Chain lube
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
Chain lube
I'm looking for a oil based chain lube that's compatible with the preservative found on Shimano chain. I say preservative, since the lube found on new chain is really just a rust preventive. I'd like a "wet", oil based chain and not a "dry" lube or an emulsion.
I normally wipe down the chain anytime it's obviously dirty, After removing the dust, I apply lube and wipe off the excess. I'll do this monthly and replace the chain once or twice a year. I never soak the chain with cleaner, I prefer to maintain oil between the pin, bushing and side plates.
Any recommendations?
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Not sure what it means to be "compatible" with the stuff they put on new chains, but Muc-Off Wet Lube holds up well in most conditions.
Quoted: 910 Post(s)
Liked 288 Times
I'll give it a try. Some lube brands require that a new chain be cleaned to remove the factory preservative.
Guest
Liked 3,270 Times
Likes For Rolla:
Likes For KJ43:
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 340 Times
I like 3 lubes for the Chain...
Regular Triflow is a nice middle ground and can be lubing for all things needing lube.
Finish Line wet is heavier and last well in rainy environments but it will act like a heavy oil (dark stuff on your skin if you touch it)
Sometimes I clean with TriFlow and then wipe with a rag, then depending on conditions chose between TriFlow and FL Wet apply a light coat and wipe lightly off and good to go.
My favorite these days is Rock n Roll Gold though. Apply a generous amount to clean then wipe, then again to lube. It stays real clean and works awesome. That said the "lube" doesn't last quite as long. So reapplication is just a little bit more often, like once a month. But it is dirt simple and really keeps a clean chain.
I will use any of the 3 depending on what I have in the garage but RnR Gold is my favorite.
Quoted: 5234 Post(s)
Liked 3,609 Times
I've had bad luck w/ "wet" lube. a bit too gooey, for my taste
Guest
Liked 3,270 Times
I’ve always heard that wet lube is great for people who like to clean and lube their chain often, and dry/wax lube is for those who like to leave it alone for a couple of weeks.
Likes For Rolla:
Sunshine
Quoted: 11049 Post(s)
Liked 7,597 Times
Every podcast and industry article I've consumed about chains in the last couple years has said to remove the factory lube as it gunks quickly and is slow.
Wet lube attracts gunk, dry lube attracts less.
Nothing I have used is similar tonthe Shimano stock stuff.
Or get a chain that doesn't rust. Those advertised as "silver plated" tends to be quite resistant from rusting and then just use any lube you like. They are not really more expensive than regular ones. Quite happy using them because I didn't have to clean and re-lube the chain every time I get caught in rain.
Quoted: 2629 Post(s)
Liked 1,979 Times
I don't think I've ever run into a wet lube that's incompatible with the factory lube/preservative. It's only the high-zoot stuff racers need to minimize chain wattage losses that worry about that,.
Likes For pdlamb:
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
Ya, where is this coming from. It's the opposite... you wax often..... but lube less with oil based lube.
Show me something that says the stuff that comes on modern chains is just a preservative. Of course it's preservative, but it's also a lube.... like a lightweight grease.
Just use Chain-L or bar & chain oil for your "wet" ness lube.
Guest
Liked 3,270 Times
Depends on the conditions. Where it's dry and dusty, wet lube attracts and retains more dirt, requiring wiping down and reapplying more often. In a wet environment, dry lube doesn't last long at all.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
"I've always heard...."
Its in here somewhere if you really want to know. Convinced me to degrease every new chain I get.
https://cyclingtips.com/2022/03/nerd...or-your-needs/
Quoted: 427 Post(s)
Liked 340 Times
Quoted: 910 Post(s)
Liked 288 Times
About 5 minutes into the podcast, the speaker discribes factory lube as not bad, not great but explains that it's not compatible with many of the more exotic lubes, such as emulsions.
hello people: I've been using stuff called dry lube. It still attacks dry dirt and seems to build crud. I still use it as I have a new bottle but I want to try something else. Before this, I would use WD-40 and whip it down after application. I heard about the dry lube and gave it a shot.
IBBY
IBBY
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 276 Post(s)
Liked 246 Times
Personally, i prefer squirt. It works in any type of weather, does not mind wet condition (does not get washed off) and does not get very dusty in dry condition.
i tried mucoff wet lube and in winter it make a real mess. I tried mucoff dry lube and it seems to attract duct a lot.
reason I tied, muc off lube are 1/2 price of squirt.
