9 speed to single conversion help needed.
I just bought a 1987 Trek 560 Pro series and want to turn it into a single speed. I have a nice set of racing wheels with 9 speed Shimano cassette. I started looking at conversion kits with spacers on Amazon but every one I looked at has quite a few horrible reviews. I was hoping you guys would recommend a kit with spacers to get me going. I have already put a few miles on it using just my small front ring and my 18 tooth cog on the rear, so I think the gearing will work for me. I actually don't even need a single cog freewheel if I could get enough good spacers to just pull a single from a cassette and get it lined up. Whichever way you guys recommend.
I'm trying to get into it cheap. I only have $100 in it at the moment. It's a nice frame and will make a bike barely over 20 lbs after I drop a few parts. I'm not doing a fixie.
I am potato.
Liked 1,728 Times
Be careful of the Amazo reviews. Most of the time it is operator error or ignorance. Sort of like the reviews of the latest non-stick pans blaming the pan as the reason the posters eggs got burnt.
All you really need is a random cog & a bunch of spacers. Maybe a locknut tool & a chainwhip. Maybe a bit of math for chainline & a gear calculator for a sensible ratio selection.
An Origin8 conversion is probably the easiest shortcut to success.
I suggest riding your cassette for a while to see which cogs you find yourself in the most. You might even disconnect the cable & make the gear selection by way of adjusting the lower limit screw to drive the derraileur to the cog you are experimenting with. Then use that knowledge to buy a proper single speed cog.
Car dependency is a tax.
Thanks. Yes, I can remove the cassette. I don't think I will need a tensioner. The bike has horizontal dropouts. I know what you mean about reviews. I was just thinking you guys could recommend a quality set of spacers or some of the better quality conversion kits. The Origin8 looks fine but I was hoping to get out for closer to $20 than $90. I know I'm cheap but for me that's sort of the point for this single.
Surly's SS conversion kit is only $40.00 and is solid.
Likes For TugaDude:
I recently converted to a SS using this $20 package on Amz:
The 63cm Paramount dropped over 4 lbs by stripping everything not needed. What fun it is to ride here in FL. Oh yeah, got some new platform pedals for $22 also. Total conversion cost - $50.
I've since replaced the Brooks with a lite racing saddle I had and swapped the wheels for a much lighter pair. It really is a "new" bike now.
CyclingDeal Conversion Kit
Also bought a set of single chainring bolts for $7.The 63cm Paramount dropped over 4 lbs by stripping everything not needed. What fun it is to ride here in FL. Oh yeah, got some new platform pedals for $22 also. Total conversion cost - $50.
One thing I just thought about is that I don't know how well my original Biopace oval front ring will work. Will it cause uneven chain tension? If so, I may need a tensioner or another ring.
Glad to hear you dropped 4 lbs. That would put me well under 20lbs. Not bad for $100 considering the price of a new steel single under 20lbs.
I am potato.
Liked 1,728 Times
Thanks. I'll need some shorter bolts as well. Thought about using washers but won't for $7.
One thing I just thought about is that I don't know how well my original Biopace oval front ring will work. Will it cause uneven chain tension? If so, I may need a tensioner or another ring..
I run a 50 tooth AbsoluteBlack oval on my Rohloff. Never dropped a chain once since I dialed the chain line; And it's not even a "narrow/wide" Biopace are even rounder than AB.
You may find it helpful to clock the ring one increment about the spider to better mimic the AbsoluteBlack ring. Shimano got it the theory backwards & as such clocked the lobes 90 degrees out of phase. This mistake bungled the adoption of the technology for many years to come.
Setting the proper tension can be a bit finnicky, but you'll be fine.
Habitual User
Liked 8,470 Times
I did a singlespeed conversion of my old Trek MTB recently.
![](https://i.imgur.com/YOmGGg7.jpg)
I'm using this spacer kit... www.amazon.com/gp/product/B0037UD4T4
And this cog... www.amazon.com/gp/product/B01J0BQCT2
Both work great. However, there are cheaper options available. My first setup was with spacers pulled from old cassettes that I have in my box o' parts.
For a SS setup, it is generally recommended to use non-ramped cogs and rings. The cogs and rings of geared bikes are designed for the chain to shift. That's the last thing you want those parts to be trying to do on a SS. As has been mentioned, dialing in your chain line is also important.
Likes For TugaDude:
Veteran Racer
Bikes: 32 frames + 80 wheels
Liked 766 Times
Don't mean to troll your thread but this got me thinking. I have an '86 yellow/white 560 frameset myself collecting dust. The main thing I don't like about conversions is the empty derailleur hanger hole and all the braze ons hanging off unused, it's never looked right to me. But looking at my frame I see that the only thing that would go unused are the downtube shifter mounts and derailleur hanger. It's a perfect candidate for a conversion.
All I would need to make it look right to me is a cable tensioner in the derailleur hanger and these shifter boss covers. Isn't there something you can buy to keep the q/r hub from slipping out of the dropout? I have a spare tubular wheelset with Ultegra 6700 hubs.
![](https://cdn.bike24.net/i/mb/07/a8/d9/80004-01-c-128945.jpg)
![](https://i.postimg.cc/nhwtPmF9/20191224-120017ccdf.jpg)
My thanks to everyone.
Veteran Racer
Liked 766 Times
Anyway, what you need is a good internal cam all steel quick release, preferably with serrations, that is capable of applying sufficient clamping force to prevent the wheel from slipping in the dropout. This is what was used for decades before road frames switched from horizontal to vertical rear dropouts. Look for vintage Campy or Shimano quick releases from the 1970s or 1980s. Newer quick releases are external cam with alloy nuts that can strip, and are intended for vertical dropouts only, where much less clamping force is required.
Also, looking at that frame, those dropouts are extremely short offering very little chain slack adjustability. For sure you will need to lose the adjuster screws to get any adjustability at all.
What, Me Worry? - Alfred E. Neuman
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Liked 234 Times
You honestly don't 'need' anything to do the conversion - all you need to do is select the cog and chainring you wish to use based on what ratio you prefer, then disassemble the cassette, set the desired 'drive cog' aside, and use the remaining spacers and cogs as spacers to get the drive cog in the right location to have perfect chainline with the inside ring on the crankset. You can put either the big or the small ring on the inside of the crank, and use the other ring as a spacer so you can use the long chainring bolts.
The only step left is to shorten the chain.
This is likely the ugliest way to do it.
Improvements can be made as you go - for instance, get a set of short 'single speed' chainring bolts so you can ditch the chainring you aren't using.
Also, if you can find a handful of cassette spacers (from a friend who works in a shop or from your own collection of used cassettes) you can assemble a stack that will take the place of the parts of the disassembled cassette.
Not a stupid question at all, but I don't have a definitive answer. The main thing you need for a simple single speed conversion is a frame with horizontal dropouts so the rear axle can be positioned to affect chain tension. Most modern bikes have vertical dropouts so it is impossible to slide the rear wheel fore and aft to adjust chain tension. I think the Trek 800 has vertical dropouts so you need some other method to tension the chain. The easiest chain tensioner is to just use a rear derailleur. You can use the limit screws, or use a very short segment of derailleur cable to hold the derailleur in position so it is perfectly lined up with the cog, which should also be perfectly lined up with the chainring you are using in the front.
The Trek 800 changed over the years quite a bit. Some of the more recent ones had vertical dropouts and I would say are not very good candidates. Best bet is to post a picture of your bike which shows the rear dropouts. I've done several conversions and have been satisfied with them, but not every bike is well suited. There are always "work-arounds" like eccentric bottom brackets, tensioners, etc., but those are best avoided if possible.
Likes For TugaDude:
thanks folks. very helpful. i'll check the dropouts today
