Ultegra hydraulic brake pad lifetime
Old 08-26-21, 08:34 PM
kirbyx
Quoted: 32 Post(s)
Liked 20 Times in 12 Posts
Hi... I'm relatively new to hydraulic brakes. I've worn out two sets of resin front brake pads... it took about 2500 miles to wear out each set. Rear pads are about half worn.
My rides are generally 40 miles with about 3000 feet of downhill with the occasional long steep descent.
Is this normal wear?
Thank you!
kirbyx is offline
Old 08-26-21, 08:41 PM
Cyclist0108
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times in 1,164 Posts
That's my experience. In fact, I wear mine out in fewer miles.
Cyclist0108 is offline
Old 08-26-21, 09:25 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
They will last anywhere from 1 hour to a year or more. Just depends. Your wear sounds about 'average' if there is such a thing.
cxwrench is offline
Likes For cxwrench:
Old 08-26-21, 09:49 PM
Oso Polar
Bikes: Trek 3500, Jamis Renegade Escapade
Quoted: 176 Post(s)
Liked 51 Times in 43 Posts
I get very similar mileage. And yes, rear pads last much longer - about 4-5 times longer than front ones.
Oso Polar is offline
Old 08-27-21, 01:42 AM
Badger6
Obsessed with Eddington
Badger6's Avatar
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times in 368 Posts
Unless you are in the habit of using the brakes on both ends, and you ride a lot in wet conditions.
OP, your mileage is pretty normal. Depending on how much riding you do, in the current parts scarcity time, keep a few sets in reserve.
Badger6 is offline
Old 08-27-21, 09:26 AM
cxwrench
cxwrench's Avatar
Bikes: lots
They should last longer but that is not always the case. I'd venture a guess that I see a lot more bikes than you do and the majority wear the rears faster than the fronts probably 2:1 because a LOT of people are too scared or stupid to use the front brake properly.
cxwrench is offline
Likes For cxwrench:
Old 08-29-21, 11:12 AM
Cyclist0108
Occam's Rotor
Unless you are my wife.
