Scratched dented fender: how to repair
Wife dropped the bike and put a nasty little dent and scratch on the fender. It’s a Townie. Trek does not produce touch-up paint. We live in South Florida.
Momento mori, amor fati.
Likes For am8117:
Droid on a mission
Quoted: 320 Post(s)
Liked 283 Times
Many fender dents can be pushed out using the handle end of a hard plastic screwdriver, working it back and forth from the inside of the fender. As far a touch up paint, we have been very successful mixing a custom col0r with Tester model paints like this set. https://www.hobbylobby.com/Crafts-Ho...s-Model%20Kits
Likes For JoeTBM:
Droid on a mission
Quoted: 320 Post(s)
Liked 283 Times
Adding a 2nd set for more of pastel type colors https://www.hobbylobby.com/Crafts-Ho...Set/p/80800174
Old fart
Quoted: 3616 Post(s)
Liked 3,446 Times
That's one of the nice things about "hammered" fenders; they don't show scratches and dents:
SE Wis
Quoted: 2752 Post(s)
Liked 3,412 Times
Nail polish comes in a multitude of colors for touch up matching
Likes For dedhed:
My bad. Fender is metal.
Quoted: 4231 Post(s)
Liked 3,940 Times
The auto world has had to deal with this for ever. How to match paint and cover boo-boos. With a car that often has body seams and defines creases this goal is not too hard. But with a bike fender that has no surface element that can act as a boarder between new and OEM paint anything less than a complete respray is likely to show the touch up easily. Some decide that applying a decal or sticker, as trashy as it might look, is a better solution that an amateur touch up. Andy
AndrewRStewart
AndrewRStewart
Droid on a mission
Quoted: 320 Post(s)
Liked 283 Times
That is not just a scratch and dent, you need some body work and repaint the entire fender as Andrew R Stewart mentioned - Have you looked into buying a replacement fender? At least it looks like an easy color (battleship grey) to match
Droid on a mission
Quoted: 320 Post(s)
Liked 283 Times
Just did a quick google search https://search.yahoo.com/search?p=Re...%3Asb&ei=UTF-8 and came up with a few possibilities including some ebay sellers
Quoted: 7084 Post(s)
Liked 11,187 Times
Generally bewildered
Quoted: 1152 Post(s)
Liked 342 Times
Anything can be done! But I agree with you if you add "reasonable or cost-effective" betweeen "no" and "fix".
One approach is to reverse the dent with a plastic mallet on a bag of lead shot and once you have tire clearance, just ride it.
Liked 11,187 Times
But I think the OP is interested in aesthetics -- in which case, the only solution is to get new fenders, unless a single replacement can be sourced.
I like the suggestion of a sticker. Maybe some reflective tape, which is nice on a rear fender from a safety standpoint, anyway.
Thanks everybody!
I’m most concerned about corrosion rather than aesthetics. Maybe clean it up as well as possible and put some clear tape on it? I’m planning on doing that to the downtube anyway.
Liked 342 Times
I like Koyote's idea: reflective tape. Will look less like a$$. I'd actually bump it out. bondo amd sand it if you want, prime and paint to match as best you can, with a rattle can.
Quoted: 6319 Post(s)
Liked 4,908 Times
Is the fender steel or aluminum? If aluminum, I wouldn't be too concerned with corrosion. Unless you ride on the beach and into the edge of the salt water. But then, you'd be having other concerns sooner than just a fender corroding.
If it was mine, I'd not worry about anything as long as it functioned and didn't hinder wheel movement. The scratches as horrible as they currently look, eventually won't be noticed so much and will just be character for the bike.
If I had to paint it and make it look pretty, then I'd get some high build sanding primer and spray it on after first lightly sanding and feathering the edges of the scratches. Then sand it down to the original paint leaving the primer in the scratches. Then spray another coat of the high build sanding primer and then sand again, repeating till the scratches don't show in the primer.
Then I'd coat with the closest paint I could find in a spray can. They make spray cans for model airplanes or such and you can also check for spray can touch up paints at the auto parts stores.
SE Wis
Liked 3,412 Times
Quoted: 125 Post(s)
Liked 29 Times
It's also possible to "botch it" by spraying the spot only keeping everything around covered in a plastic sheet or such. Or just let it be. Doubtful the uncovered material will corrode.
EDIT: I would have assumed they are all aluminium but unsure now, it appears some come steel too, would need to know the model:
https://electra.trekbikes.com/us/en_...olorCode=black
Quoted: 858 Post(s)
Liked 1,092 Times
Likes For Crankycrank:
Quoted: 581 Post(s)
Liked 921 Times
Since the damage is right near the bottom edge of the fender, you could consider masking off everything above the damage and sand and paint the damaged area a contrasting or complementary colour. I would also do the other fender to match so it is obviously a feature and not a flaw.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1244 Post(s)
Liked 336 Times
I don't see what's a big deal. Looks like it's steel.
Sand the paint all off to half an inch above. Put something rubber under it and bump the dent out. Primer, paint and done.
Maybe fill the deep scratch first. Maybe paint white for nighttime like they did on old bikes.
Quoted: 18424 Post(s)
Liked 4,544 Times
I'd probably pull the fender off the bike. Then you could work on it with a hammer and dolly, or anvil. Get it as good as you can do.
Wire brush to clean off paint and down into the crevasses.
Then I think you need a sealer and some body filler, the repaint.
It may be difficult to get it perfect, but you might get it close.
An auto paint store should be able to help with paint matching, then make sure you feather the new paint into the old.
Overall, to get it really good will be a big project.
You may be able to get it banged out close, spray on a sealer, then go for the reflective tape.
