Calibrating distance on computers - long measured courses - surveyors wheels?
Bikes: Surly Disk Trucker, 2014 w/Brooks Flyer Special saddle, Tubus racks - Duo front/Logo Evo rear, 2019 Dahon Mariner D8, Both bikes share Ortlieb Packer Plus series panniers, Garmin Edge 1000
Quoted: 405 Post(s)
Liked 115 Times
All,
I am curious how some of you are calibrating bike computers over longer measured course lengths - at least a mile if not 2-3+.
I have done the wheel count method over a measured distance. I want to say I used 200 feet, maybe 300 feet. On the 2 bikes I ride there is a slight variation in the distance over a routine ride I do. I find that a bit odd - if the wheel count method should be accurate then the numbers should line up closer than what they do.
That brings me to my question on calibrating over longer courses. Surveyors measuring wheels can keep track of distance while rolling, as opposed to stretching out a tape (even a long 100-300 foot reel tape) and resetting it. Plus - it would allow you to measure continuously however far you want to go. I think a lot of them max out at 9,999 feet. So you would be able to fit a mile in there at 5,280. Or, if you went further than 9,999 feet the counter would just start over. If you factor that in to the counter turning over - say the reading is 3,200. At 9,999 before that would be 13199 feet, or about 2.5 miles.
Just curious what others have done. My theory with the measured course is it would average out other inaccuracies that could be at play over a shorter distance - and that is what I believe the root of my mismatched distance readings is. They are close, but I notice they are different. I'd like to get them closer - and I don't know which one of the two is the most accurate.
Quoted: 3509 Post(s)
Liked 1,492 Times
Why? If you have less than a half percent error in your computer, does it matter?
If you were setting up a track for competition, use a surveyor tape measure with all the bells and whistles (temperature compensation, correct tension on tape, etc.).
When I measure the distance of one wheel revolution with a tape measure and come up with something like 85.25 inches, if I was off by a quarter of an inch (it was really 85.00 inches), my error is a hair less than 0.3 percent. Get a 25 or 50 foot tape measure and do three or six revolutions on the wheel to increase precision.
I think you are getting precision and accuracy a bit mixed.
Likes For Tourist in MSN:
Quoted: 4310 Post(s)
Liked 1,387 Times
All,
The very-involved approach might not be better than taking the average of multiple shorter runs.
Do you think you can ride a bike straight for 2.5 miles?
You see a "slight variation" but don't reveal the numbers. It sounds like one is always lower than the other. That would be a "difference", not "variation".
What are the two bikes? Is the difference always lower for one bike? If so, make you ride one bike straighter (faster)?
Note that this depends on load and tire pressure.
Use circumference numbers for each based on the average distances measured. That should get the numbers closer (if one is always less than the other).
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,328 Times
It seems people can get overly concerned with accuracy on these devices. Some rides I do with a gps watch and some rides with a computer with gps and wheel sensor. On the rides with the computer, I don't know how much of the calculated distance is done by gps data and how much by wheel revolutions. But I don't think I've noticed enough of a difference I would want to be worried about.
Off topic as far as wheel calibration but related to accuracy concerns is I also run with a group. For several seasons I was the one that went out on the path and marked our mileage and turn around points. Many would complain to me that the markers should have been this many or that many feet before or after where I marked them. Or they would tell me they only got 5.94 miles or went 6.03 for a six mile run according to their watch or phone app. Those without watches or smart phones just simply thanked me for my time I spent doing this for the group.
Quoted: 523 Post(s)
Liked 231 Times
If you live in an area laid out in a grid as many places outside of the eastern US you can check the accuracy of your computer by simply riding. In my area most streets were built so that the main avenues are a mile apart with a secondary road at the half mile point. I can choose to read the computer at the beginning of one road and go several miles to the same point at a road a couple miles away and then again read the computer. I'm pretty amazed at how accurate an inexpensive computer is if you set the wheel diameter correctly. The instruction sheet that comes with the computer is an estimate. If you want accurate readings do a runout on the wheel. Tie a narrow piece of string around the wheel, douse it with a colored liquid like India ink or food coloring and ride the bike a few feet on cement pavement. The distance between two lines on the pavement will be an accurate value to plug in the computer.
Quoted: 6330 Post(s)
Liked 4,923 Times
How many miles you rode really doesn't mean anything. The only thing that counts is who crosses the line first.
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 886 Post(s)
Liked 1,235 Times
Most really modern bike computers use GPS tracking to calculate distance, there is no calibration.
If you add a wheel sensor, some computers use the GPS to automatically set the wheel circumference to match the GPS for distance.
Then in areas of low/no GPS signal, the computer uses the wheel sensor for speed and distance.
As a bonus, the wheel sensor can also allow the computer to register when you start and stop more quickly than solely using GPS data.
Hope that helps
Barry
Hope that helps
Barry
Likes For Barry2:
Quoted: 2629 Post(s)
Liked 1,979 Times
Depending on where you live, the people who build and maintain the roads may have already done the surveying for you and marked them with mile markers. I like to do a roll-down test: I check my odometer reading at the mile marker near the top of the ridge and roll down two miles. If correction is needed, I can get within 0.5% this way.
Note this depends on where you live and ride. In some parts of the midwest, they seem to put up mile markers like some people put up bouquets of balloons to celebrate a child's birthday. (Maybe that explains some of the numbering there, too!)
Liked 1,492 Times
... If you want accurate readings do a runout on the wheel. Tie a narrow piece of string around the wheel, douse it with a colored liquid like India ink or food coloring and ride the bike a few feet on cement pavement. The distance between two lines on the pavement will be an accurate value to plug in the computer.
Quoted: 405 Post(s)
Liked 115 Times
The 2 computers are off about 7% between the two. One is higher than the other. The 7% difference is calculated from an average of many of the same rides. Each bike's ride individually is very close and repetitive (if I take the upper and lower distances of each bike I get about a 2% difference ride to ride span).
What I don't like about the "measuring the circumference of the wheel" method is this does not take in to account the compression of the tire when under load.
That is why I am trying to get an accurate course distance measurement. Then I can tune the calibration factor on the computer per bike so that the reading is repetitive and correlates to the measured course.
Liked 1,387 Times
I suspect a simple and proper rollout would be closer. Maybe, one if them is wasn't done well.
(But it might not matter too much.)
I suspect one of the bike's measurements isn't as good as it could be.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,328 Times
Just curious... Are these two identical computers on two different bikes or are you moving the unit from bike to bike? And if they are two separate computers, are they both using the same satellite system, GPS, GLONASS or Galileo?
Liked 1,492 Times
Some computers occasionally have a hiccup, I have a wireless VDO computer that at very slow speed, such as when I roll my bike outside my front door on my condo, I will get a measurable distance measured in several hundredths of a mile from moving my bike 20 feet. It has happened many times on the VDO wireless computer, but has never happened on my wired computer.
And the distance on my VDO computer is rarely repeatable within tenths of a percent where the wired computer is always spot on. The wired computer sensor sends a signal to the computer with every revolution, but the VDO wireless computer sensor sends a packet of information to the computer every several seconds, there can be several revolutions in that packet of information. And for some reason that I do not know, the precision on that wireless computer is not very good. I have had both computers for over a decade, the wired computer is consistently very precise, the wireless VDO is not. But I never care if my measured distance is off a few percent so I am not going to worry about this. If I cared that much about distance measurement, I have a separate GPS that I use sometimes, I don't call that a computer, I call it a GPS, it has no wheel sensor, I mostly use it for the map screen.
This might be a valid concern if you were riding a fat bike with only a few psi of pressure. Otherwise, this is not significant enough to matter, any error from that would be below 1 percent on most bike tires.
If you want to check this, ride a known repeatable distance, such as around a block with your tire at the max pressure on the tire label, then drop the pressure to the minimum pressure and ride the exact same route at the same speed to compare the difference. You will find minimal difference in the two distance measurements.
That said, I described above that my wireless VDO computer has poor precision, if I did that test at two different pressures, I would not trust my VDO computer to be precise enough.
Quoted: 3057 Post(s)
Liked 1,223 Times
Liked 4,923 Times
7% error is still meaningless. Did you know that that when your auto manufacturer puts a odometer/speedometer in the cars they sell that that they are only required to have that much accuracy.
What will being more accurate do for you?
Liked 1,979 Times
Of course that's going to vary with rider weight and tire pressure. I suspect it will take some trial and error to find what works best for you.
Quoted: 347 Post(s)
Liked 418 Times
Subtract 3% from the circumference of the computer on the bike with the longer distance, and add 4% to the circumference on the computer with the bike of the shorter distance. Now your devices are matched! Go live your live.
The distance you measure on a map isn’t as accurate as you think it is anyway, especially for longer distances, as it depends on the method chosen by the cartographer, slight elevation changes, and curvature of the Earth at your location (the Earth is not a perfect sphere, although often modelled as one for maps.) GPS is probably the most accurate you can do and I’ve seen some articles showing only small differences between phone apps, watches, bike computers, and handhelds.
Quoted: 18883 Post(s)
Liked 10,646 Times
Liked 1,492 Times
Speedometer, it is common knowledge that manufacturers usually show a faster speed than actual, I am not questioning that instrument.
Mark the position on the floor where the tape on the tire ends up after the two full revolutions. Measure the distance between the two marks on the floor, and get the effective tire circumference from that.
Repeat this a few times to see how much scatter there is in the measurement (in my experience, not much).
This is just how I do it. I have not compared weighted vs. unweighted to see if that would make a measurable difference.
Quoted: 405 Post(s)
Liked 115 Times
Lets cut through all the opinions and the "this way" and "that way" and simplify my question:
What is an accurate method to measure 1-3 miles for a course that I can repeat then tweak the computers reading?
Liked 4,923 Times
Well your surveyors wheel will be a good choice if you want to do it that way. However the rollout as others have described is the easiest most accurate that I've seen or have done. And you can easily determine the rolling circumference from the tire which is usually what you are suppose to enter in the calibration.
I'd still hesitate to compare the two devices though. Let us know what you get on each if you do decide to do a rollout.
