This should not be *this* hard
Bikes: yes, i have one
Quoted: 1152 Post(s)
Liked 1,194 Times
There are about 2 or 3 places that i can think of where i ride and it suddenly gets real hard. all involve climbing. one particular place is a little 1-2% grade that lasts for about a 150' about 6 miles into my morning commute. before that little climb i already climbed a bunch. another spot is maybe 2-3% for about a 1/4 mile where i have already done 5-6% climbs for way way longer. these little climbs just seem to get me and i don't really know why. i find it comical, have anything like that on your rides?
I am potato.
Quoted: 1818 Post(s)
Liked 1,689 Times
Hills make you stronger. Headwinds just make you mad.
Car dependency is a tax.
Likes For base2:
Quoted: 20810 Post(s)
Liked 9,456 Times
Off the top of my head, I can think of two little... I hesitate to call them "climbs," so we'll call them inclines... that look like they should be barely above the threshold of noticing, yet they're always more tiring than they should be, by all appearances. Kind of like false flats, but it's more like false gentle inclines.
Quoted: 18557 Post(s)
Liked 15,959 Times
I just got back from touring Vermont for a week, including some mileage on dirt. ‘Nuff said.
Likes For indyfabz:
Bikes: ...a few.
Quoted: 2014 Post(s)
Liked 410 Times
My commute home has three small climbs, like 5-6% and probably around 1/4 mile or less. All depends on how tired I am at the end of the day. Sometimes when feeling strong I'll attack it. Others when I've had a hard day at work it's like, ugh! Just get into the lowest gear, put my head down and spin it up.:/
Bikes: '23 Devinci Hatchet Carbon Apex1 '19 Norco Bigfoot 6.1 ,'12 Motobecane Turino (killed by dog crash), '12 Trek 3700 Disc
Quoted: 149 Post(s)
Liked 128 Times
I hate hills that start with inclines where I already lose any momentum I had before the actual climb starts. Even worse when there is a headwind (approaching 100% of the time) to make the incline speed drop more pronounced.
My area has lots of these. Incline - steep hill - slightly less steep top of the hill. Then you get to pedal down the other side of the hill because the headwind gets worse over the crest.
You'd think I hate cycling... but for some reason I keep doing it.
lol
lol
Klaatu..Verata..Necktie?
Quoted: 10576 Post(s)
Liked 12,182 Times
Quoted: 2611 Post(s)
Liked 3,143 Times
The annoyance of trying to keep riding at some arbitrarily chosen speed up hills and into the wind: that's why I stopped using a bike computer with a speed readout and started using only a pulsemeter. Maintaining a target pulse range keeps me from worrying about how fast I think I should be going.
Quoted: 1955 Post(s)
Liked 2,200 Times
The only thing I can relate to, is when I have a left shifter issue. More specifically a left hand/right brain problem where I don’t want to shift to a smaller chainring for a short section.
Sometimes it just doesn’t seem worth the effort to get to the best gearing only to go right back again.
John
John
How I cope with such routes that strangely, doesn't make sense? Slow down a bit but also hunch down in an aero position while you move forward on the saddle a little bit as well.
Likes For koala logs:
Quoted: 1005 Post(s)
Liked 1,684 Times
Yep... It is quite humbling when ya know you should be able to get over that hill easy peasy...
I spend more time in my 34T bail out gear then I would like to admit...Or over in Galveston Texas where you start your ride with the wind in your face, then when ya turn around to ride back,
Its in your face again... Rats!!!
Likes For zandoval:
Quoted: 833 Post(s)
Liked 1,976 Times
False flats like long 1-2% sections that suck the life out of my legs do it for me.
I do not monitor rise, so after I map the ride and see I was actually climbing it all makes perfect sense.
On the bike, I query whether I have a slow flat.
Quoted: 195 Post(s)
Liked 234 Times
Every road from my house has annoying hills within half a mile on the way back. Made me a stronger rider tho and I don't hate them nearly as much now. Goals of biking up sugarloaf mtn this year.
Likes For DonkeyShow:
Since it's a loop, I should try riding it in the opposite direction. But there's a much steeper climb going the other way!
Quoted: 1368 Post(s)
Liked 1,695 Times
My commute home was uphill over 9 miles. I don't know the grades, but two of the routes took me along old railroad lines and they were very subtle rises...practically unnoticeable. So when I would then encounter an additional slight increase in rise, it was really more than it seemed.
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 681 Post(s)
Liked 755 Times
Some years ago I lived in Prescott AZ in a hillside community, at the top of the steepest paved road in the city, a 300' climb at a 15% grade. Some cycling neighbors called it "Effing Hill," some saw it as a training opportunity. There were lots of climbs in the area, in the Bradshaw Mts, but most were the typical Western grades not exceeding 6%.
I liked the view there, but will never live at the top of such a hill ever again.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,099 Times
I think how I perceive the difficulty of a hill is very dependent on what I've been doing leading up to that hill. That 1-2% ascent might seem a lot bigger if I've been pushing myself harder while approaching it than I was leading to the 5-6% ascent. If I know the 5-6% ascent is coming, I've probably paced myself accordingly.
And wind, Some stretches always seem to be in a headwind.
There used to be a route near me called the Three Sisters, consisting of three short, but steep hills. The third one, about 1/4 as long and 1/4 as steep as the other 2, was always the hardest.....
My personal adage on this subject is that to climb well, first I must climb poorly. Well for me is feeling on top of the gear and my breath, then looking down and noticing I'm in a gear a cog or two higher.
Bikes: Diamondback Haanjo Trail, Fuji Team Road
Quoted: 160 Post(s)
Liked 68 Times
I nixxed a house on our search because all the roads leading up to it required some pretty steep climbs. I told my wife I couldn't imagine going out for a ride and then having to finish by climbing up to the house.
Quoted: 4227 Post(s)
Liked 2,491 Times
Quoted: 696 Post(s)
Liked 910 Times
Liked 15,959 Times
Liked 15,959 Times
