Is my Garmin dying?
Quoted: 1811 Post(s)
Liked 1,335 Times
Is my Garmin dying?
I have an Edge 200. Basic, but all I really need. Actually, I have two. One I bought 5 yrs ago and this one about 1-2 yrs ago. Anyway, it has worked fine until about two weeks ago. Here's the problem....if I am climbing on a steep climb and get near 5 mph, it will read 0.0 mph and go on Pause. I've also seen it read 10 mph when I'm around 20 mph. Has anyone had this happen. Is it time to just bin it?
Pizzaiolo Americano
Likes For Pizzaiolo Americano:
Quoted: 18883 Post(s)
Liked 10,646 Times
Sounds like gps glitches. Sometimes those have nothing to do with the unit. If it happens a lot, maybe.
Don't bin it, call Garmin, see if they can do anything, maybe they'll replace it cheap and you'll have a present for a cyclist in your life. 🙂
Likes For Seattle Forrest:
Are you using a wheel speed sensor with the one that's acting up, or both of them? If so, it may be helpful to either swap the wheel speed sensors or disable the sensor in the Edge to try and isolate the problem.
Bikes: 2022 Salsa Beargrease, 2020 Seven Evergreen, 2019 Honey Allroads Ti, 2018 Seven Redsky XX, 2017 Trek Boon 7, 2014 Trek 520, 2006 Gary Fisher Montare
Quoted: 697 Post(s)
Liked 911 Times
I’ve had this happen with my Edge 500 on a regular basis. IIRC it happened irregardless of cloud cover/tree cover or line of site to the sky. I “fixed” it by “upgrading” to using the wheel sensor. I haven’t had this problem with any of my Edges before or after my 500.
Quoted: 6364 Post(s)
Liked 4,961 Times
As someone else mentioned, check what your auto-pause is set to. With my Garmin Edge 500 I used to have it autopause ever so briefly when I was doing 20 mph plus. That was when auto-pause was set to zero mph. For whatever reason, setting auto-pause to when <3 mph solved my issue and it never happened again in the subsequent 10 years of use.
Sounds like an autopause issue + GPS reception. Anyway, you'll *never* get reliable speed measurement without a sensor, so if you are really interested in your correct speed, you'll need to get one.
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
Check if Garmin has a firmware update available. My ancient eTrex Vista was acting funky for a long time (random time/date display, difficulty locking into satellites, etc.) and it got so annoying I stopped using it for a long time. Then I thought to check for firmware update; sure enough, there was one only a couple years old. I installed that, and the unit has been working well since then.
