Thickest, stuckest seat post
Bikes: Lots of Schwinns
Quoted: 109 Post(s)
Liked 250 Times
so, the find of the day turns out to have the thickest and very stuck seat post I have encountered. To make matters worse, is about 6-7 inches into the seat tube. This Reynolds 531 frame may not make it...
First I started with Drano, no luck. Then I cut it off and had planned to cut it out and discovered just how thick the side walls are...
I have read the lye ideas, prob not something I would want to try. Mostly interested in cutting it out, but I don't think my sawzall blade will fit. Maybe bore it out with a drill first? other ideas?
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3285 Post(s)
Liked 1,899 Times
Wow.
Awaiting constructive replies.
Bianchi Goddess
Quoted: 2957 Post(s)
Liked 3,026 Times
If you have big bits I’d try and drill it out.
Sugar "Kane" Kowalczyk
Quoted: 840 Post(s)
Liked 2,209 Times
Wowza, that is a thick post. I’m not an experienced stuck post remover, just throwing out my 2 cents. That said, I would think about using that thickness to my advantage. Perhaps drill through the side of the post and insert a steel rod through the post to gain some leverage. Trying to cut out that thick post seems like a nightmare. Good luck!
-Randy
'72 Cilo Pacer • '72 Peugeot PX10 • '73 Speedwell Ti • '74 Nishiki Competition • '74 Peugeot UE-8 • '86 Look Equipe 753 • '86 Look KG86 • '89 Parkpre Team Road • '90 Parkpre Team MTB • '90 Merlin Ti
Avatar photo courtesy of jeffveloart.com, contact: contact: jeffnil8 (at) gmail.com.
-Randy
Quoted: 1088 Post(s)
Liked 1,207 Times
Folks are always suggesting extreme heat, then letting it cool to break the bond. Maybe a blowtorch down the middle of the post? I have ZERO experience with this, so grain of salt, at your own risk, and all that.
Phyllo-buster
Quoted: 2299 Post(s)
Liked 2,062 Times
I just went through this with a Rocky Mountain Fusion. Long post slammed down solid. It took 6 days with multiple applications of strong lye solutions thru the BB to win the war and melt the post. The paint suffered terribly although mild caustic soda won't usually damage quality paint. It's nasty and I won't do it again unless it's a truly special frame. That sounds odd but I would refine the process to not damage frame.
I used hardware lye crystals in 1 litre Mason jars, about 6 tablespoons per jar. Wear protection!
edit. Gotta say, there's an idiot on Youtube who has to be the poster boy for how not to try this. Shorts, T-shirt, shaking a pepsi bottle full of caustic soda. 'Only burns a little' he said, dodging the boiling magma. Unreal.
Quoted: 3035 Post(s)
Liked 3,923 Times
Likes For iab:
mycocyclist
Quoted: 914 Post(s)
Liked 855 Times
I have read the lye ideas, prob not something I would want to try. ...
As you have already started down that path,
And destroyed the seat post,
Give the seat tube a thorough bath.
Lye will wash your troubles away, given time.
Likes For machinist42:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,332 Times
I'd assume the previous owner was a clydesdale. As thick as that is, I would drill and tap it to accept a slide hammer fashioned from all-thread and a hefty piece of metal. But I have access to large taps and drills and I understand someone may not want to make that investment. If it is mushroomed up enough you aren't worried it will fall down inside the seat tube, I'd try to break the bond with a good rap from a hammer.
Likes For Chuck M:
Quoted: 109 Post(s)
Liked 250 Times
thanks all for the replies. I have a 3/4 wood spade bit, it does drill into the Aluminum but it wont make the 7 " trip. I also have a couple hack saw blades and while it will be a long job, they appear to have potential to do the job by hand...
also ordered a 3/4" boring bit some skinnier saws all blades with hopes of fitting in there to cut it out, if that doesnt work - lye it is. but this project may get pushed to the back of the stash if it comes to that...
Phyllo-buster
Liked 2,062 Times
I get it but I think it's easier to destroy a frame with a cutting tool than lye. Not that it's the best 'solution'. nyuk.
Likes For clubman:
Bianchi Goddess
Liked 3,026 Times
Can you tell if the post walls get thinner?
mycocyclist
Quoted: 914 Post(s)
Liked 855 Times
Quoted: 109 Post(s)
Liked 250 Times
oh for sure. its thinner about an inch in, but I dont think I can drill all they way down with what I have. I have my eye on this close quarter hack saw hand tool too. One way or another, that sucker is coming out!
I do plan to blast/powder so not that concerned about the paint - so Lye will be the next try
Passista
Quoted: 885 Post(s)
Liked 747 Times
I'd be careful with such a thick seatpost - too much twisting force could ruin the frame.
Likes For Reynolds:
Quoted: 1154 Post(s)
Liked 1,813 Times
For where you are in the process I would use some PB Blaster and longer sawzall blades and go cut down the center on opposite sides. I would use the power tool, I would have your frame secured on a table or bikestand so that you can easily see your angle of cut. I also have fashioned a slide hammer out of threaded rod a couple of nuts with washer various sockets, to help tap out.
I've done a few, I did buzz a hole in my first attempt, all since have been extracted with no damages.
Likes For Mr. 66:
Quoted: 109 Post(s)
Liked 250 Times
nevermind, I see your saws all and blades - thanks for sharing!
Bikes: 48 Alleluia, 52 Blondin, 57 Cattaneo, 68 CNC, 55 Dujay, 46 Herse, 76 Singer, 48 LeGreves, 55 Metropole, 62 Holdsworth Cyclone, 49 Carpenter, 55 Condor, 65 Masi Special, 81 Sequoia, 76 Eisentraut, 72 Proteus, 60 Paramount, 77 Trek TX700, 82 Ross
Quoted: 79 Post(s)
Liked 137 Times
I recently drilled out a thick frozen stem using a hand drill, step bit and extension. This required the stem to be cut off fairly close to the top of the steerer tube. It worked very well, although it's slow and requires cutting oil to resist galling and jamming. Assuming the original hole is centered in the post, the step bit will follow this hole very well and leave you with a thin tube that can be be collapsed by driving a thin screwdriver down the side. The trick might be to come up with a step bit with a suitable maximum size. For the stem, I used a 7/8" bit with the largest step ground off, reducing the maximum size to 13/16 or 20.6mm. For a seat post you would need a 1" step drill, and this size seems to be uncommon.
Likes For WaveyGravey:
Quoted: 915 Post(s)
Liked 516 Times
2) Make sure your seat post is the right size (slides in and out without zig zag twisting)
3) Use a light coating of grease or anti seize.
4) And most important of all, take it out once in a while to clean and re grease. This includes quill stems.
Likes For FBOATSB:
Quoted: 109 Post(s)
Liked 250 Times
Not lost wanderer.
Quoted: 890 Post(s)
Liked 1,025 Times
I had to do this with my Zunow.
Found a 22mm drill bit at a local shop.
Likes For bwilli88:
Quoted: 2592 Post(s)
Liked 3,118 Times
For future reference for others who might encounter stuck seatposts:
When we used to run into that problem at the bike shop where I worked, we'd take the bike to the auto repair shop next door, where a mechanic would use a pneumatic hammer on the underside of the seat clamp. The seatpost would pop out in a few seconds with no damage to the frame.
Odd that I've never seen this suggestion in any of the stuck seatpost threads I've come across here.
Likes For Trakhak:
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 811 Times
Seems like a good method as long as the starter hole is centered. I had a bike shop remove a stuck post years ago. While they got it out and only charged me $100(3+ hours they futzed with it), someone used a sawzall at some point and sliced a small (3/8ths inch) slit-hole in the seat tube. Small, but definitely there once the paint chipped off enough to see it. No idea if they knew they did it. It wasn't visible initially as it didn't come through the paint. Ended up giving the bike(a very nice bike..) to the son of a good friend. An added "decal" electrical tape pinstripe around the seat tube and good to go. He's 26 and starting an adult cycling habit. He loves the bike..so did I..
