Coasting down hill
Quoted: 2741 Post(s)
Liked 492 Times
Coasting down hill
Is putting out consistent power faster than attacking climbs and coasting down descents? Constant power and pedaling down hill are common tips for doing endurance rides. Personally I don't often pedal when im going ~26+ mph
Quoted: 9678 Post(s)
Liked 6,395 Times
If you wear a shirt and let it fly behind you like a cape, it will generate lift. The result will be less tire to road contact and reduced friction, enabling you to go faster downhill without pedaling. YMMV
Likes For Mojo31:
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Take up running; problem solved.
Likes For Bah Humbug:
Klaatu..Verata..Necktie?
Quoted: 10632 Post(s)
Liked 12,255 Times
I'm not sure how much more speed you can gain by pushing harder on the descents. Mostly, I spin up to 25 or so and then coast, on the straight ones. The technical ones, I'm braking WAY more than I'm pedaling. I think you'd lose more by going less hard up the hills than you'd gain pushing more on the descents. And, geez - you say you weigh 260. How much more speed do you need than what that gives you? You could probably get more speed by rebuilding your hubs with new grease and bearings.
Quoted: 18883 Post(s)
Liked 10,646 Times
Likes For Seattle Forrest:
Quoted: 890 Post(s)
Liked 736 Times
Depends on how hilly and long the ride is, and what type of physiology you have / want to train to have.
Mathematically it's faster to go harder uphill and into a headwind, go easier downhill and with a tailwind. However attacking and going over threshold takes longer to recover and eventually you'll blow. Some riders are much better at putting out bursts of power and recovering, others are diesels that can't go into the red much at all.
Likes For surak:
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Quoted: 6353 Post(s)
Liked 4,956 Times
If you are coasting at 26 mph, you might need a bigger chain ring or develop a faster cadence.
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
On anything more than a moderately steep descent, your pedaling effort will be wasted. This is because aerodynamic drag (and therefore power required to increase speed) goes up by the square of your speed increase.
Going up a hill, obviously you must pedal to keep moving. It's okay, because at speeds below 10 or 15 mph, air drag is by far the smallest component of the total formula you have to overcome to maintain or increase speed. In other words, your effort is not wasted, because increasing power by 20% will bring an increase in speed of nearly 20%
On flat ground, pedaling is again required, obviously. At speeds of 15 to 20 or 22 mph, air drag starts to take over as the major component. Within this range, any increase in speed will require a progressively greater effort--actually, this is always the case, but in this range it becomes a significant factor.
When you're coasting downhill at 25, 30, 35 mph or higher, you might as well rest and enjoy the free propulsion from gravity (technically, withdrawing potential energy you put in the bank while climbing earlier on your route, or if your descent is at the beginning of the route, going in debt by using energy you haven't banked yet). To increase your speed, you'll have to exert a disproportionately greater effort. Spending any energy here does little to increase speed, therefore it's better saved for a time when it will make a bigger difference.
Likes For Broctoon:
Liked 6,395 Times
Mother Nature's Son
Quoted: 865 Post(s)
Liked 1,462 Times
I am in the flatland of Delmarva. The only "hill" for many miles is the Indian River Inlet Bridge, guessing about 50 feet above sea level, each side is about 1/4 mile long. I believe the grade is about 4%. So, this likely does not relate a whole lot to the descents the OP has in mind. Anyway, it's about half and half in regards to getting as much speed as I can, or just coasting. I would have to go over and back on the bridge about 55 times to reach 1 mile of elevation gain. On days the wind is out of the north or south at a good clip, I like to go uphill into the wind riding hard, then coast the downhill, then do the reverse coming back across. I once hit 42 mph in the downwind, downhill 1/4 mile. Recent memory is more like 32 max.
Liked 12,255 Times
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
1. It's not just a physics problem, but a physiology one also.
2. In time trial, if you're not pedalling within 10% of your target power during the event there better be a sharp corner, insufficient gearing, or you've already passed the finish line.
If confused about #2, refer to the part after the "," in #1.
Likes For burnthesheep:
Quoted: 4605 Post(s)
Liked 5,146 Times
Likes For PeteHski:
Liked 10,646 Times
Last time I did a 20 minute MMP test, I was pretty done at 18 minutes, then the road went uphill at about 18:30 and my power went up with it. I don't know if hills just keep us honest, if the different position recruits more muscles, or if somebody shot me with a tranquilizer dart but filled it will speed instead. But I've heard a lot of people say hills draw more power out of them at the same feeling of effort.
Liked 492 Times
so ive heard stuff like this but it seems to contradict the idea that its more efficient to work hard when going slow because of drag. Ive also heard people talking almost derisively about riders going hard on hills and coasting on the decents, as if they are training ineffectively or are inexperienced. It also seems like people drop massive watt bombs on punchy climbs, but maybe people just like doing that? I dont really know what to think tbh
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Stupid question. If you can pedal you can go faster.
Likes For cxwrench:
Liked 12,255 Times
Likes For genejockey:
Liked 12,255 Times
(I confess, I do the latter for fun, where you turn off of Page Mill onto Arastradero right by 280. Charge up the hill like my life depends on it then gasp like a fish on a dock for the next 100 yards. Why? Why not?)
Advocatus Diaboli
Quoted: 4801 Post(s)
Liked 1,547 Times
It's kinda a fun question. Pretend you have a course that's 20 miles long. 5 miles of flat, 5 miles up a 5% gradient; turnaround and do the 5 miles back down and the final 5 miles on the flat. If you have eg. a 200 watt FTP.. do you go out at 200 watts, and gear appropriately to keep that all the way through the ride, or do something else, and what would it look like?
Should Be More Popular
Quoted: 22743 Post(s)
Liked 9,124 Times
Likes For datlas:
Quoted: 18583 Post(s)
Liked 16,057 Times
