Is there a wrench for this?
Bikes: many
Quoted: 1461 Post(s)
Liked 1,418 Times
This pic is of the seatpost bolt nut on my Univega Super Speciale. I've never been really successful holding it in place while snugging up the bolt. I've tried screwdrivers, nickels, chainring bolt wrenches. Nothing seems to work well. Of course, my seatpost slipped while out in the "wilds" of Michigan just now (a bit south of South Haven). I've done what I can to tighten it up, but suspect it will slip again (yes, I have the proper size seatpost).
Is there a wrench for this beastie? If not, I think something like JB Weld will hold it in place. If I was going to get the frame painted, I'd probably just have it brazed in place.
Quoted: 1118 Post(s)
Liked 1,345 Times
That is an example of form over function (I am being charitable here).
Best replaced entirely, with something that will let you get a good grip on both ends.
You might find a bog-standard seatpost-bolt nut of the recessed variety will fit in the frame socket; if so file off the tang and cut it carefully to length, such that it bears on the internal flange of the frame-socket, not on the rim (leave a little gap there to allow for wear).
Quoted: 604 Post(s)
Liked 1,064 Times
Can’t you just get a new binder bolt, pretty cheap for cr-mo one on Amazon, or you could break the bank and get a Campy, either would look way better, and stop your seat post from slipping. If that were my bike, just the look of that thing, as it is, would drive me nuts.
Tim
Tim
Likes For stardognine:
almost looks like the back part of a chainring bolt, maybe try a chainring wrench
Semper fi
Semper fi
Likes For sloar:
Quoted: 1840 Post(s)
Liked 3,449 Times
The suggestions to replace the bolt and nut with something more user friendly seem like a good idea too.
I'm really just here to suggest bearing retainer compound instead of JB Weld (even though I'm about to use JB Weld for a small job myself).
I suspect bearing retainer compound might provide enough grip to do the job while still permitting removal of the nut in the future.
Something like this perhaps?
It might be worth perusing the websites for the companies making threadlocking compounds, bearing retainer compounds, etc. They sometimes have charts or tools to identify the best product for a particular task.
Steve in Peoria
USAF Veteran
That "nut" is toast. I would replace with the double allen like above. If you're adamant about getting a matching replacement (assuming it's original) Ace hardware (if local) may have it. Grainger's, McMasters and other online sources certainly will have it. It's just a round slotted nut.
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
I just remembered something, some bolt heads have a weird little tang, that sits in a notch, which keeps it from spinning. See if flipping it around might reveal that to you. 🤔
Bikes: many
Liked 1,418 Times
Thanks for the suggestions, even the more expensive monetary one. A nickel was the largest coin I had in my pocket at the time.
I was literally on my ride when I wrote (still am, at a coffee stop in South Haven), so hopefully you'll understand that details were kept to a minimum. The bolt and nut are meant for the seatpost binder. I doubt a Campy style binder bolt will work (though I have a couple to try back at home). The bolt itself is your normal diameter thing, while the Campy thing is much larger diameter. Frame surgery not gonna happen.
While I ride back to the beach house I'll leave you with a puzzle too solve. I think I know why it happened, but you get to speculate wildly. I test rode the bike before coming up. Everything was fine. When I set out on my ride this morning I heard this horrible grinding from down by the bottom bracket. "Oh no, that doesn't sound good at all!" I stopped and investigated a little. If I turned the crank, it made the sound once per cycle, no matter if I spun the crank forward or backward. I peeked they the bb shell window and was reminded that I have a Tange Seiki sealed bottom bracket, so that wasn't likely to be the cause. It took a minute to figure out what the problem was. The fix was pretty trivial.
So, two questions for the assembled experts. One, what was the problem? Two, what caused it? Hint: I use a Saris Bones rack. The first to answer both questions correctly will get a small bike-related gift in the mail.
Partially Sane.
Quoted: 972 Post(s)
Liked 643 Times
I dunno, I keep thinking it was your pants leg hitting something, but you were probably wearing shorts. 🤔
Quoted: 2367 Post(s)
Liked 1,759 Times
Strap from the Bones rack left hanging on the frame somewhere, hitting one of the crank arms as it goes by?
Quoted: 4264 Post(s)
Liked 2,980 Times
Is that just a stripped out allen bolt that someone cut a screwdriver slot into?
Edumacator
Quoted: 2525 Post(s)
Liked 3,321 Times
It probably has something to do with the secondary strappy thing that stabilizes back and forth I presume? YOu forgot to detach it and it stayed on the seat-tube where it interferes.
Or the strap moved the front derailleur enough the pedal hits it.
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Klaatu..Verata..Necktie?
Quoted: 10546 Post(s)
Liked 12,127 Times
Tim
Tim
blahblahblah chrome moly
Quoted: 1208 Post(s)
Liked 2,661 Times
I have some nuts that are a plain cylinder with M6 thread and a 6 mm allen socket. They came with Gipiemme brake bridges, for recessed brake mounting. Not the normal "top hat" shape of brake nut though, just the cylinder without the flange. Oh right, here's a picture:
They are somewhat precious to me but I will sell one for $10 shipped in the US, if that'll help you. It'll leave me with one brake bridge without a nut, but I'm unlikely to use that bridge anyway...
One disadvantage of this type is the bolt needs to be just the right length. Too long and it fills up the allen socket; too short and you don't have enough threads engaged. A stainless bolt can be trimmed to just the right length without the cut end rusting, if that matters to you.
Dimensions 10 mm diameter, 10 mm long, 6 mm length of threads. Chrome plated.
Mark B in Seattle
Quoted: 3619 Post(s)
Liked 3,044 Times
Liked 1,759 Times
There are different sizes of chainring NUT wrenches (you use an allen wrench on the bolt....), but I think they're still all too large for the OP's purpose.
Burning question - is there a notch in the hole on the NDS ear for a conventional binder nut with a tab to lock into? (Or on the DS ear, for that matter?)
Quoted: 4551 Post(s)
Liked 6,511 Times
https://www.acehardware.com/departme...E&gclsrc=aw.ds
Get one of these and grind down the sides to fit if necessary, short, stubby and stout
Clean up that slotted nut and do whatever it takes to keep it in use, no way I would replace it unless I absolutely had too.
Quoted: 1152 Post(s)
Liked 1,809 Times
Yeah I thought those nuts had a nub on the backside. It may be intended to fit on the Left side of the bike ('non-drive side" for those who have trouble with right-left)
Mark B in Seattle
Mark B in Seattle
