Anyone have any ideas how to remove this freewheel?
I got this 5 speed wheels from a friend for free. I'm just curious if there's any way for you guys to identify what kind of freewheel is this and how to remove this. It got 20 splines and I have no tools for that. It's attached on a SR hub. My initial speculation is this is a 120 or 126 threaded hub given it's a 5 speed and it's quite old.
Here's the picture
Here's the picture
Quoted: 1088 Post(s)
Liked 1,207 Times
Park Tool remover with 20 splines: https://www.parktool.com/product/fre...26%20Freewheel
Likes For noobinsf:
Quoted: 941 Post(s)
Liked 1,359 Times
You need to clean all the crud out from the recessed circular part so that you can read the brand name and model. My guess is that it is either a Suntour Perfect (which may be labelled either "Suntour" or "Maeda") or a Shimano of some kind. Once you figure that out you will know which splined freewheel remover will fit. You will then need a vise of large crescent wrench to turn the remover with. Or, you can just go to the LBS or bike coop and I'm sure they will remove it for a nominal fee.
Actually @noobinsf is correct. See here: https://www.parktool.com/blog/repair...freewheel-type
Likes For davester:
My friend and I tried to go to a local shop but they don't have the tools either. We were planning to convert this one to single speed. I got this one for free so I would like to remove it with no cost but I guess it's impossible given that the tool the other person mentioned above is something I don't have.
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 275 Post(s)
Liked 419 Times
If you're happy destroying it, and don't want to buy any special tools, do this:
Insane Bicycle Mechanic
Quoted: 821 Post(s)
Liked 771 Times
Yes, many of the "Schwinn Approved" freewheels were made in France by Atom. The Park FR-4 tool looks better than the original Atom tool in that you don't need to remove the spacer on the axle. This was SOP back when I was working on Schwinns in the early '80's.
Jeff Wills
Jeff Wills
Quoted: 941 Post(s)
Liked 1,359 Times
Quoted: 275 Post(s)
Liked 419 Times
It's quite a lot of work converting because you probably should re-space the axle and re-dish the wheel to get a straight chainline
It's not quite as nice imo but a cassette wheel is much easier to convert because you can keep the dish and axle spacing the same and move the cog around with spacers to get your chainline.
Likes For Soody:
Likes For davester:
Liked 1,207 Times
Likes For noobinsf:
Freewheel Medic
Quoted: 1481 Post(s)
Liked 2,251 Times
Personally, and this is no surprise to anyone here on C&V, I hate to see a freewheel destroyed as Soody suggests. Since you are located in New Zealand, silferion , maybe we can connect you with a fellow C&Ver who has the appropriate removal tool. Also, your axle will need to be removed because the tool will not fit.
Bob
Bob
Likes For pastorbobnlnh:
Old fart
Quoted: 3618 Post(s)
Liked 3,457 Times
Likes For JohnDThompson:
Quoted: 732 Post(s)
Liked 696 Times
I have nothing against converting an old ten speed to a single speed if one gear is all you need. One big advantage for doing so is the bike will lose a pound or so in weight.
Go for it but get the right tools and do it with style, isn't that what single speed is all about?
feros ferio
Quoted: 1409 Post(s)
Liked 1,366 Times
Quoted: 3470 Post(s)
Liked 2,844 Times
Phil tool for Atom / Regina freewheels or remove the axle lock nut and some spacers and an old Atom remover with the axle sized bore. Service hub after freewheel removal.
Groupetto Dragon-Ass
Quoted: 417 Post(s)
Liked 797 Times
Did an Atom freewheel off a Campy hub yesterday. with the Park tool.
The drive side axle lock nut was too big to fit the tool in, but remove it and the axle spacers on that side slide out, leaving plenty of space for the tool.
What I used to do before I got the tool was pull out the 110v wire welder and put a spot on the outside where the face and gears move past each other, then use a chain whip or just grab the gear teeth in a vise and spin.
I got the tool to save Regina freewheels
Seems like the Maillard freewheel spines are a much larger diameter.
Likes For Chuckk:
I have the older version of THESE for THOSE -
But you do have to remove the locknut and spacer to use it.
As it turns out, I have a lot of vintage bicycle tools.
Liked 1,207 Times
Quoted: 1393 Post(s)
Liked 1,799 Times
I have several freewheel removers, collected over the years. The splined ones are great. The four tab ones are sort of OK but the two tab ones are not to my liking...
Likes For randyjawa:
