Would You Buy This Bianchi Sport for $50?
So I see the dimple in the top tube and I realize I'll have to watch it but if it is otherwise as advertised I was going to get it. I figure the parts are worth at least $50 right?
https://www.facebook.com/marketplace/item/570800877577491/
Quoted: 5907 Post(s)
Liked 3,541 Times
That's a heck of a dimple. The parts are nothing to write home about even at $50. If you really need them for a project, this can be OK if the parts check out.
Likes For bikemig:
I agree. I'm on the fence. I wonder how frequently people have had steel frames just suddenly collapse or have bike wrecks from this. I think I'm going to go for it. Maybe I can get 4-500 miles out if it before it happens.
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,125 Times
If you want a cruiser on a budget, sure, its worth $50. This would be a case where im not sure its worth the time to part it out for sale , but spending a few hours on washing out the brown crystallized grease from the bearing surfaces and freshening them up, plus giving the beast a thorough cleaning would yield big dividends for a rider - budget a bit for tires and bar wrap and you may still get out the door with a capable cruiser for $100 or so
I'm riding with gloves tomorrow so I wonder if I can hold off on the tape for now
What's a good tape? Does it come with adhesive on it or do I need glue?
Liked 1,125 Times
Makes sense. I occasionally ride with some older folks...11-12 mph pace, 30 miles or so. I'm wondering if I could use this for that? Tires are actually new but I agree it could use some sprucing up.
Even with gloves, those metal bars would likely be pretty slick by themselves, i personally wouldnt ride it much without some sort of wrap, --- but im sure its been done before
Quoted: 801 Post(s)
Liked 1,830 Times
I think it's worth more than the asking price and should make a nice rider. While cosmetically bad I would worry about the frame failing it is very rare for even badly damaged quality lugged steel frames to fail suddenly. If it has good new tires there basically worth the asking price right now so I would say it is a good buy at this price.
Quoted: 3466 Post(s)
Liked 2,839 Times
To me, it looks like the top tube dent also bowed the tube. if so, then the frame alignment will be off. Rideable, but off.
Quoted: 1005 Post(s)
Liked 1,686 Times
Buy it...
Its steel, that dimple is no big deal and frame alignment can be fixed. And speaking as a guy who has empty parts bin's this bike could be a filler. Those stem shifters are worth half the cost of the bike. I straitened out a top tube dent almost like this one. A friends ladder fell on it. It was not hard. We took some C clamps and 2x4s and levered it straight hopping the frame would maintain its alignments and it did. Then it was just a matter of light bondo and spray paint.
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,574 Times
Next time, could you edit out the black bars from your cellphone picture? That would save us some scrolling and let you post a bigger shot of the bike itself.
Bikes: A few too many
Quoted: 1367 Post(s)
Liked 2,188 Times
If the damage does not bother you and it rides ok then buy it and enjoy it......as others have said the frame will not explode suddenly.....it will take a lot to cause a metal frame to collapse?
Best, Ben
Best, Ben
Voltaire
Voltaire
Likes For xiaoman1:
Quoted: 1109 Post(s)
Liked 1,828 Times
My answer is "no". that 50 bucks might the 50 bucks it takes to close a deal on a bike that isn't in such poor condition. But that's me, I'd rather buy "condtion" than create it with money and labor after the aquistion.
Could you elaborate on what you mean by "poor condition?". I'm not arguing I'm just trying to learn to see what an experienced person sees. It's dirty and the handlebars need tape, and the dent. But what else?
Liked 1,828 Times
Probably needs tires and tubes. Dry rot or tread wear is an automatic replacement item for me. Dentist bills are high these days and front flats at speed can possibly send you to one.
It needs brake hoods. Not just a comfort item, they're a safety item as the hoods are a postion I ride in a lot.
It needs handlebar tape.
It could need:
Tubes
Rim tape
A chain
Freewheel
Every bearing to be cleaned and re-lubed . Hubs, BB, headset and RD pulleys.
Brake pads
If the rims are shedding aluminum, it'll need a wheel re-build(s)
For me, the saddle would have to go
and...........it has a good dent in the top tube. That 50 buck bike can wind up costing 150 bucks (or more) and it'll still be a low end bike with stem shifters and a damaged frame. I presume you live in the United States where people buy things with the best of intentions, then quit and hang them in the garage when they find out there's some actual work involved with making the thing go down the road. There's just too many used bikes for sale that are better in every way to settle on this one.
All of that said, you seem set on the bike. Buy it and learn all this the way I did many decades ago. Educations cost money because they're mostly worth it.
Based on the overall condition I see in the photo that would lead me to believe:
It could need:
Tubes
Rim tape
A chain
Freewheel
Brake pads
It could need:
Tubes
Rim tape
A chain
Freewheel
Brake pads
You actually seemed like you had some good points until the bigoted, xenophobic America-bashing started.
Liked 1,828 Times
Good luck with your 50 buck bike.
Likes For nomadmax:
Expired Member
Quoted: 3782 Post(s)
Liked 5,769 Times
Folks are pulling your leg, that's way more than a "dimple." Use your $50 for the bar tape and handlebar you need for the other bike.
Likes For shelbyfv:
Liked 1,125 Times
It could need:
Tubes
Rim tape
A chain
Freewheel
Brake pads
It could need:
Tubes
Rim tape
A chain
Freewheel
Brake pads
Very good points
Likes For DMC707:
. . . people buy things with the best of intentions, then quit and hang them in the garage when they find out there's some actual work involved with making the thing go down the road. . . .
I'd consider buying this bike. It's uglier than the bike I use as my city runabout (and is even less likely to appeal to thieves), it looks rather more comfortable, and its gearing makes it palatable for city use. (Of course, your city's topography may be very different from mine.) If it turned out to demand too much work (seized seatpost, etc), then legally disposing of it would add a lot to its price, but I'd take the risk.
Likes For microcord:
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1107 Post(s)
Liked 2,208 Times
Let’s calm down some. No one is making bigoted, xenophobic, or American bashing posts. The posts are just giving honest feedback on a potential bike purchase. The nice thing about forums lik this is feedback can be taken or ignored.
Liked 3,541 Times
That's seriously over the top. This is a pretty easy going forum. If you find a remark you don't like, just move on. So I'll tell you something about America you might not like. We should all spend less time getting offended by other people's statements and spend more time riding bikes, hanging out with family, or whatever the heck makes you happy. We have too many snowflakes in the US of A.
Likes For bikemig:
Bikes: a bunch of stuff partial list its becoming a disease 69 Drake 3 spd 87Lotus elan 75, Atala 1988 corsa professionista, Matsuri track kieran bike 1972 astra tour de france
Quoted: 12 Post(s)
Geez I cant get a pizza and a 6 of beer for 50 buy it.
Quoted: 12 Post(s)
Besides if they ask 50 I offer 25 and if they say 40 its 30 and a handshake. This way I have more money in the pocket and with a little elbow grease and patient manipulation that dimple dent or whatever we call it can be straightened out. Part of being part of this community is the comraderies gained in a project because everyone will chip in with helpful suggestions and encouragement.
