Move over carbon fiber
Sr Member on Sr bikes
Michelle Shen
USA TODAY
MIT researchers have developed a new material that’s as strong as steel but as light as plastic.
It can be easily manufactured in large quantities, and the use cases range from lightweight coatings for cars and phones to building blocks for massive structures such as bridges, according to Michael Strano, the Carbon P. Dubbs Professor of Chemical Engineering at MIT and the senior author of a new study.
'We don’t usually think of plastics as being something that you could use to support a building, but with this material, you can enable new things,' he said in a statement from MIT.
The material is several times stronger than bulletproof glass, and the amount of force needed to break it is twice that of steel, despite the fact that the material has only about one-sixth the density of steel, according to MIT.
The researchers were able to do this by developing a new process to form polymers. Plastics are an example of polymers, along with rubber and glass.
The researchers wanted to see whether they could create a two-dimensional version of a polymer that could remain flat, thus making it lightweight. They tried for decades to create such a material, and the new process they developed was published in peer-reviewed journal Nature last week.
Polymers are essentially chains of individual molecules, called monomers, linked together by chemical bonds. Normally, when polymers are formed, they expand into three-dimensional objects, like how a sheet cake rises as it bakes in an oven. The challenge is if even one monomer begins to rotate, the polymer becomes three-dimensional.
For example, imagine if you wanted to line up children and pack a bunch of them in an auditorium by having them link arms. However, if even one of the children choose to be unruly and shift around, it would be impossible to maintain order.
Link to article
Dan
Will be exciting to see industrial applications, for sure!
Shawn of the Dead
Cue the "Steel is Real" folks ; )
Likes For Rdmonster69:
Tragically Ignorant
Liked 9,103 Times
How about cue the "show me a proof of concept bike" at least before comparing it to other materials.
May be be a bit too early to extol the virtues of the "2 Dimensional Version of a Polymer" bike.
BTW, did anyone else suspect this was a joke when they saw the name "Carbon P. Dubbs"? I had to google that:
https://digging-history.com/2016/01/...-riches-story/
Real guy, really funny name.
Likes For livedarklions:
Shawn of the Dead
Tragically Ignorant
Liked 9,103 Times
Well, it is a plastic. That rhymes with spastic and fantastic, so it could go either way.
Drastic and elastic may or may not fit.
According to the article, it's supposed to be cheap, btw.
Liked 3,302 Times
how easy will it be to patch or repair, of it can be?
How much of an impact with UV have on an exposed untreated or non-painted surface?
-YMMV
-YMMV
Likes For Troul:
The “will cost a lot” “will take a while” comments about cycling applications are obvious. It will probably follow a similar development/acceptance/usage that CF did. This is just announcing its discovery. The stuff is still in the lab. The discovery/development of CF goes back about a century or more. Initially used in the aerospace industry in the 1960s. Wasn’t used in cycling (for a frame) until the late 1980s. LeMond won the TdF on a CF frame in 1986. CF frames weren’t widely available until the 2000s (but that was probably because of UCI acceptance of it). Maybe cycling applications with this new stuff might happen sooner. Technology always speeds up.
Dan
Dan
Likes For _ForceD_:
Tragically Ignorant
Liked 9,103 Times
I did note that they described it as useful for a lightweight coating for cars, but also (presumably) load-bearing bridge "building blocks." Anyone versed enough in materials science to recognize anything significant from that seemingly odd pairing?
Tragically Ignorant
Liked 9,103 Times
Dan
Dan
It's interesting but, of course, people have to recognize that we're all just speculating based on almost no knowledge of the material, and absolutely zero knowledge of its compatibility with different production techniques.
For example, I'd love to know if this is useable in 3D printing--that could mean inexpensive bespoke frames.
Comments about frame material through history…
1830s - “My good sir…I can’t believe you’re still riding one of those wooden velocipedes. Steel is real!”
1930s - “I do say…I can’t believe you’re not riding a chromoly frame yet.”
1990s - “Bro, I can’t believe you’re not riding an aluminum frame yet.”
2000s - “Like shouldn’t you be be riding a carbon fiber frame now, dude?’
2040s - “Where’s your plastic polymer bike?”
Likes For _ForceD_:
Liked 2,277 Times
The truth is, a bicycle is one of the more primitive devices out there.
For all the technological advancements in frame materials we are still using a steel chain to steel cogs for the overwhelmingly majority of bikes. Despite all the space age developments, function still revolves around the weakest quick link.
John
John
Likes For 70sSanO:
Palmer
Liked 1,975 Times
Still waiting on nanotubes and Buckyballs.
Likes For tcs:
John
John
Edit: Except for FDs, which are still very primitive contraptions!
Tragically Ignorant
Liked 9,103 Times
Plus the drive train design is an extremely efficient match for the engine, and no one is coming up with a redesign of the engine anytime soon.
There is a driveshaft option to the chain drive. I’d think this (the gears) lasts somewhat longer. Obviously not very popular. — Dan
Disco Infiltrator
Liked 2,150 Times
Disco Infiltrator
Liked 2,150 Times
Steel and concrete are really, really cheap. When this stuff is stronger per dollar then it will be important for anything other than aerospace and sporting goods
Genesis 49:16-17
Genesis 49:16-17
Tragically Ignorant
Liked 9,103 Times
Yeah, there's a long, sad history of failures with the shaft drive concept. Remember CeramicSpeed showing off their shaft drive prototype a couple years ago? They've now spun it off into a new company "Driven" which is now crowd funded. They claim they're planning on having an actual product by 2023, but I'm skeptical..
Newbie racer
I suppose since it's just in the lab we should all pack it in and go back to talking about the same typical Bikeforums troll questions asked the 1000th time or some kind of really Fred topic such as trying to race people on group rides with tt bars. You know, instead of speculate about something new and different for once.
Likes For burnthesheep:
Clark W. Griswold
Liked 4,552 Times
Likes For veganbikes:
Liked 2,277 Times
Liked 3,302 Times
schedule II substances provided a lot of reshaping for the engine, just that its use is frowned upon.
-YMMV
-YMMV
