What is the smallest chainring that someone has put in their bike?
Quoted: 4035 Post(s)
Liked 7,612 Times
1 tooth.
Likes For tomato coupe:
Quoted: 18451 Post(s)
Liked 4,562 Times
I think 34T is the smallest ring that I've put on any of my bikes. Maybe I went down to a 30T with a 7703 crankset on one bike.
Mountain Tamer may get you down to 16T if you want, although I'm not sure they regularly stock smaller than 18T?.
Mountain Tamer Quad Plus
Advanced Slacker
Quoted: 2769 Post(s)
Liked 2,546 Times
22t as the small ring on an MTB. A friend had a 20t.
That was all a long time ago.
Liked 4,562 Times
This is a good watch.
The guy in the clip uses an idler to create 7.5 gear inches.
I think that would be equivalent to having a 16T front chainring and 56T rear sprocket.
Likes For CliffordK:
Mad bike riding scientist
Quoted: 6284 Post(s)
Liked 4,323 Times
Four of my current bikes have 20 tooth inner rings. I have had 18 tooth inners and a 16 tooth inner with a Quad adapter.
Stuart Black
Stuart Black
Likes For Canker:
Liked 4,562 Times
When I was "car free" a couple of years ago, there were times when I wanted lower gearing, especially for the 2 small hills I have to go over to get home.
I had planned on moving to a trike for more stability, but started driving again.
As the rider in the clip above discovered, one can adjust the weight on the front by the attachment point. So, connect above the axle and it pulls the front wheel off the ground. Connect below the axle and it could push the front wheel down, unweighting the rear. Connecting at the axle level is probably best.
My bike has a shimmy problem on hills, perhaps due to attaching the trailer behind the rear wheel.
Ideally design a 5th wheel configuration on a trike to get trailer weight onto the bike, and at least as far forward as the rear axle.
Our local bike coop built what they call the tri-hauler. It is front wheel drive, with the cyclist's weight above the front wheel. They do tow a heavy trailer with it, but get a lot of weight on the actual trike too. Their machine is also electric assisted.
Enthusiastic Sufferer
Bikes: 2015 Specialized Roubaix, 2014 Salsa Fargo, 2013 Trek Remedy, 2014 Cannondale Synapse
Quoted: 124 Post(s)
Liked 311 Times
I've got a 24/38T set of front chainrings. Works a treat
Guest
Quoted: 1346 Post(s)
Liked 3,271 Times
My 1992 Suntour Microdrive XC Pro build had either a 24T or 26T on the granny chainring.
Cheerfully low end
Quoted: 649 Post(s)
Liked 1,067 Times
My RockHopper had a 42-32-22 175mm triple crank when I got it. I replaced it with just a 42 on an old 170mm SR road crank.
With the chain on the 22 ring it would start to drag on the U-brake when shifted to anything much smaller than the middle rear cog, not that that would serve much real riding purpose.
Otto
Otto
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,452 Times
My homebrewed "K-Mart triple" uses a 22T freewheel cog as the small ring, which gives a 19 inch low when combined with the 34T on the back. This was concocted in '83. Still in use
Likes For thumpism:
Bikes: Trek 5200, Giant Rainier, Devinci Destination,Motobecane CF, Bike Friday family tandem, Bike Friday NWT
Quoted: 15 Post(s)
22 on my touring bike.
OwainGyndwr
Super Modest
Quoted: 11031 Post(s)
Liked 4,755 Times
I had a 26T that I took off of a used bike10-15 years ago. I gave it to a guy who wanted something similar for a trike. He still uses it.
Keep the chain tight!
I had a 20t on my fat bike until I went 1x and switched to a 26t. I don't have much top end, but don't need it.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 337 Times
Along such line, I currently have 18T on my main full-size bike, for 1.24m of development, and in reserve 16T. However, on the main folder I have 20T that yields even lower 1.06m with all the rest I have there. The simple justification is that I take the folder into more challenging places than around home.
