Looking for ideas on repurposing weight bench into Bike repair stand and/or trainer
As the title says, I'm looking for ideas on how to repurposing/upcycle an old bench press stand into a bike repair stand and/or trainer. I have multiple weight benches but I refuse to throw anything out and I'm always looking to repurpose. This is a cheap'o weight bench from the late 80s that has the leg and arm curl option.
Likes For CharlesDennison:
They say you can make a silk purse out of a sow's ear, but I certainly wouldn't try. Your weight bench has everything you don't need in either of your goals. It's too low and long to be a good work stand and it has nothing you'd need to add upright stationary support or resistance to make it a trainer. You'd have better results turning it into a couch potato lounger for binging Nickelodeon
Quoted: 2395 Post(s)
Liked 2,952 Times
I am an build it myself, improvise/recycle/creative guy. I wasted way more money and time trying to make a DIY workstand than buying a good one cost, just buy a good one
IMHO a bike workstand is as important as a good set of hex wrenches. it is the foundation for repairs
as for trainers, look for used, lots of people try and give up
Life is too short not to ride the best bike you have, as much as you can.
Expired Member
Quoted: 3800 Post(s)
Liked 5,800 Times
It's possible someone might want your old weight bench. Try giving it away. It's just some random object. No more a repair stand or trainer in disguise than your lawnmower.
Sr Member on Sr bikes
Yeah, that can be done. I remember seeing a repair stand made from a weight bench many years ago when I lived in Spain, in a little shop a guy ran out of his garage. I can’t recall exactly how it was set up, but just remember thinking how ingenious, simple, and effective it looked.
Dan
Dan
Quoted: 1956 Post(s)
Liked 2,201 Times
Do you weld?
John
John
Space Ghost
Bikes: Bridgestone, Fuji, Iro, Jamis, Gary Fisher, GT, Scott, Specialized and more
Quoted: 292 Post(s)
Liked 412 Times
You can get a cheapie bike repair stand at Aldi and/or Lidl for thirty bucks, even less on clearance.
Likes For Rage:
Quoted: 206 Post(s)
Liked 38 Times
Both Park Tool and Bikehand make heads that you could probably fit onto one of the uprights but I wonder how stable it's going to end up being and I think it would be more clumsy and awkward to use and take up more space than something that's engineered to be a bike repair stand.
I have a Bikehand stand that in my opinion is really well designed - quick and easy to set up and take down, lightweight - I hang it from a rubberized J-hook turned sideways attached to a stud over my tool pegboard.
You think you're going to come up with something as good as this? The weight of the bike hangs over the legs to enhance the stability. You can turn the pedals while on the stand - for cleaning the chain for example, or running through the gears to adjust the shifting mechanism. The head folds down - I hang mine from the rubberized J-hook around the round ring around the back of the head in its folded position, with the legs folded up it takes up very little space. Nice tool tray right there. Someone clearly put some thought into designing this. I actually think it's designed better than the Park stands I've seen.
Btw - it telescopes higher than shown in both these pics.
Likes For MyRedTrek:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Quoted: 574 Post(s)
Liked 616 Times
I am a hopeless mechanical engineer/tinkerer so understand and while I admit I have a Park Tool and a Bontrager repair stand I have a saw horse converted to a European type stand for when I really need to get down on a stuck BB or similar. Have you checked out these:https://www.instructables.com/Homemade-Bike-Stands/
Likes For easyupbug:
Exercise equipment is in short supply right now. Sell the bench, purchase a work stand. Mission accomplished.
Likes For Outrider1:
Method to My Madness
Quoted: 2068 Post(s)
Liked 1,562 Times
Last winter I picked up a similar weight bench for 25 bucks including 50 pounds in weights and a barbell. The cheapo stuff ain't worth much because it is cheap right from the start.
I am a tinkerer and enjoy repurposing into useful items. Post a pic of the bench so we can see what you have to work with.
