CFM-4
Liked 51 Times
I just got a new Niner RDO carbon seatpost and am installing it on my Fuji Traverse. Should I get some carbon paste? I’ve been reading that it’s a good idea to avoid slippage later? What’s a good brand? I saw some reports that the Park Tool paste may be too gritty and scratch? Also, am I OK with any steel/aluminum collar/clamp as long as I tighten it to spec?
Thanks for any input.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Liked 1,014 Times
Liked 51 Times
Thanks for the input,
I’ll pick some up. Thinking about this Finish Line:
https://www.amazon.com/dp/B0012RIEM6...ing=UTF8&psc=1
Likes For blacknbluebikes:
The dropped
Liked 1,014 Times
Likes For Unca_Sam:
Clark W. Griswold
Liked 4,234 Times
I use paste personally whenever coming across carbon but that is me. Park Tool is probably fine but I believe in past uses I used Fiber Grip from Finish Line. Make sure to use a good torque wrench most importantly.
Likes For veganbikes:
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Liked 621 Times
Terrible advice. Use paste. Carbon will slip. Also, random torque specs from the internet are dangerous...too loose, too tight, probably not right....torque to the manufacturers spec. Always.
Likes For Badger6:
Liked 51 Times
Thanks again for the great input everyone,
Do I just apply a light coat of carbon paste inside the seat tube about an inch or so in before I slide the seatpost in?
Likes For MrWasabi:
Method to My Madness
Liked 1,574 Times
Likes For SoSmellyAir:
Liked 621 Times
So to you good madam or sir, a tip of the hat and a glass raised to you, because you aren't wasting time with paste and a torque wrench.
Again, OP, use paste and follow the recommended torque specs. We aren't all this lucky.
Liked 3,992 Times
Not mentioned is the galvanic corrosion aspects of carbon posts in many frame materials. Some sort of assembly coating (paste, grease, anti seize) to make removal possible after a year of neglect is strongly suggested. As to tightening torque- I've been told by a number of people smarter then I am that the torque specs for bike parts are generally the MAX and not the MUST DO levels. If a bit less then the listed spec works, the post stays put in use, then there's no reason to max the tightness out (and some why less but good enough can be better). Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Advocatus Diaboli
Liked 1,558 Times
