Bike shoe tongue rub
Bikes: Diamondback Haanjo Trail, Fuji Team Road
Quoted: 160 Post(s)
Liked 68 Times
I wear Sidi Megas on my gravel bike (which is now on a Wahoo Kickr). The Sidis have a stiff leather-ish tongue material and the top of the tongue rubs the top of my left foot over the ankle through the sock. Maybe IRL I move around enough that I don't notice it, but on the trainer it's very obvious. On a 10 miler, eh, not so bad. After a 35miler last weekend, I got a blister there.
My Shimanos on the road bike have a soft upper tongue material so no problem there.
Is there maybe a soft pad I could stick on the tongue that will provide comfort? I thought of wearing a bandaid on my foot over that spot, but I think that would bother me. And I'd rather not cut the tongue shorter because it might just start rubbing lower. Everything else about the shoes is fine.
Thanks
Paul
Thanks
Paul
Quoted: 1172 Post(s)
Liked 449 Times
pennpaul - the top strap on Sidi's can be offset a little by playing around with the plastic clicks where it inserts into the shoe. Maybe if that could be offset slightly the tongue pressure on your upper ankle would not be so bad. Also, can you just loosen the tongue ratcheting buckle a little?
Quoted: 1147 Post(s)
Liked 1,252 Times
Interesting. I've used Sidi Genius for over 10 years on my road bike. This year, I needed new MTB shoes so, having loved the Genius, I bought a new pair of Dominators in the same size. They have 2 boa-like closures, the top one with a strap. I also feel the edge of the tongue pressing into the front of my ankle. I never experienced this with the road shoes - they were super comfortable from day 1. I'm going to look closely and see if maybe I can work the stiffness out of the tongue.
As an aside, I don't think these Dominators fit me as well as the Genius of the same size do. They just seem a bit roomy. I thought maybe I'd been sent a pair of Mega accidentally, but both the shoe box and the shoes themselves indicate they're regular sizing. It could just be a roomier toe box which evidentially it has. I'm not nearly as happy with these as I am with the Genius. Don't really like Sidi's version of the boa closure either. Too fussy. I'll give them a few more weeks and see if I'm going to keep them.
Quoted: 515 Post(s)
Liked 655 Times
Quoted: 3323 Post(s)
Liked 2,164 Times
So what's the question ?, the Sidi's don't work, use the Shimano's.
Liked 2,164 Times
Good one. Had I stayed awake during Mrs. Phimsters 5th grade English class, I might actually know how to correctly use an apostrophe.
Gone Biking!
Bikes: Orbea Gain, Lynskey, Redline Conquest Disc, Bike Friday, Cannnondale T2 Tandem.
Quoted: 42 Post(s)
Liked 50 Times
Clip the tongue
After riding Sdis for years I just got a new pair of Megas. As usual it had an instructional paper in the box. I happened to actually look at it. It showed that the top of the tongue should be clipped with scissors along the serrated lines. I took my current Dominators and clipped every other line. What a difference it makes. Wish I had figured this out sooner. You might want to try clipping the tongue.
Likes For Pridedog:
Quoted: 1466 Post(s)
Liked 1,494 Times
Do your Sidi shoes have a tongue that has little slits in it like this?
If so, you should cut them so they look like this:
This seemed crazy to me at first, and I was hesitant to cut slits into my fancy new Italian shoes, but after talking to many other Sidi owners this is typical and completely solved my problem of the top of the tongue rubbing against my foot.
Likes For msu2001la:
So, I went through a similar situation with a pair of kicks that were rubbing the crap out of my pinky toe (I was doing a lot of HIIT training). I ended up buying 1” wide Velcro strips with adhesive backing, and used the soft side (loop part) and stuck it inside the shoe. Worked perfectly. The best part is you can “stack” the Velcro to your desired thickness for extra padding. =)
Quoted: 160 Post(s)
Liked 68 Times
Liked 1,252 Times
My new Dominator 10's don't have those slits that can be cut, but have wedge shaped cutouts in the tongue which are probably intended to do the same thing. I've only ridden them 3-4 times and I can see that the tongue is breaking down a little/softening to achieve the same purpose I'd wager. If not, I might work it a little or maybe even extend the cut outs. The only reason I'm thinking about this at all is that my old Genius 5's were dead comfortable from the get-go. These just don't feel as supple overall and especially in the top of the tongue.
I now see my old Genius have those slits - I wasn't aware of them and never had to cut them!
Quoted: 890 Post(s)
Liked 734 Times
Had similar issue with the tongues on my S-Works 7 shoes leading to heavy bruising. Read tips on another site to take a hair dryer (which I did) or heat gun (don't have one) to reshape them. Seems to have done the trick of permanently bending the tongues so they don't dig into my ankles.
Likes For surak:
Quoted: 373 Post(s)
Liked 437 Times
Wow, now I'll have to go home and look at my Sidi Genius Megas.
Like the OP, I've occasionally had some issues with the top of the tongue, but (a) I could usually solve it by loosening the ratchet and repositioning the tongue; and (b) since it is "leather" (of some type? I think?) once I got going it would soften up/absorb moisture so it was only a problem for a few minutes. I could see this being a problem for others, though (drier climate/not heavy sweaters/different socks/different anatomy/more sensitive skin/etc.).
The snipping does look like it would solve the issue, now I have another reason to look forward to going home after work.
