Cycling equivalents to running 10km, half, and full marathon.
When I was first getting into running I gave myself a number of targets: sub-40min 10km, sub-90min half marathon, and sub-3hr marathon.
Are there road cycling equivalents to these goals? Not necessarily identical, but are there common distances and associated times people aim for?
I've asked a couple of cycling friends, who are also keen runners, and they were somewhat stumped.
Thanks!
Thanks!
I think time trials are as close as you get with the 40km TT being the most standardized. Aerodynamics make mass start racing quite different between cycling and running.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 276 Post(s)
Liked 461 Times
These are you against your own clock and someone will have to suggest times but I’d say:
40 km
Metric Century
Century
(Could add double century but I’d say that’s getting into the ultra distance events)
All could be done solo or in a group. A group can draft so should be faster. So two time goals may be appropriate.
40 km
Metric Century
Century
Should Be More Popular
Quoted: 22690 Post(s)
Liked 9,037 Times
There are some times I have seen thrown around as goals/benchmarks, but they are really dependent on terrain and group vs solo. So PLEASE take this with a grain of salt...
The two I think of are:
1. A sub-1 hour time for a 40Km/25 mile Time Trial. This is SOLO.
2. A sub-5 hour century (100 miles), typically done with a group.
Likes For datlas:
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 906 Post(s)
Liked 1,949 Times
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Thanks!
Thanks!
So a common duathlon is:
5k, 30k, 5k
Common 1/2 Ironman:
56.2 bike 13.1 run, 13.1 x 4.3 = ~56.2
IMO, that's the best "physiological" equivalent to the demands on the body. But they don't equate to race distances other than in multisport events.
In respect to "race distances", the bike versions are track distances of 3km, 4km, then open road time trial distances of 10mi, 25mi, and in the UK 50mi TT's.
Common "goals" for the bike equivalents are:
-10mi: break 30min, break 25min, break 20min
-25mi: break 60min, break 30mph
Sunshine
Quoted: 11048 Post(s)
Liked 7,595 Times
There is no cycling equivalent to a marathon because I could never run a marathon yet I could ride 100mi, 150mi, or even 200mi if absolutely needed in one go.
Simple as that.
#runningisthedevil
Simple as that.
#runningisthedevil
Likes For mstateglfr:
Quoted: 3260 Post(s)
Liked 2,572 Times
As both a runner and a cyclist, you really can't compare the 2. Maybe if you were strictly riding a single speed. Take the gears away and it becomes a lot harder time/effort wise. The type of terrain on the route is so important. Same for the individual doing the efforts.
Since this will eventually become a pissing contest between running and cycling, here's what I think:
Aerobically, swimming is way harder than the other 2 for me. You have your breathing limited(compared to the other 2) and you're flailing away with all of your body. It's low impact, but requires more effort than the other 2.
Sunshine
Liked 7,595 Times
Also, #swimmingisthedevil
Liked 2,572 Times
That's what I do endurance sports for. Get to the finish and enjoy the day. I am strictly back of pack. Was a good run and jump/fast twitch athlete BITD, but I'm a terrible endurance athlete. Father time and eroding skills push you out of the other sports, and you eventually turn to endurance sports. I actually enjoy it more now because of low expectations. I have to eat humble pie all the time. 2 weekends ago, I ran a half marathon. The leader/winner of the full marathon passed me as I was crossing the finish line! That's always hard on the ego. He was around my height, but probably 60-70 lbs lighter. Even If I was in the best shape I could be in, he'd still be 50 lbs lighter. If you looked at our effort related stats for the runs, I'm guessing they wouldn't be that different except for the heart rate. That's what I tell myself, anyway.
Perceptual Dullard
Quoted: 950 Post(s)
Liked 1,213 Times
Thanks!
Thanks!
A rough rule of thumb is that to run X meters/sec on a firm flat surface takes about X watts/kg. This varies across individuals in their running economy and their gross metabolic efficiency but across individuals it's not bad. Converting watts/kg into cycling speed on a similarly firm flat surface is harder because, unlike running, the relationship between speed and power isn't linear (it's cubic, roughly).
Here are some splits from a 3-55-15 duathlon. Note in particular that the correlation between 3k run and 15k is 0.88, so the correlation between the runs and the cycling leg of ~0.77 isn't bad. The point here is that you can make an estimate of 10k running time and relate that to something like 40k cycling time over a sample of athletes who do both activities.
Liked 3,081 Times
imo, an equivalent to a runner's target might be a cyclist's power output to time spent. Distance & time targets for a person riding a bicycle has too many environment variables to contend with outside. If you were indoors (trainer, rollers, alike) then the distance with time could become an option to use as a target.
-Oh Hey!
-Oh Hey!
Quoted: 18883 Post(s)
Liked 10,646 Times
The impact on your joints puts running in another world.
The sitting down puts cycling in another world.
Likes For Seattle Forrest:
Quoted: 590 Post(s)
Liked 445 Times
And even in the "sub-5 hr 100mi ride", there's the additional variable of total ascent. Doing a sub-5 in FLA as opposed to in the Northeast US, or Colorado, is a different thing.
Quoted: 3998 Post(s)
Liked 7,490 Times
Likes For tomato coupe:
Newbie racer
Liked 1,569 Times
In other words, making 25w more in the run got you a LOT more time gain than 25w more in the bike.
As to the above, I don't train running "much" compared to bike and I have my run threshold set based on 10k distance at about 7:05/mi. My 40k TT time is a bit under 55min.
I do feel racing a 10k feels more similar to a 40k ride. You feel like you're easing into the pain a lot more than you do for a shorter 5k run or 10mi TT bike. I just detest those distances personally as it's just all teeth grit the whole time. A 40k TT sure does suck longer than a 10mi TT, but you ease into it a lot longer pain wise. Like the "boiling a frog slowly" phrase.
Quoted: 2333 Post(s)
Liked 2,097 Times
Thanks!
Thanks!
A sub 3 hour marathon effort is probably closer to something in between a 9-9 1/2 hour Double and 4 hour Century on easy/moderate terrain on a fast road bike (TT bars). Lance's best NYC Marathon time was 2:46 and there is little doubt he could break 4 hours solo on a century.
I tried to make a similar comparison from cycling to ultra fast distance hiking and ultimately realized it was impossible due to aerodynamics for cycling and the benefit of descending fast without pedaling whereas in mountain hiking, the descent can be more difficult on the body than the ascent and rugged terrain itself slows you down. A 20-25 mile walk on a trail feels like a century ride but 20 miles in difficult terrain with a pack feels worse than a double.
Note: My estimation is based on difficulty and stress on the body....not the physics of time and distance.
https://www.ultracycling.com/individual-records
Perceptual Dullard
Quoted: 950 Post(s)
Liked 1,213 Times
I got into a friendly argument with a guy on Slowtwitch who claimed duathlon 3:1 ratio had to do with equalizing the metabolic costs of run/bike. He claimed to have some kind of link to USAT. I disagreed with him because metabolic cost ignores physics of time gain running being largely linear, and time gain on the bike being very non-linear. You can measure "run power" these days. I found one of the super popular run scientist guy's pace/power calculator and then worked the math out on how long you would need in the bike leg to make time gain/loss on power differences in each pay out fairly. The 3:1 ratio wound up being pretty BS. It took even more than the triathlon 4.3:1 ratio to even out.
Elsewhere I've argued that in terms of distance the multiplier is likely somewhere in the range of 2.5:1 to 3.5:1. That is, if you were handicapping a runner/cyclist race, how long should the cycling race be so that the times are roughly equivalent?
Liked 3,081 Times
Grab a computer for the bicycle that supports having a power meter & start setting personal goals based on your age group of similar body composition.
To devote the time, effort, & money to do long rides means it leaves nothing for anything else. Taking care of/raising a family? nope. Full-time student/career? nope. Do normal activities with friends? lol wut..
If the only goal is to make cycling define your character, well then that is all the flavor you'll want to taste. I'd rather be a slow 2-wheeled turd that enjoys many aspects of life. No one but i cares about my cycling achievements.
-Oh Hey!
-Oh Hey!
Liked 2,097 Times
I am always astonished how accomplished and bright nearly all randonneurs are from my acquaintance, despite troll's opinion. A similar pattern can be seen with Ironmen. It is not hard to find 10-15 hours/week to train. I did back in the day travelling with a Bike Friday getting up at 4 am before heading to the work location. Many are able to be fit on far fewer hours.
Newbie racer
Liked 1,569 Times
Was that guy saing 3:1 ratio in time or in distance?
Issue is that 25w faster over two 5k runs per the runner power pace calculator is more time saved than 25w more over the 30k bike leg in a duathlon.
So:
300w run and 325w bike is slower in a 5k/30k/5k than a 325w run and 300w bike.
I made a little Excel sheet to prove it out.
Basically if you can run 5min miles you can really suck at the bike and win but the bike cannot use mammoth watts to makup the same time. Because the faster a cyclist goes the more power it takes and the less time they gain.
Pace power calc here: Couzens
https://alancouzens.com/blog/Run_Power.html
Liked 2,097 Times
Distance.
So:
So:
Lots of cyclists ride a 100 miles on both a Saturday and a Sunday. How many runners have ever run a Marathon two days in a row? OP's question does not have an easy answer and in my view, there isn't one if considering difficulty (stress on the body and mind). Cycling is way easier.
Perceptual Dullard
Quoted: 950 Post(s)
Liked 1,213 Times
[Edited to add:] Just to clarify, you're right that equal increases in power don't produce equal gains, but you can see that's because the actual relationship is nonlinear.
Likes For RChung:
Quoted: 1777 Post(s)
Liked 1,310 Times
In my club some of the younger (40 - 60 yr range) and stronger riders have targeted 20 mph in a 5-rider group for a relatively flat Century. I think it was 3 men and 2 women and they made it.
Bikes: Habanero Titanium Team Nuevo
Quoted: 401 Post(s)
Liked 187 Times
As a lifelong runner of 43 years and cyclist there is not way to really compare running and cycling. Running pounds your body and that takes a toll. Cycling does tax the heart and lung system and over time you can burn more calories or make some type of comparison in the amount of work, but running pounds the body. No cycling event I have done comes near a marathon at race pace. I can ride 100 miles for days in a row if I had to and keep eating and sleeping, but running 26 miles days in a row are not possible for most anyone. Even elite marathons cannot run 2 marathons on 2 days and still be fast. If they survived it would be at a huge price. I must say though that for me a very long climb will get my heart rate as high or higher than running.
I actually wish I could run more now but runner's dystonia is causing me problems. Cycling I am fine.
