Goose Down Shoe Covers
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Not that I've ever seen...sounds like a terrible idea.
Likes For cxwrench:
Quoted: 18596 Post(s)
Liked 16,092 Times
I’ll bite…
You’d need a really good outer shell because down sucks when wet. Or maybe have a built in oil dispenser.
Likes For indyfabz:
i made a pair out of a down jacket someone put out on the curb.
for cold and dry weather only. and SPD pedals. i have shoe covers for rain already.
just wanted something good for the low 30's.
i did a search but found no commercial version out there..
just wanted to know if i am the only one riding theses things.
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
They have over-booties for hunters. But they are not meant to be pedaled in…
Quoted: 377 Post(s)
Liked 446 Times
Why? I mean, if you've already gone to the trouble and it works for you, then great. But as a solution for the rest of us?
3mm neoprene booties are good down to the teens, °F. Below that, slip chemical hand warmers on top of the toe of your shoe and under the bootie, that's worked for me down to single digits °F. If that didn't do the trick, I'd probably switch to Sorrel boots with flats. Or, more likely, ride the trainer or go skiing or snowshoeing. (If it's that cold then there's likely snow on the ground, why not do some cross training?)
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,543 Times
Neoprene is fine for the 20s, it should be good for the 30s, too.
Likes For downhillmaster:
Quoted: 2645 Post(s)
Liked 2,001 Times
But I'll bite again. Is this for some rad wide tire arctic expedition, or for an e-bike?
Pennylane Splitter
Bikes: Yes
Quoted: 1878 Post(s)
Liked 1,547 Times
Rather than outside, look inside your shoes. Buy a pair that are a size too big and add another layer of socks - preferably wool or a cold-weather blend of wool & poly.
Likes For skidder:
Quoted: 5234 Post(s)
Liked 3,609 Times
Old fart
Quoted: 3618 Post(s)
Liked 3,457 Times
FWIW, I have a set of old shoe covers for slotted-cleat pedals that have a synthetic down fill:
Likes For JohnDThompson:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 429 Post(s)
Liked 1,022 Times
I've never understood the idea of adding lightweight insulation to the outside of something heavier, when the warmth source is inside the heavier mass. skidder has the better idea in post #10, I think.
Quoted: 4894 Post(s)
Liked 4,064 Times
A classic BF thread! OP asks about an idea that is roundly denounced. A few posts later tells us he's done it and for his riding it works really well. (I was like the first few to respond. Virtually all of my winter riding has been in wet places like southern Michigan, Boston and the PNW but I kept my mouth shut.) The fact that we've learned the OP is doing something that works well for him barely slows the ridicule of his idea.
Likes For 79pmooney:
Quoted: 980 Post(s)
Liked 779 Times
We have learned what again from the OP?
FYI: you didn’t keep your mouth shut
Sunshine
Quoted: 11100 Post(s)
Liked 7,702 Times
I have used the little toe covers and full shoe and ankle covers, depending on temp. The full shoe and ankle covers have brushed fleece and are windproof too, which has always been plenty for me. Once wind is blocked, I am pretty good to go.
Likes For mstateglfr:
Quoted: 4227 Post(s)
Liked 2,491 Times
Likes For wolfchild:
Quoted: 383 Post(s)
Liked 690 Times
As I posted elsewhere. Lenz electric socks. None of the other solutions have worked, I have also used Hotronics. I probably got frostbite years ago and my toes will go painful below about 45 degrees. I've tried inside plastic bags, neoprene, fleece, shells, etc. Double and triple coverings over the lower legs. Getting them on can be like dealing with compression socks. Rechargeable batteries snap on near the top and there's a 3-setting button heat choice or, of course, these days, there's an APP for that.
Just two days ago:
Just two days ago:
Likes For kahn:
Old fart
Liked 3,457 Times
Liked 3,609 Times
Liked 3,609 Times
I have virtually no circulation in my toes. I now use an electric foot warmer in the office. wonder if I have diabetes. anyway, this time of year I resort to adding heat & winter boots. but toe warmers also work in regular shoes if it's not frigid out. just loosen the laces get the foot in & re-adjust the laces
when it's really bad I use hand warmers, (usually w/ less tape than this) hehe
Likes For rumrunn6:
Liked 2,001 Times
All I saw was a planned temperature range (FWIW I handle low 30s easily with thick wool socks) and the "cold and dry weather only" limitation.
Likes For pdlamb:
