Carbon Fitness bike
Bikes: Had an old Columbia in the 80's, here a used Schwinn hybrid, now a Cannondale Quick 3 and a Topstone 105..
Quoted: 249 Post(s)
Liked 306 Times
Carbon Fitness bike
I would like to know if anyone has firsthand knowledge of some good carbon Fitness brands are? I am thinking of moving to something with 105 mech, two gear crank, and an 11-gear cog set. Hydraulic brakes and able to run a 37 or 40 tire and a well-known brand to cover any warranty issues.
I found the Specialized Sirrus 6.0 so what else is there that I should consider? Thanks in advance.
Frank.
Frank.
ignominious poltroon
Quoted: 2280 Post(s)
Liked 3,503 Times
Trek FX Sport 6 or something like that (the highest priced one).
Likes For Polaris OBark:
Quoted: 102 Post(s)
Liked 55 Times
Besides Trek, there's Cube's SL Road SLT, We did have a look at the Sirrus 6, but for the price, the spec was very underwhelming, and the geometry was much more upright. But for those who care, it is 68mm BSA! haha
The new FXS6 fixed much of the older '21 model's issues, with proper internal cabling, wider tire clearance, rack mounts and even a kickstand option! However, with the 1x 40t crank, they changed it much into the gravel/trail side of things, at the expense of decent asphalt speed. That is very strange considering they fit aeolus aero wheels on them. But for the price, it's a better spec than Sirrus 6, with a lot of change to get a 2x11 system like the Ultegra 46/36 or GRX 46/30 like the Cube and switch out the RD/shifter to SRAM's GX, which has an alway on roller bearing clutch, instead of a silly switch on Shimano and the breadth to even go with 10-42.
Cube's SLT is also nicely specced, and better geared than Trek or Sirrus 6, with the 46/30t and 11-34 cassette. It also can take racks front and rear etc, and still have cash to upgrade. Granted Cube isn't as big as Specialized or Trek, but they make nifty bikes if the geometry works for you.
The geometry is probably the biggest factor in choosing your hybrid bike. More upright like the Sirrus, and a lesser extent FX 6, or a little lower and agile like the Cube.
Likes For Sardines:
Bikes: 2022 LiteSpeed CHEROHALA CITY, 2019 Canyon Roadlite 9.0 CF LTD, 2015 Giant FastRoad CoMax 1, 2001 Mongoose Pro Triomphe,
Quoted: 129 Post(s)
Liked 84 Times
Frank.
Frank.
Edit: Didn't see your request to go wide on the tires. Sorry the Canyon's only go to 32mm. However our Litespeed city bikes can go to much wider tires. You can see my post on them here: https://www.bikeforums.net/hybrid-bi...wneastter.html. They are great all around bikes. However a little more $$ for the frameset (handmade in the US). We love the 1X11 gearing btw.
Likes For DowneasTTer:
Quoted: 430 Post(s)
Liked 714 Times
A friend rides a Giant Fastroad & speaks very highly of it. Hers is aluminum, but Giant does make a carbon model also. Don't know what tire size it will accept. FastRoad Advanced 1 (2021) | Fitness bike | Giant Bicycles US (giant-bicycles.com)
Likes For freeranger:
Quoted: 1443 Post(s)
Liked 2,009 Times
apparently Cannondale no longer offers Quick carbon
Quoted: 249 Post(s)
Liked 306 Times
I saw this as it would have been my go-to. I have a Quick 3 2019 alloy and like it but I bought the wrong size and am now trying to correct that mistake. Size-wise mine is way too big and I have changed the stem as much as I can and also the handlebars. I need a correct-sized frame to work from and I figured at my age I might as well do it up right. Thus, the carbon search.
Be safe, Frank.
Be safe, Frank.
Liked 2,009 Times
Cannondale hybrid sizing is all over the place
frustrating
I was on the lookout for a Quick Carbon 1 - but found a Quick Disc 1
I've seen pictures and reviews of a Quick Carbon - but never saw one in person
frustrating
Quoted: 249 Post(s)
Liked 306 Times
Frank.
Quoted: 129 Post(s)
Liked 84 Times
Quoted: 249 Post(s)
Liked 306 Times
My wife and I had two FastRoad CoMax 1's, the carbon version, for several years. You can see our thread here: https://www.bikeforums.net/hybrid-bi...wneastter.html.. Great bikes for sure. But the same problem as many of the road based hybrids the tire size is maxed at about 32mm. Sold them to get the LiteSpeeds that allow for much wider tires. Currently running 30mm on them but plan to swap out for 40s or so for our gravel/dirt riding.
Thanks in advance, Frank.
Liked 2,009 Times
but still need to put more time on it to provide final verdict - spent more time on a CX1 recently (due to type of riding)
and still dialing in the fit - including stem/bar/grips and a few other items ; could get a better idea later this summer / early fall - have a few longer pavement type rides planned ; hands got a little sore on the one decent pavement/road ride I did so will be interested to see how I feel after different stem and bar
not sure if a flat bar will work for me on long rides - at this point I'm partial to drop bar because I've always been comfortable on the hoods
( bike like a Jamis Renegade S2 might be ideal ? )
Quoted: 249 Post(s)
Liked 306 Times
I like it a lot ; lightweight and versatile ; I've ridden it with 30 - 32 - and 35mm tires (appears 38's would fit and possibly 40's ?) and it has worked well on pavement (w/narrow tires) and on dirt roads and easy trails (w/ wider tires)
Thanks for this information. What 35mm tires did you try and how did you like them? I tried a set of WTB Riddlers like the set that came on a topstone I have. I like them but they wear out easily but are very comfortable. Looking for something that is a compromise between wide/narrow and comfortable/good wear.
Thanks for your response, Frank.
Liked 2,009 Times
currently have 35mm Gravelking SS installed - but only a few rides on them ... (they measure a bit over 36mm installed)
had 32mm Gravelking SS installed before this (they measured around 31mm installed) - they appeared to wear fairly well (?) but not many miles
plan to go with 32mm Conti GP4S for some longer road rides later this summer
( using 35mm Conti Terra Speed on a CX1 )
Quoted: 129 Post(s)
Liked 84 Times
I have never ridden a Ti bike. How does it compare to a carbon bike? One of the main reasons for moving from my aluminum bikes to carbon was to get a more compliant ride as I have a back issue that is getting more acute as I age. Also, how does the sizing run on the Lightspeed?
In Giant's I was riding Large frames, With the Canyon's it is Mediums with the Litespeed it's a M/L. There phone support is the best. Give them a call, doesn't cost a penny. They are very helpful both pre and post sale and offer a 30 day return similar to Canyon.
Quoted: 249 Post(s)
Liked 306 Times
These are the second TI bikes we own, The first are 20 year old hard tail mountain bikes purchased for our 30th anniversary. Still have and use once in a while. The Litespeeds are our of course new. Many feeling is the TI frameset on both sets of bikes are more comfortable to ride than any of the carbon based bikes we have used/owned. That incudes our Canyon RoadLites and all of the Giants we had. Plus the quality of the handmade USA frames of Litespeed, Lynskey, Seven and others is much better than those produced in the fast east (IMO). However, they are more $$.
Frank.
Quoted: 129 Post(s)
Liked 84 Times
I notice you live in NC. How far from 95? We will be traveling through sometime in Aug on our way home. We normally stay @ the Lumberton KOA for a night. If you would like to meet somewhere along the way (hopefully near a rail trail) you can try out one of the LiteSpeeds to see for yourself. I'm 6' 0" and ride the M/L and my wife is 5'6" and rides a small. Just a thought.
Quoted: 249 Post(s)
Liked 306 Times
Frank.
Quoted: 102 Post(s)
Liked 55 Times
Is there a particular reason why you want carbon? For the lightweight? Compliant ride quality? Bling? haha Cos good Ti bikes are great, and there are moderately priced options out there.
Likes For Sardines:
Quoted: 249 Post(s)
Liked 306 Times
Thank you all for your input as you have given me a lot to think about.
Frank.
Quoted: 102 Post(s)
Liked 55 Times
Well as I'm sure you know, compliance/ride feel is an acquired taste and also more importantly, a design issue. Carbon frames are naturally built with compliance and stiffness in different areas. Ti frames tend to be 400-700g heavier than carbon equivalents, but the compliance is much more in the design than just the material than many think. From the butting to the thickness of the tubes in different parts of the frame, and even how the cables fit.
My custom Ti commuter/tourer/fitness bike has carbon wheels, seat post, handlebar, stem and fork, running a pinion gearbox. With all that, it rides as well as any carbon/steel/aluminum bike that doesn't have suspension. So a combination of carbon and Ti is better than a full Ti bike. And truth be told, tire size makes a bigger difference than most people realize. It also has
The endurance bike is a good choice because the geometry fits the larger proportion of riders than race bikes. However, distance riding doesn't always equate to fitness. For my commute/fitness rides, I run shorter gearing and bigger tires for comfort on the way to work, and higher resistance for fitness on the way back from work, to work on VO2 max. This way I am more time efficient with fitness workouts. It all depends on how you want to go about it.
Likes For Sardines:
Quoted: 249 Post(s)
Liked 306 Times
Thanks, Frank.
Liked 2,009 Times
I believe I am trying to do the impossible in that I want a bike that I can go out and thrash myself on a hard ride or just jump on for a leisurely ride around the village. My area is nothing but hills, with some long and substantial, so no matter what kind of ride I want, unless I put the bike in the car and drive somewhere else, it's going to be a hill workout. I think what I am trying to build/have is only possible with two different bikes. I could certainly live with that but right now I am trying to just get one that fits my changing anatomy.
Thanks, Frank.
Thanks, Frank.
bike / type : hybrid or gravel or endurance bike ; should provide the ability to run the tire sizes you desire and provide the fit / position and versatility
(some other options might exist including rigid MTB etc - but would require some creativity and mech)
crank: 2x - 3x - 1x ? ; at least one option or possibly all three options can provide the gearing you desire when paired with the appropriate cogs / cassette
Your Quick and/or Topstone might be or might have been options - but apparently their size is an issue ?
Likes For t2p:
Liked 2,009 Times
Thank you in advance for your support lol
Likes For t2p:
Quoted: 102 Post(s)
Liked 55 Times
Well not necessarily. Getting a 2x11 or 12, with a 10-42, and a 46/36 Ultegra crank, or a Pinion P1.18 will give the range of gears to do all that. You just need the proper tires and wheels to do whichever you feel like. I do that with my Ti with the Pinion P1.18, which gives me over 600% range. So I just go 32t at the crank and 24t cog at the hub, and the wide range gives me road bike top speed and the climbing gears of a touring bike, and everything else in between. In short, put the right wheels and tires on, it can do many things, comfortably and on a flat bar too! I won't hit the same speeds as my carbon road bike, but the fitness aspect is about resistance so getting the heart rate up is the point. haha
Thanks, Frank.
Thanks, Frank.
Likes For Sardines:
