Off to a decent Dura Ace start...
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 210 Post(s)
Liked 175 Times
In addition to what's pictured, I've got a front DA hub and wheel on the wall, and a crank set on the way.
I'm closing in on a 7403 rear hub, but am totally stalled on new hoods and a seat post.
What's kind of funny is that I don't even have a frame to put it all on.
So...what early 90's frame might I seek that had a Dura Ace groupset on it as standard equipment?
PS: These brakes have to be one of the sweetest components I've ever seen!
Likes For 67tony:
Quoted: 1387 Post(s)
Liked 1,784 Times
Likes For randyjawa:
Quoted: 843 Post(s)
Liked 2,214 Times
Nice assemblage of DA parts. When capping off a DA 740X build, the post and stem are usually the most elusive bits to find since they are size-specific. Hopefully the frame you settle on will need a clamp-on FD, too.
Hard to go wrong with any top-end frame from that era. Even Euro frames from that era often had a Dura-Ace spec option. What frame is the right choice? Depends on your own fancy. I've never owned an Eddy Merckx and I recall seeing a lot of them equipped with DA back in the day, not only in the Motorola livery (which I would avoid on principle). That's one option, but any top-tier early 90s frame would wear that group well.
When I scored my grail '90 Merlin frame (something I always wanted when I couldn't afford it) a D-A group seemed a natural choice to adorn it.
Likes For gaucho777:
Quoted: 3631 Post(s)
Liked 3,054 Times
Usually lots of posts, not as many stems, on eBay. Pricey but definitely worth it.
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,125 Times
Hard to go wrong with a Klein! This one is mostly "catalog spec" as it came stock with Dura Ace - although most bikes from that era at that level seemed to be sold as a frameset only - and either the importer put together parts-kit packages, or maybe even it trickled down to the local dealer for final parts selection
Likes For DMC707:
Liked 3,054 Times
Schwinn Paramounts also ran Dura Ace.
If you want original, you can still get the proper cable adjusters for the brakes (those appear to be mountain bike-inspired 7700s), and the rubber tips for the center bolts.
Likes For smd4:
Quoted: 210 Post(s)
Liked 175 Times
Yes, sharp eyes indeed.
It also looks like I have a cracked lock washer, if that's the correct term.
Quoted: 210 Post(s)
Liked 175 Times
gaucho & DMC, those are really nice bikes, thanks for posting the pics.
Right now I can only dream of this level of quality, but, at least I have a goal in mind!
Quoted: 1635 Post(s)
Liked 1,839 Times
The 74** series had both single pivot and dual pivot brakes. I would go for the duals.
Likes For icemilkcoffee:
aka: Dr. Cannondale
Quoted: 2172 Post(s)
Liked 3,516 Times
Looks like tou’ve put some effort into obtaining and cleaning/polishing DA bits. Well done!
Yes, the correct brakes for an STI equipped DA bike would be 7403 dual pivots. Much better brakes.
Best way to get decent hoods is to buy a pair of blown up shifters with good hoods. Cheaper.
The scrape on your RD can be polished out carefully with 1000 grit paper or a small Dremel polishing wheel.
Liked 3,054 Times
The 7400 calipers were my dream brakes. The best I’d ever seen. But their performance compared to 600EX was marginal. I sold my DA Paramount in 1991. Got my Cinelli shortly thereafter. Then I got dual pivot Dura Ace brakes (7700). I finally got the braking experience I was expecting in 1986.
That being said...for some reason I still troll the Bay looking for 7400 brakes. Not sure why. The 7403 will be exceedingly nice.
Pedal to the medal
Team Miyata's from that era came with Dura Ace, at least they did in the late 80's. Great collect you have there.
Pedal to the medal
What principle drives you to avoid Motorola livery? Not trying to troll, I'm curious. I'm unaware of any controversy about it.
Quoted: 843 Post(s)
Liked 2,214 Times
@romperrr, I didn't mean to derail this thread and would prefer not to get into any charged LA discussions here. I actually like the colorway of the Motorola livery quite a bit, but that team and its leadership still leave a bad taste in my mouth. As someone once said, "It's not about the bike."
Thread derailleur
Bikes: Croll '94 & Cannondale Supersix '15
Quoted: 378 Post(s)
Liked 480 Times
Colnago Master Olympics came spec'd with Dura Ace. Here's mine. Still in near-mint condition.
Likes For roadcrankr:
Quoted: 179 Post(s)
Liked 252 Times
Bottom line is that the hoods you want, and that your bike deserves with such a clean group, are roughly $100 new on eBay.
The Simplicity of Vintage Cycles
aka: Dr. Cannondale
Liked 3,516 Times
They seem to come up in tranches....none for a long time and then a bunch in a row. You may also be right about pricing. There's pair of new hoods on eBay now at $109.
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
Liked 3,054 Times
The washer he has will still work...
Quoted: 604 Post(s)
Liked 1,064 Times
That group would look good on my 92 series 5 Paramount that I just got back from repaint, never did like the purple slime. However, I found a nos 1055 group that should work quite nicely, as that was what was what the bike came with originally.
Best of luck finding the hoods, but I think a Nitto S65 seatpost would look great with that group.
Tim
92 Panasonic Paramount
Tim
Liked 3,054 Times
Except for the unicrown fork, that Para is a gorgeous bike. Exquisite workmanship.
Likes For smd4:
Quoted: 604 Post(s)
Liked 1,064 Times
Actually, rereading your post, if it were me, I would try and find a early 90s Waterford Paramount frame for that Dura Ace group. Thats what I did for an early DA 7400 group, gave up on the seatpost, and went with some Campy dual pivot calipers I had, over the single pivot DA ones.
Tim
91 Waterford Paramount
Tim
Likes For tkamd73:
Liked 3,054 Times
Also...don't forget to try for the Dura Ace quill stem--probably the nicest quill stem ever produced.
I don't think even Campy can make this claim, but it's possible to have Dura Ace for nearly every single component--from seat post to stem to chain.
