Can you have a dropper post and a suspension seat?
Time Traveler
Bikes: 1983 Ross Paragon
Quoted: 206 Post(s)
Liked 100 Times
Maybe dumb question but can you have both a dropper post and a suspension seat on a mountain bike? Thanks.
Likes For Canker:
Time Traveler
Quoted: 206 Post(s)
Liked 100 Times
The Rinsten spring seat suspension can be installed on dropper post. But I don't think anyone has ever done that.
Also the stock unmodded Rinsten spring is dangerous and inefficient. I had to tie the ends together with steel cable to pre-load it and limit travel. Else it will bounce a lot and make the bike want to throw you off every time you brake.
Stock Rinsten spring:
My mod. The steel cable that holds the ends together preloads and limit spring travel is visible at the rear :
Clark W. Griswold
Quoted: 4449 Post(s)
Liked 4,111 Times
Don't do it, those Rinsten springs are terrible and everyone I have seen on them doesn't like them and they just aren't really safe. Maybe if you are a kid or super light maybe less dangerous but honestly no don't do it. If you have to modify it with bungees and straps and such that don't come with it probably not a great product and certainly not one I would want to add to a dropper as it adds significant height leaving me to get a shorter travel dropper which you might not want.
This is the product you are looking for thanks to Canker for originally posting it! I saw the title and was like PNW, PNW GET THE PNW and then I saw Canker had posted it and I was like good good, someone did it!
Time Traveler
Quoted: 206 Post(s)
Liked 100 Times
Thank you Veg and Canker! That is really sweet!!! How do you trigger the drop is it on a cable?
Likes For BikePower:
OM boy
Bikes: a bunch
Quoted: 545 Post(s)
Liked 688 Times
I've been running a RockShox post on my HT Stumpy for 14+ yrs. Just enough to take the edge off sharp, small hits which jolt you out of the saddle.
Lifting off the saddle, even just a touch, makes continued pedal pressure difficult, especially on a series of small hi ts like holes, large root sections on uphill sharp climb sections.
I have been considering that dropper/suspension post listed above - the PNW Coast.
If you're doing a long ride, which requires getting off the saddle often, doing so just gets 'old' really quickly...
The Rockshox has been perfect, but now having a dropper post seems essential for my rides. Having a dropper + suspension post seems a natural/essential thing for me...
Ride on
Yuri
Ride on
Yuri
Time Traveler
Quoted: 206 Post(s)
Liked 100 Times
The suspension post I want because I need a comfortable ride. Im not a serious mountain biker, I ride mostly urban terrain, curbs, rough roads, gravel, trails. And the dropper is nice for hills on the trails and for standing up or lowering my center of gravity. This is not for the Schwinn by the way its for my MB project.
Bikes: 2014 Avanti Circa (Rd Dist), 2020 Giant Toughroad (Rd Tour), 2021 Trek Allant+ 8S (eCommute), 2021 Scott Aspect 940 (Mt HT), 2014 Santa Cruz Superlight 29er (Mt FS), 2022 Scott Spark 960 (Mt FS)
Quoted: 35 Post(s)
Liked 52 Times
I cannot see why you cannot do both, provided that the seat has its own suspension.
You probably want a shorter seat post than you expect, as I expect seat post insertion depth is going to be your main problem - the link below is for Fox Transfer dropper dimensions, and take note of the collar that will prevent the seat post being lowered any further.
https://www.ridefox.com/dl/bike/tran...ifications.pdf
Are you looking at something like a Brooks Flyer saddle?
https://www.brooksengland.com/en_row/flyer.html
Disco Infiltrator
Quoted: 3133 Post(s)
Liked 2,115 Times
That PNW post looks pretty good except it's pointed at gravel bikes. For 27.2 post diameter you can only get 100mm travel. You'll probably want more travel, and more only comes on bigger diameters. But maybe that's fine, at least you know you won't run out of room.
Cargo bikes sometimes come with droppers now so you can flat foot while loading. I've considered getting one for my wife on her comfort bike. It came with a cheap suspension post and a big sprung saddle too. She likes to flat foot but the low saddle chokes her up when pedaling. If I convert it to 1x I can use the cable routing meant for the FD. Really the only holdup is that I need to do the 1x conversion first and it only comes in black, not polish or satin to match the other components. In fact I sent them an email maybe a year ago asking if they had considered a polished version for just this sort of bike, which is often chrome-polish and not always racy-blackout. But they said no plans
Genesis 49:16-17
Genesis 49:16-17
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
One thing to consider is how much space the suspension will take up between the frame and the saddle. There might not be enough seatpost left exposed to do much "dropping."
Advanced Slacker
Quoted: 2764 Post(s)
Liked 2,540 Times
Clark W. Griswold
Liked 4,111 Times
Yeah, Rinsten is probably not good on dropper unless the seat tube is quite short.
It's unsafe unless you compress the spring together and tie the ends with steel cable because every time you brake, it tilts the saddle forward and up and rear wheels lift off.
I have to admit that product @Canker posted is far better solution even if it costed a lot more.
The PNW Coast is exactly what the OP wanted and is in general a neat idea for hardtails and gravel bikes.
Clark W. Griswold
Liked 4,111 Times
With my own riding it is the tire width and tire pressure that has the most impact when riding. Going tubeless and running with as low a tire pressure as you can get away with would be my approach. There are softer seats but most of these are wide and not great for pedaling distances - more for a city bike.
Time Traveler
Quoted: 206 Post(s)
Liked 100 Times
Bikes: C'dale, Trek, Cervelo and Santana
Likes For Wheels4:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Time Traveler
Quoted: 206 Post(s)
Liked 100 Times
why do racers you high pressure tires 120ps? Why does it feel harder to pedal when I have low air pressure? Why do I get much less mpg fuel economy on my truck when I dont keep the tires inflated to the correct pressure? Im very interested if you can bust this misconception that I have. Thanks.
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
Clark W. Griswold
Liked 4,111 Times
If they are, they are using it for a stage race where they want a certain pressure in their tubulars at a certain point like say on the Paris-Roubiax course when they hit the cobbles. With lightweight tubulars with latex tubes you are likely to lose pressure a bit faster so their mechanics typically have a pumping strategy to get them right on for the cobbles. However yeah it is pretty unlikely anyone is using that high of a pressure at least not outside maybe still at the track but that is a whole different ballgame. No mountain bikers would ever go that high and most mountain bike tires aren't rated for that high anyway. I do always get a chuckle when someone comes in the shop saying yeah I really love my 23s pumped up over 100psi.
Time Traveler
Quoted: 206 Post(s)
Liked 100 Times
why does my bike slow down much faster when coasting if my tire pressure is low and when its normal or higher it coasts longer?
Just to be clear, I understand from your reply to my post that you are convinced that low tire pressure does not increase rolling resistance. Is that accurate?
Disco Infiltrator
Liked 2,115 Times
I don't know why you guys are arguing in a dropper post thread in the MTB sub about road bike tire pressure. A retread, if you will, of a familiar topic. Perhaps you are lost and need directions?
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
