Poor shifting with 11 speed 105 setup
Quoted: 454 Post(s)
Liked 1,080 Times
On my road bike, I'm currently running 11 speed 105 5800 shifters, 5800 FD, R7000 50/34t crankset, R7000 RD with a 105 11-32t cassette. For some reason, I can't get the setup to shift smoothly throughout the entire 11 speed range. If I optimize shifting for the small cogs, the big cogs suffer and if I optimize for the big cogs, the small cogs suffer. I checked the derailleur hanger and it looks straight, also I recently just replaced the RD (it's brand new) with brand new shift cabling. Compared to my 10 speed gravel bike, that bike shifts perfectly throughout the entire range (with nice spacious gaps between cogs). The only difference I can see between the two bikes is that my gravel bike has a gentler shift cable line (less bend) to get to the RD. On my road bike, cabling routes towards the bottom bracket and is screwed in place through plastic inner cabling tubes before arriving to the RD. I'm wondering if that's a possible issue with too much bend or some other problem I haven't realized?
Any advice would be appreciated! Thanks!
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
You can't reliably eyeball a derailleur hanger. Take it in for an actual alignment; it only takes a few minutes and should be very inexpensive. If nothing else, it will rule that out as the cause of your shifting problems.
Likes For Rolla:
Guest
Liked 3,270 Times
Yes; being able to shift well on some cogs but not others often points to an alignment issue. Again, it's nice to rule it out so you aren't needlessly chasing other things, like cable tension. While you're at the shop, have them measure the teeth and the chain for wear. This is also easy to do and shouldn't take long. At my shop, we'd do it while you wait or within a couple of hours.
Quoted: 454 Post(s)
Liked 1,080 Times
Likes For jonathanf2:
Guest
Liked 3,270 Times
When I redid the RD cabling, I re-used the old inner plastic cable tubing for the internal routing. I was thinking of getting fresh tubing if that might cause some friction or other issues. I don't think it's the cassette teeth or chain either, both are new. If it is the derailleur hanger, do you think I'll need to order a new hanger? Thanks!
You can usually straighten a hanger if it's only slightly bent; we're talking millimeters, here. Should you need a new hanger, just be aware that there are dozens and dozens of them, and each is specific to the frame; you have to get the right one.
Quoted: 454 Post(s)
Liked 1,080 Times
It doesn't sound like a friction issue to me; that would affect shifting in every cog, not just some of them. But unless I have the bike in the stand in front of me, I can't diagnose this with any accuracy.
I run a 105 eleven speed on my gravel bike and I have two observations about shifting issues like this. The first is the derailleur spring seems a little weak and has been since new. The other is that the cable housing wear has an impact on shifting to higher gears. My housing sticks a little and combined with a weak spring to start with seems make shifting adjustments a bit touchy. Hope this helps.
Likes For OshkoshBiker:
Guest
Liked 3,270 Times
Carrying a spare hanger is always a good idea. I wish manufacturers would supply one with their bikes.
Likes For Rolla:
Quoted: 2376 Post(s)
Liked 2,904 Times
fwiw I run 105 5800 11 speed (and have used the same set on 2 bikes a de rosa and my current 85 Miyata team). The team was aligned when I had a shop spread it to 130
shifting has been pretty much flawless.
I have more issues setting up the front and did find i needed to have the front cable really tight for the FD and really get the front parallel with the rings.
IIRC I had to have a far amount of tension on the rear cable at smallest cog
I have to replace cables soon so will soon do this again
Likes For squirtdad:
Mother Nature's Son
Quoted: 860 Post(s)
Liked 1,455 Times
I have a 7000 group set and have the same experience with the RD cable needing to be really tight when the chain is on the smallest cog. I seem to remember having an issue getting the front to shift correctly, if might have been needing tightness on the cable, but not sure. This is with exposed cabling. I have had it for a good while and it has worked really well the whole time.
Likes For delbiker1:
Quoted: 7090 Post(s)
Liked 11,209 Times
Likes For Koyote:
Quoted: 454 Post(s)
Liked 1,080 Times
Good call. It might not be the hanger, but that's a pretty good place to start. If it's ruled out, they can then look at the cables, B-tension, chain wrap, chain length, etc. The alternative is for you to futz around with all that stuff and still not solve the problem if the hanger is off.
I called my LBS and they said they can look at it. If the hanger is just slightly off they have a tool that can align it properly. I also removed the hanger to visually inspect it. If it's bent then it's definitely not something you can eyeball. The LBS said it could also just be a cross chaining issue with my setup, but on my 10 speed it can shift smoothly across the entire range with perfect gaps for each gear. Also I feel fairly confident in my road bike B-tension and chain length since I also built and tuned my gravel bike which shifts fine.
I'll first do the replacement inner tubing first (which it needs anyways) and if that doesn't solve it, I'll bring it to the LBS and also order the spare hanger for insurance! Thanks for the responses!
Guest
Liked 3,270 Times
Best of luck, and let us know what happens!
Likes For Rolla:
Liked 2,904 Times
hard when it is a steel bike hanger part of the drop out forging..... would need to carry spare dropout and a mini oxy/gas set
Method to My Madness
Quoted: 2051 Post(s)
Liked 1,543 Times
Guest
Liked 3,270 Times
Yep, I've had many bikes with built-in hangers. They're actually more durable than the replaceable ones, but you're SOL if they get bent or broken on a ride.
Quoted: 1847 Post(s)
Liked 1,718 Times
Some do. Years ago I worked for a company which distributed Look frames. The frames were shipped with a spare derailleur hanger along with all the other hardware needed to build the bikes up
Likes For alcjphil:
Quoted: 454 Post(s)
Liked 1,080 Times
So the jumping when you get to a certain cog, this happens at a different cog depending on whether you optimize shifting for the big cogs or the small cogs, right? And does this jump happen only on a down shift, only on an up shift, or on both? When did this start happening? Have you previously run the same components without any shifting issues?
Also I'm wondering if the issue could be with my 105 5800 rear shifter?
Liked 1,543 Times
The RD-R7000 is Shimano's new(er) Shadow RD, which has a different profile than your RD-5800. Compare the respective locations and angles of the barrel adjusters in each rear derailleur. In the RD-5800, the barrel adjuster is located closer to the ground, and the shifter cable and housing enters the barrel adjuster at an angle roughly parallel to the ground. In the RD-R7000, barrel adjuster is located further to the ground, and the shifter cable and housing enters the barrel adjuster at a much steeper angle. If the shifter cable exits the frame at the junction of the right chain stay and right seat stay (like it does in my Cannondale Synapse), the housing forms a much, much tighter loop with a RD-R7000 than a RD-5800, which adversely impacts shifting. (That was why I had to return a RD-R8000 and search high and low for a RD-6800.)
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
Quoted: 454 Post(s)
Liked 1,080 Times
Ah, now I know why.
No, the problem is with your new RD-R7000.
Anyways I figure it's best I try an address the issue now since I do have another bike to fall back on. Also I won't know what the problem is until I bring it to the LBS, unless I do the tear down myself. I'm also probably going to order a new derailleur hanger just to be on the safe side. I'm not sure if I'll be able to find parts for this bike much longer, so it's probably best I just order a spare.
Liked 1,543 Times
I no longer use the 105 (CS-5800) 11-32 cassette which came with my road bike; you can have it if you want. I don't do as anywhere near as much climbing as the rest of you guys in the SoCal sub-forum. Although SoCal gas is so expensive nowadays that you can probably buy a 105 cassette with the roundtrip gas money.
Likes For SoSmellyAir:
Quoted: 454 Post(s)
Liked 1,080 Times
In that case, do you have another 11 speed cassette to try?
Quoted: 454 Post(s)
Liked 1,080 Times
The LBS called, they said the hanger was super bent! Wow, no way I would have noticed. Also they said my internal routing is a mess, so I'll just have them do everything in one go. They said everything should be 100% once they're done. Thanks for all the help everyone!
