How much grease packing for cup & cone wheel hubs?
I just repacked the bearings with Shimano Spin Doctor grease. I put a fair amount in there to hold the bearings in place, and then a bit more on top of them before installing the cone. There's a bit more drag than I'd like spinning the wheel after assembly.
Is too much grease a self correcting issue? It seems any excess might just be forced down to the center of the axle, but I don't know for sure.
Quoted: 4862 Post(s)
Liked 4,011 Times
Is this a fair weather bike or will it see miles in the rain, etc? Yes, more grease does add a little drag on the bearings but enough grease so you get some squeezed out at the axle means you have a watertight seal as good as the grease you used. (Marine grease and you will probably be able to ride the hub a few inches under water. But do your bottom bracket and pedals too unless they have good seals because the will go deeper!)
I ride all my bikes in Pacific northwest weather. All get marine grease for the non-sealed bearings so I don't have to track which bike has what,
Likes For 79pmooney:
Quoted: 114 Post(s)
Liked 119 Times
I do what you did, and I like to see grease oozing out. You may feel a bit more drag when spun my your fingers, but as long as it spins smoothly (with no play), all is goo. Excess grease will work its way out, and better to have too much grease than too little, IMHO.
Quoted: 4233 Post(s)
Liked 3,950 Times
Any excess grease will be pushed aside by the action of the balls. Andy
AndrewRStewart
AndrewRStewart
Quoted: 859 Post(s)
Liked 1,098 Times
Agree with all of the above. Too much is better than too little and as mentioned any excess will just push its way past the seals. The bearing drag will go away after the first ride as bearings retain only what's necessary to keep them lubed properly and push away the rest. Excess grease that remains against the inside of the seals also helps a little to keep out moisture.
Likes For Crankycrank:
I am potato.
Quoted: 1810 Post(s)
Liked 1,678 Times
Car dependency is a tax.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,330 Times
I've seen very few things harmed by too much grease before. But none of them have been bikes.
Likes For Chuck M:
Too much grease isn't necessarily a bad thing, but it isn't good either, it presses out and makes a mess and attracts dirt and grit but that's about it. I finger-in just enough grease to fill the voids and then close it up.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3926 Post(s)
Liked 6,574 Times
Quoted: 514 Post(s)
Liked 652 Times
Depends on the hub. I have run this experiment with several different hubs. Lower quality hubs demonstrate this. With Campagnolo Record hubs, clamping the skewers does not change bearing adjustment at all.
I am potato.
Liked 1,678 Times
If the cones & the locknuts are properly bound against each other & the proper adjustment is achieved, why would the proper adjustment change when squeezed by a skewer? What then is the point of the locknut if not to bind against the cone to hold the adjustment?
Liked 4,011 Times
The force in a QR skewer is a lot. The skewer steel stretches. And, the axle steel compresses. Not as much; there is more steel in the axle than the skewer but it does compress. With a look at the skewer geometry and hand force to close the lever, calculating the stretch of the skewer and compression of the axle is a simple exercise in a junior year engineering class. So a bearing that was right on is now a little too tight. With good bearings you won't feel this in the ride but the races and cones notice.
señor miembro
Liked 6,574 Times
Likes For SurferRosa:
señor miembro
Liked 6,574 Times
It's one of those things of physics that I cannot easily explain, but it is something that I learned very early when I first started working on my own bikes.
Quoted: 1955 Post(s)
Liked 2,200 Times
But there will never be a consensus. For everyone who leaves no play and 30 years later the hubs are perfect, there will be someone who leaves a slight amount, that goes away when the QR is tightened, and 30 years later the hubs are perfect.
There was an endless thread a number of years ago that discussed the impact a QR skewer on a hub. It ranged all over the place and included axle material type and axle deflection. Personally, I think there are so many parts that make up a hub, especially threaded interfaces, and the QR just takes up all those minute tolerances. I mean we are probably talking thousandths of an inch difference.
John
Likes For 70sSanO:
Liked 4,011 Times
Yes, the final number is small. But what you feel at the rim is that number multiplied by 20.
Quoted: 514 Post(s)
Liked 652 Times
You're right. I did a bunch of tests with Campy Record hubs back in the day. Steel axles and zero compression. I just tried it with my current Record hubs and changing the force on the QR clamp changed the play in the hub. Sorry to quote old information.
Likes For KerryIrons:
