Frame Material
Bikes: Eddy Merckx Corsa Extra, Basso Loto, Pinarello Stelvio, Redline Cyclocross
Quoted: 336 Post(s)
Frame Material
I tried to keep up with all of the latest fads. I ended up with top end carbon bikes and to tell you the truth most of them rode like garbage. I am not a pro-racer and I'm not going fast enough to smooth the bumps out with speed. Then they started making carbon bikes for people who just tide. These carbon bikes are pretty light but to tell you the truth my bike and body weigh a little over 210 lbs. and changing this weight by a couple of percent as a normal sports rider doesn't make a detectable difference in climbing or riding on the flats.
So it began narrowing down to whether it was worthwhile to pay a small fortune to have a new or even newish bike.
I began riding more and more aluminum bikes and while they rode OK, I didn't like the cables ringing like a bell when they slapped against the headtube on the terrible roads around here. So now I will be turning back to steel bikes. Tomasso, Tomassini, Masi and other really nice bikes using modern groups and such can end up almost as light as a top end carbon racing bike,. Certainly as good as my Colnago C50 which I keep around for old times sake.
At 77 I neither climb fast enough nor have the guts to descend fast enough to make aerodynamic drag even worth mention. So shouldn't ai ride a nice comfortable bike that doesn't put my bank account in the red?
Quoted: 18548 Post(s)
Liked 15,919 Times
Why not?
Quoted: 1273 Post(s)
Liked 1,378 Times
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
To be perfectly honest with you neither frame material nor 'design' have really anything to do with ride quality. Unless you have some kind of mechanical pivot in the frame (Trek Domane) all frames are so close in ride quality you'd never be able to tell the difference in a blind test. Tire pressure is another story.
Likes For cxwrench:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
That's certainly an option that many have chosen. I think the whole frame material debate is much ado about nothing; just get whatever inspires you to ride.
Quoted: 833 Post(s)
Liked 1,976 Times
Ride what you believe in.
We all make a cognitive assent in what we ride.
Likes For CAT7RDR:
How dare you question whether you should buy a new bike? At the magnificent age of 77, you should definitely buy a new one, if for no other reason than to renew your passion for riding (and the accompanying desire to get your money's worth out of your new purchase). You're 77. You deserve a new bike. It's probably going to be your last bike (before buying your first recumbent, e-assisted trike). There really shouldn't be any discussion.
Edit:
Carbon is supposed to dampen the chatter vibrations, but like the other guy said, improvements in the ride begin with the tires. But why quibble? Get yourself a new steel bike, for goodness sake.
Edit:
People think I'm crazy but I can feel a difference on steel bikes. I feel like the aluminum bikes have high frequency vibrations that steel doesn't pass along. I have noticed it in my car too, going from the steel version to the newer all aluminum version of the car.
I have an aluminum bike on its way but with a steel fork. I'm curious to see how it feels. Its a touring frame so I'm hoping for more relaxed position and wider tires. I think it should be comfortable.
You should ride any bike you want to.
Likes For m.c.:
Likes For tornado60:
Quoted: 7094 Post(s)
Liked 11,213 Times
I doubt that anyone will tell you otherwise.
Quoted: 4227 Post(s)
Liked 2,491 Times
Ride whatever you want, no need to justify personal preferences for frame material.
Quoted: 457 Post(s)
Liked 487 Times
After riding nice carbon it's hard to ride anything else. Just feels like what little power I am putting out is being sapped by inefficiencies in the frame design/materials. I still have a 90s Ti bike that makes it off the rack occasionally, but if I'm honest I just enjoy looking at it and riding my carbon bikes. A good aluminum frame feels nice, too, almost like carbon. I've ridden some entry level steel (Reynolds 520, 631) but have been unimpressed. Maybe I will pick up a 853 to try, but my better half may object to me procuring yet another bike I don't need.
My first road bike was an aluminum for a year, then moved to a 86 Nishiki Tri-a and got a Centurion ProTour15 (steel) for commute.
Using wider tires for commute is great and super comfy, but somehow the ProTour15 fells a bit heavier (have fenders + rear rack).
Last year I got a TI bike, Litespeed Firenze with carbon forks. Really light but something was not there. Flex? And max tire was a 25c.
This year took the Nishiki to a bike shop to have the rear brake bridge moved some 5 mm up to be able to fit a wider comfy tire on it and added all the bosses for fenders and racks.
Got the paint stripped and powder coated. Now I can fit a 700x32c on it
Quoted: 2596 Post(s)
Liked 3,121 Times
Likes For Trakhak:
Quoted: 1789 Post(s)
Liked 1,317 Times
I don't know why you would expect anyone else to tell you what you SHOULD ride. I have 6 bikes and they have either steel, CF or AL frames. I enjoy each for what it is. FWIW I'm 76 and weigh 190 lbs. I'm still fairly strong but,like you, not a good climber. But when I climb I can certainly tell the difference between my 17 b 11 oz steel Guru Sidero and my CF 15 lb Guru Photon.
Likes For bruce19:
Then there's just something about aluminum I don't like.
Palmer
Quoted: 1701 Post(s)
Liked 1,877 Times
Likes For tcs:
Palmer
Liked 1,877 Times
Quoted: 3620 Post(s)
Liked 3,045 Times
But I do agree with your basic premise--the prevailing wisdom always has been that aluminum dampens road vibration.
Likes For smd4:
Quoted: 645 Post(s)
Liked 797 Times
Likes For Litespud:
unless they built an Al replica of your previously steel car, it’s likely that many other design and material factors are at work here. Anyway, no car is “all-aluminum” or “all-steel” - they’re a complex mix of metals, alloys, plastics, glass and rubber, all of which contribute to the feel. To say “I can feel the aluminum at work here” is delusional
Likes For Reflector Guy:
Liked 3,045 Times
climber has-been
Quoted: 3557 Post(s)
Liked 3,716 Times
Reality: Essentially all of the compliance comes from tires, saddles, and bar tape. In comparison to these bits, all frames are rigid.
