Need help identify this 2 red nuts...
Ned help to identify what this is?
Looks to me some kind of holder for removable pedals, if it is, where can I find one? I've a removable pedals order on the way, need to find ways to attach it when folded. Thanks.
Hello
Here is the MKS style removable pedal holder I mounted on a Brompton I recently sold. The holder did come with an insert washer so that it could be mounted on a smaller diameter bolt (5 mm?)
It was purchased here: https://www.aliexpress.com/item/3283...62d64c4dSLdrMV
Likes For zebede:
Quoted: 992 Post(s)
Liked 589 Times
Depending on your bike and how it folds, you may only need to remove and stash one pedal. I took both pedals off for a long time before I realized that only the right side pedal needs to be removed.
I have a front rack and the strapless toe clip on the pedal can be hung over the rack. Mission accomplished!
Now 'days I only store the right side pedal on the rack.
Likes For sweeks:
yes I also plan to add a toe clip + straps on the removable pedals too, coming from the old school roadie, this is what we used to rode back in the 70-80's time before clipless. Will see how the pedal holder works with the toeclip/straps when all are put together.
