Brake Squeal with Paul low profile Canti and Kool-Stop Salmon?
Quoted: 1869 Post(s)
Liked 666 Times
Have this problem with wife's Terry, and she does not like it at all. What's the cause and what are the available fixes? I'm using a popsicle stick as a toe-in shim. Is that appropriate? Pads are on ball-swivel mounts.
Quoted: 4233 Post(s)
Liked 3,954 Times
Popsicle stick, sure why not. As good as another easy to handle item that's about the same thickness.
However there are other ways to try quieting a brake squeal. Toe out, grinding small ramps to the pad's rear facing edges, wiping garden dirt on the pads (my favorite partially because so many cringe at the thought of making a brake dirty as a good thing) and trying different pads.
BTW can you provide an image of these Phil brakes? Having followed Phil Wood products for decades this item is a new one to me. Perhaps you mean "Paul" brand? Andy
AndrewRStewart
AndrewRStewart
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Cleaning the braking surface with steel wool and rubbing alcohol can help, as can de-glazing the pads.
Likes For Rolla:
Liked 666 Times
Quoted: 4866 Post(s)
Liked 4,019 Times
Rats! You had me almost drooling. I don't know the popsicle trick but that is about the toe-in I shoot for.
OP, are you using Koolstop pads? If not, try them. Not magic but a very good compromise between squeal and stopping power. Most of my brakes (of at least 4 different types) are silent.
One trick to silencing squeal is to use it all up. Doesn't always work and will scare animals, irritate people and raise the dead in the process. Find a long steep hill. Go down; braking continuously at max volume. Often (but sadly not always) the squeal will be far more manageable afterwards. Andrew, I like the dirt trick. I have a rim that I contaminated the sidewall of mounting a sewup. Three rounds of lacquer thinner, Simple Green and a very good rinse haven't silenced it. (Rear. Grabs badly with oscillating noise to boot. The big downhill helped a lot but it's still a college football game; down from a rock concert.)
Quoted: 3622 Post(s)
Liked 3,046 Times
Likes For smd4:
Liked 666 Times
Liked 666 Times
Liked 666 Times
Thanks to 3-star Mod Stan Seven, my Phil/Paul faux pas has been corrected
Liked 666 Times
Liked 3,046 Times
Liked 4,019 Times
I just tried the dirt trick. Impressive. I don't know how long it will last but I'm pretty certain I'll be able to find more en route when I ride a century Sunday.
Likes For 79pmooney:
Guest
Liked 3,270 Times
Quoted: 457 Post(s)
Liked 112 Times
We use Kool Stop on all our bikes and here is the way I address the pads. 100 grit sand paper followed by rubbing alcohol.
Liked 666 Times
Because I have Kool-stops, toe-in, tight pivots (no apparent play) between my Pauls and the canti posts, not-loose tension bolts, and non-flexy calipers (Pauls), and I still have squeal which drives my wife to want to give up her bike, I think removing, cleaning, de-glazing, lubing, reassembling, and re-pitching and re-yawing the pads (experimenting with amounts of yaw) is plausibly what it needs. If it doesn't work I'm reluctant to pay another $30+ for a front set of Salmons, but it will be time for that. Remember, the front brake pads started their banshee scream with the preferred calipers and pads, and significant toe-in already in place. The hardest part of this is re-orienting her perspective. Before I start up that mountain I need to do the mechanical work, including the garden soil trick!
If any cantilever brakes are less prone to squeal by their inherent design, I'm curious. The levers are Campy Ergopower and they give a mechanical advantage and feel which works well for her as a cyclist, so anything new must work decently with Campagnolo levers. We're not letting this problem lead to a whole new drivetrain. I'm planning to change hers from 3 x 11 to 2 x 11 with a Campy 50/34, but that's the biggest drivetrain change I'd take on (then see if the triple lever works with the CT chainset).
As far as sandpaper choice, I have a box of scraps to look through. 100 grit is a good recommendation, though.
New but related question: Do disks squeal?
Liked 666 Times
Quoted: 996 Post(s)
Liked 591 Times
Brake squeal as I understand such things results from one or both brake arm assemblies resonating while under braking load. The objective is to change the system in some way to move the resonant frequency out of the range encountered in normal operation. One thing I've (apparently) had success with is using a thick (eg wheel-bearing) grease on the pivot bosses. If there has been enough wear to allow "rocking" movement of the brake arm, the grease may provide some damping. Might be worth a try.
(Greetings from Mundelein!)
aka: Dr. Cannondale
Quoted: 2170 Post(s)
Liked 3,505 Times
Another way to change the resonance is to use a different amount of toe-in on each side.
Likes For rccardr:
Guest
Liked 3,270 Times
Quoted: 243 Post(s)
Liked 234 Times
I have Paul Touring Canti with Koolstop Thinline pads. No squeal but it takes a good amount of toe. With the Thinline pads there is a little "kick-out" on the end that's about 1.5mm, and I have about .7mm of toe under the kickout. Also make sure the pad adjustment ball/cup that is closest to the pad is fully seated. I've had some of them not fully seat and leave a gap. Those would occasionally squeal, then then pad would suddenly be loose when the cup finally seated. Now I tap them in place with a drift and a hammer, and I haven't had that issue.
Kool Stop Dual Compound?
My single-point-of-data personal anecdote...
My 1995 Trek 730 Multitrack has its original Shimano Acera-X cantis and Matrix Journey wheels. When I was waking it up a couple of years ago after a long slumber, I installed Kool Stop "Eagle 2" salmon pads.
Stopping was fine, but they squealed something fierce. I fiddled with adjustments on occasion without success, and put up with it for several thousand miles. I mostly ride alone on fairly rural highways, and don't really need to brake very often, so net annoyance was low; it just wasn't a high priority.
I eventually tried some Kool Stop "Eagle 2" pads in the "dual compound" Black/Salmon, and that improved things dramatically on the noise front. I still get a little bit of squeal right when I'm coming to a stop. Stopping seems to be satisfactory, too, and maybe a bit easier to control.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,301 Times
I had this problem with mini-motos I had to change from Salmons to multi compound
Liked 666 Times
Source of the vibe seems (at least I like Jobst Brandt's argument) to be a surface wave on the rubbing surface of the brake pad. Toe in was (I think) intended to limit the vibrating surface. I don't know if there is play in my canti pivot bearings. Plan is to set the shoes square with the braking surfacs (machined) and send her out to try it. I did that work and I can't make it squeal, but she seems to have a knack for it. I think tomorrow I"m going to set up the toe-in, since I think I figured out a way to do it without a helper - use an old toe strap to force the calipers closed over the popsicle stick or other wedge, loosen the clamps, and force the brake lever with the toe strap, tighten the brake shoe clamp bolts, and release the toe strap. If its all still aligned correctly do the other brake and go out and ride. We'll see. If that doesn't work overhaul the calipers and measure the outer journal and inner and see if there is any play. I don't expect any, these have less than 2000 miles on them and I put Park grease in when I installed them.
I might also try several different gaps, or even asymmetrical gaps, as somebody else selected. But this begins to sound more like research than repair!
I think I've had that old toestrap in my toolbox since we rode around Evanston together!
Likes For Road Fan:
Quoted: 243 Post(s)
Liked 234 Times
If you can find an old Park BT-4 these work to hold the brakes shut.
I've used a Quick-Grip clamp to hold them shut as well.
But with the Paul cantis just loosen the mounting bolts and release the spring tension on the arms, then set the pads. With no spring tension it is easy to set the pads and lock them down. Once this is done reset the tension on the arms. It's super easy to do.
