Heart Rate Connection with GPS During Stops
Happy With My Bikes
Quoted: 887 Post(s)
Liked 2,358 Times
I currently use my Garmin Forerunner as a heart rate sensor by broadcasting it to my Garmin Edge. I'm thinking about getting a heart rate strap, not because I think I need it, I just want to. I want to join a ride next month with several rest stops. My Edge is set up to auto pause so obviously it will be paused during these stops. What I'm curious about is if heart rate sensor will pick back up if I stray too far away from the bike during the break and it drops the connection.
I know the few times my Forerunner dropped during a ride I had to stop broadcasting and then restart broadcasting to get the HR data back and I figure I can do that during this ride. But does anyone have experience with a HR strap and will it just seamlessly reconnect if this happens?
Quoted: 18883 Post(s)
Liked 10,646 Times
A chest strap is on when it's on your chest. The battery is good for a year or two of use, when you wear it it picks up the electrical activity of your heart, that's what wakes it up. I think the Garmin watches in broadcast HR mode work differently, where they'll automatically turn off after a while of not being connected to anything. To save battery. The Edges I've had always picked my chest straps back up when I left range and came back.
Likes For Seattle Forrest:
Happy With My Bikes
Quoted: 887 Post(s)
Liked 2,358 Times
Thanks. That was the only thing I was wondering about. I didn't want to only have HR data for only the first 15 miles or so. Not that I do anything with it, I just don't like missing data.
Likes For Chuck M:
Liked 10,646 Times
https://www.amazon.com/dp/B08JGPDWSQ...ing=UTF8&psc=1
This works with both of my Garmins (Edge 130 and Fenix 6x). Costs a lot less than the Garmin one. It's fun to spend money on bike toys, sometimes though you don't want to spend much on something you don't see a lot of value in.
Quoted: 4323 Post(s)
Liked 1,400 Times
If the watches (or anything) did this deliberately, you would not have to turn-off broadcasting (like the OP describes having to do).
There's an icon that is displayed when broadcasting. It would be bad if that icon is displayed when broadcasting is turned-off.
It's arguably a bad design to turn this off even with turning-off the icon because it's easy to forget to turn it on.
If it's using ANT+, I don't think it would work this way (ANT+ usually has no idea it's being received).
(I can't find anything that says the watches behave like this.)
Happy With My Bikes
Quoted: 887 Post(s)
Liked 2,358 Times
The lower cost of that strap is attractive as this isn't something I would use every ride. The toy I can't bring myself to spend money on though is a power meter. I've become interested in increasing my VO2 Max while running but Garmin requires a power meter to give this information for cycling. There is a Velocomp PowerPod which isn't near as expensive as but I don't know how it is supposed to work not measuring pedal force like a pedal or crank sensor would.
Likes For Chuck M:
Liked 1,400 Times
Likes For njkayaker:
Quoted: 237 Post(s)
Liked 199 Times
ANT+ is a broadcast protocol. The HRM - whether using your forerunner or a chest strap - broadcasts and the Edge listens for the broadcast data from the sensors it's been told to listen to (i.e. paired). So either your Forerunner is somehow stopping its broadcast or the Edge is somehow stopping listening. Kinda tough to discern which is the case. Either way this is a bug. I use my old fr235 with my edge 830 for HR and it remains rock solid even on 40mi rides with stops.
If you've not yet made sure everything's up to date on software and if you've not unpaired / re-paired the forerunner & edge, I'd do so first.
As for a different/new HRM - speaking from experience of many years running with chest straps... they can be a pain in the azz. especially in cooler months. You might wish to consider replacing the forerunner with a dedicated optical HRM armband. See https://www.dcrainmaker.com/2019/04/...tickr-fit.html for some ideas.
Edit - as for power meters. Consider the Stages or 4iii crankarm mounted options. I chose the 4iii Precision 3 and have been happy with it. Choosing one vs other largely came down to which was available preinstalled on the crank arm at the point I was ready to buy.
Liked 10,646 Times
ignominious poltroon
Quoted: 2305 Post(s)
Liked 3,543 Times
So to address this question, I did the following experiment:
Turned on heart rate broadcast on my Venu 2 and verified it was connected to my 530, and went for a ride. I arrived at my destination, and put the Garmin into sleep mode, which also turned off my radar. It did nothing to the watch, and I did not touch my watch. The watch continued to broadcast for the next hour and a half. Every so often, it would vibrate to remind me to turn off the heart rate broadcast, but I ignored that. After I finished what I was doing, I biked home. I had to turn the radar on manually when I woke up the Garmin 530. Theheart rate continued to broadcast and automatically rejoined. I did not have to do anything at all.
I assume this is the default setting, because I did not consciously change anything about heart rate broadcast mode (nor am I aware if this is even possible).
Likes For Polaris OBark:
Happy With My Bikes
Quoted: 887 Post(s)
Liked 2,358 Times
Thank you. Your experiment seems to suggest this will do exactly what I want. Especially since it seemed to work with you putting the Garmin asleep. I'm running a half tomorrow so Sunday I may just tool around the neighborhood to loosen my hips and try a similar experiment with my Forerunner which is quite a bit older than your Venu to see if I get the same result.
Likes For Chuck M:
Happy With My Bikes
Quoted: 887 Post(s)
Liked 2,358 Times
I honestly can't say I even understand what VO2 Max is. I run half two half marathons a year with a group that mentors teens. As I run at the pace of the teen I partner with, and generally cycle in the offseason, I don't even know if my running VO2 Max is accurate. But I noticed that as the girl I ran with this season started to run better, My VO2 Max improved. I just supposed that if I could measure it during cycling activities I could see how my cycling was doing rather than just estimating it by how I percieve it.
I created this app for just this reason. It is not as accurate but gives pretty good power meter like estimates.
Chuck
Likes For OshkoshBiker:
Quoted: 237 Post(s)
Liked 199 Times
If the OP is seeing different behavior, something is not working properly.
Likes For gpburdell:
Liked 3,543 Times
If you do not wish to spend a fortune on a power meter, please take a look at https://cykelstrom.com
Chuck
Chuck
Maybe version 2.0 will be for both Android and IOS, which will be some time from now.
Liked 10,646 Times
Liked 10,646 Times
Chuck
Chuck
If you would like to expand your audience. And probably do some heavy lifting. This would be useful to the OP and probably many others if it could send the power estimates to a Garmin as if it were a hardware meter. That would allow the Garmin head unit to estimate VO2, which is what he would like to achieve.
Contact me at developer@cykelstrom.com
Kind regards, Chuck
Happy With My Bikes
Quoted: 887 Post(s)
Liked 2,358 Times
Thank you. email sent.
