Vintage handlebars - drops too short
I finished my winter project, a 1987 Trek Elance 400T, and have ridden it less than 20 miles so far. I kept it as original as possible (except the aero brake levers) and decided to keep the narrow, stock handlebars. So far it's not the narrow width of the bars that bothers me, it's the short drops. I ride mostly on the hoods but I use the drops a lot too.
My other two drop bar bikes have bars with longer drops, plus bar-end shifters so there's an extra inch. With these, there's nothing there and it seems short, feeling almost like my hands might slip off. I know they won't, but I just don't feel secure. I'm half thinking about putting a set of bar end shifter plugs in there and taping over them, just to provide a bit of a "knob" at the end. Is this unusual? Will I eventually get used to having such short drops? I really don't want to swap bars, more just for the hassle of retaping two layers. Any ideas?
Two words: Nitto Noodles.
Likes For rccardr:
SE Wis
Liked 3,653 Times
Likes For Chombi1:
Controltech Terminator MTB Bike Handlebar Bar End Extension Plug
Likes For Jeff Neese:
two wheels only
Jeff, I have experienced exactly the same issue on some handlebars and it seems to me more common on the "ergo" shaped bars. I have wondered if the "short drops" bars were made as a way for the handlebar manufacturers to shave some weight and thus appeal to the weight weenies and also use less tubing in the fabrication process, i.e. cut costs. My solution is to just change out the handlebars, As rccardr suggests, Nitto bars have a good extension on the drops and I have always liked the vintage Cinelli bars (models 64 and 66). You just have to be careful on matching the stem clamp diameter.
Likes For T.W.O.:
I've had a set of Noodles but I prefer the Nitto Randonneur, which I have on two bikes. If I swap handlebars on this thing it will be another set of Randonneurs, but I was really trying to use existing components. And now that it's taped, I really don't feel like changing the handlebars.
Edumacator
Liked 3,590 Times
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Liked 2,324 Times
Very nice-looking bike!
However, it looks too small a frame with the extended post and stem. Do you like the short reach?
I recently swapped bars from the Cinelli 64 to a more ergo style. I don't like the current set up and may return to the Cinelli.
Wrapping and unwrapping tape with Ergos is significant and is to be avoided. I reused my tape, and it looks bad which is motivation to change the tape and bars.
Bikes: 82 Medici, 85 Ironman, 2011 Richard Sachs
Liked 2,236 Times
The sooner you change those bars, the easier it will be to re-use the same bar tape. You will never be happy with those bars so get going on the switch.
Likes For Classtime:
Rotate the bars down like they were designed to be and you will have more of the "drop" part of the bar.
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
When in the drops, it really translates to in the hooks.
rotate them a bit.
check to make sure the stem is at least the minimum insertion line. Just looks marginal.
if for some reason no mark, 55-60 mm inside the steerer.
even better to make sure that the expander is below the threaded portion of the steerer.
rotate them a bit.
Klaatu..Verata..Necktie?
Liked 13,197 Times
Yeah. How's the reach to the brake levers when you're in the drops?
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Liked 757 Times
Hmm, ramps in same plane as stem extension, and drops pointed at rear axle; just how I was trained to install drop bars. Maybe there's a different rule for stepladder-height stems?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Straight from the catalog, almost pointed at the rear axle like you say, but much lower stem height. They could be tweaked a little bit up or down depending on rider preference from here.
2019 Salsa Warbird
2019 Salsa Warbird
Fine. I normally optimize brake position for riding on the ramps/hoods but when I'm in the drops I can grab a handful of brake if I need to.
Like anything, that's just a general rule, a starting point. Those bars were designed to have the flat part of the hooks parallel to the ground, more or less. But yeah, the stem height is exaggerating the "point at the rear axle" a lot.
Sunshine
Liked 8,063 Times
Shoota nailed it- rotate your bars downward. The brake levers are at a really high angle right now and also effectively high up on the bars. Those bars were not designed to have the ramps be flat, they were designed to have the ramps angle down at 12deg or so. Rotating the bars down will effectively push the drop ends towards you and give you more room on the drops. Also, your wrist angle wont be wonky when it the drops and reaching for the brake levers if you rotate the bars down.
Likes For mstateglfr:
Liked 1,285 Times
I hate to say it, but this is why I don't wrap bars until I've test ridden a few times to dial in the fit. Like shoota said above, though, you may have a noticeable difference by simply rotating the bars down slightly, and since this is the least invasive thing to do, it's worth a shot. The bar tops will be angled downward a bit more (you may or may not find that tolerable), but the drops will be a bit flatter and extend a bit further back. Again, worth a shot.
Likes For noobinsf:
Liked 3,312 Times
Centurion 1986
Liked 757 Times
Good point there (oops, a pun). Hmm, never having ridden on a bike with a stem remotely that high, on modern bikes with bars so much higher in relation to the saddle than I am used to, maybe using the ramps is not a common hand position anyway due to the rotation of the wrists needed?
Liked 1,078 Times
Really nice job on the build, love the tape job. I’ve got two 400s and put Nitto Noodles on both. If you go to the Nitto website, they make a lot of drops, and they also post the dimensions of each, including the drop. That might be a good place to start if replacing the bars, I would wince at undoing that tape job though.
Tim
Tim
If you set up bars/levers with the ramp in mind then you wind up with what the OP has. Nothing wrong with that per se, but it can create other issues, as we see here.
2019 Salsa Warbird
2019 Salsa Warbird
