Grease or Oil on Freewheel Pawls?
In the past, any freewheels that I have cleaned up and greased with the Park Tool poly-urea grease on the bearings and the pawls have sounded like the grease was preventing the pawls from functioning properly and seemed sluggish with the ratcheting. After removing the grease from the pawls and applying a bit of sewing machine oil they sounded right to me. I'm hoping the expert freewheel doctors on this site will comment on this. I'm fiddling around with an old Atom freewheel now and want to get it right.
Thanks all for the comments and suggestions! Now if I can get the pawls in right and the freewheel assembled, lots of fun!
I am potato.
Quoted: 1816 Post(s)
Liked 1,685 Times
As a quick-n-dirty hack: Lay the bike on it's side, give the wheel a good run & dribble Phil's Tenacious Oil into the gap between the rotating & stationary pieces. Centrifugal (centripetal) force pull the oil into the pawl area. When the sound changes, you'll know you have enough.
Car dependency is a tax.
Quoted: 817 Post(s)
Liked 1,042 Times
Good question and I'll jump in and provide an answer for what I follow:
Grease the bearings, oil the pawls
I will lightly apply a thin coat of grease to the ramps to provide some rust protection and soften the click the slightest bit.
The problem or potential problem with grease in the pawl area is that the oils dry out of it over time and then the pawls get sticky and don't engage. This would likely take years, but it can happen.
@pastorbobnlnh will provide a more professional answer.
Good for you for keeping an Atom freewheel going.
Likes For Velo Mule:
Quoted: 936 Post(s)
Liked 1,336 Times
This is a topic I've always wondered about. Grease for the bearings and oil for the pawls makes sense, whether it be for bicycle freewheels or sailboat winches (which are remarkably similar to freewheels). That said, I've always in the past done routine lubrication of freewheels by doing something similar to what base2 suggests above (i.e. lay the wheel on its side and dribble oil or Triflow or something similar into the gap while spinning the freewheel. I'd never thought through the process too much but it seemed to work. Is this the right way to go about freewheel maintenance (short of disassembly)?
Quoted: 30 Post(s)
Liked 28 Times
Back in the 1980s Wheelsmith advocated using light grease for the pawls. They sold a mechanism that threaded into the back of a freewheel (removed from the wheel) that had a grease nipple that allowed you to use a grease gun and pump grease into the free wheel without disassembling. Obviously you can't dribble grease in. The Wheelsmith mechanism and grease in the freewheel worked great. You pumped a bit extra through until the grease came out the other side clean, and you'd cleaned and lubed the freewheel. And the freewheel was wonderfully quiet.
I don't think that is recommended any more. The grease can dry out or if you go to a cold environment and the grease thickens and suddenly your freewheel free wheels in both directions. Been there, done that. The pawls never engage. Maybe you could find a light enough grease and keep it refreshed enough to avoid problems. But oil is a better way to go.
Quoted: 3832 Post(s)
Liked 6,871 Times
I defer to @pastorbobnlnh on all things involving freewheel lubrication.
Old fart
Quoted: 3617 Post(s)
Liked 3,452 Times
I still have the tool, but prefer oil these days.
Picture shows Phil grease in the tool:
Bikes: Numerous
Quoted: 1680 Post(s)
Liked 3,157 Times
I usually do the non-disassembly oil method mentioned above. When working on the 3 pawl Campy free hubs, I use grease to help the pawls stay in place when remounting the free hub, then I thin it with lube oil after everything back together. Never had a problem.
Quoted: 30 Post(s)
Liked 28 Times
IIRC, the tool was made by J.A. Stein. Phil Wood distributed them at the time, and made a point of the fact that a Phil grease tube would thread directly into the tool once you removed the Zerk fitting. I have one, and it works as you say. Phil grease is too thick, IMO. It doesn't need to be "cold" for it to prevent the pawls from engaging, just cooler than Southern California. I found a light lithium grease to work better (we had it in 55 gal. drums with a pump attached, at Trek, for lubing headset and bottom bracket bearings for the assembly line), but even that was a problem when the temperature gets below freezing.
Freewheel Medic
Quoted: 1468 Post(s)
Liked 2,236 Times
Thanks for the mentions Velo Mule and nlerner
My Four Cents of advice after servicing 1000s of freewheels:
1st cent) Synthetic grease in the bearing races (I prefer Super Lube). It is very temperature tolerant, plus water and salt resistant.
2nd cent) A few drops of high-quality machine oil on the pawl pivots, pawls, and wiped across the ratchet teeth.
3rd cent) Blue Loctite on the outer bearing race/retaining ring (hand tighten only)
4th cent) The Phil Oil/TriFlo/WD40/Soak-in-Solvent, flush and dribble method is only a stopgap, short-term freewheel service method. Oil will not remain in the races. It leaks out and coats the sprockets, allowing dirt and grit to stick, thus leading to premature wear of the sprockets.
Finally, my advice is to never use the grease injector tool which floods the interior with grease. A freewheel is a mechanical device and not a bearing.
Bob
Bob
Count Orlok Member
Which Super Lube do you use? They make many, many varieties.
Palmer
Quoted: 1702 Post(s)
Liked 1,882 Times
What does Sturmey-Archer use? NLGI #00 semi-fluid grease.
"Since
Freewheel Medic
Liked 2,236 Times
Bob
Bob
Quoted: 817 Post(s)
Liked 3,050 Times
Quoted: 4866 Post(s)
Liked 4,018 Times
I used to dissemble FWs, grease and oil but after several came apart and spewed bearings on the road I went to just oil as base2 suggests. And you know what? With my riding, the oiled FWs outlast the cogs easily and since FW cogs are about as easy to find as the hen's teeth at the farmers market, I call that good enough. I follow the old "rule" - oil from the outside; ie the dropout side until you see oil on the inside (between FW and hub if mounted). That should flush any dirt thrown up by the wheel out.
(And a minor editorial point - if you are wearing out oiled FW bearings, may I suggest maybe you should pedal more. Those bearings are only being used as you coast. My favorite bikes don't even have them. )
Liked 4,018 Times
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 340 Times
I do this...
I'm no expert either though. Pastor Bob is.
I was going to rebuild a freehub body for winter duty. In the past I've been "seat sacked" while pedaling because the pawls didn't engage in the cold. Not comfy down there when it happens. There is a primer or two on the internet how to lube pawls for winter duty, not that the OP is going to be doing any winter riding(?). One fellow even suggested kerosene as it is very light and leaves an oily finish. But yeah, as others have said here, a light oil for the pawls.
Liked 4,018 Times
I have that Finish Line wet lube and use it here. Just oiled two FWs I picked up before riding them yesterday.
Quoted: 1003 Post(s)
Liked 1,684 Times
Back in the day 70's... Oh Boy... Here it comes...
I was hanging out at the Liotto Bicycle Shop in Vicenza Italy. I was in the back with the guys trying to learn about bicycles. I always brought cigarettes and bourbon so I was always welcome. The Racers were coming back from thier AM training run preparing for the Bassano race. Of course there was a Karen complaining about his Freewheel slowing him down and he knew it because it was not making a loud clicking sound in the glide. All the guys in the back just squinted at this per-madonna and Gino nodded he would take care of it. He quickly removed the freewheel from the training bike and plunged it into a bucket of Kerosene working it back and fourth to get all the lubricant and grease out of it. He then plunged it into a bucket of very light oil possibly LSA gun oil. He remounted it on the training bike and placed it drive side down to drip dry. I questioned him, "No Grease?". He lowered his head, took a long puff off his cigarette, and quietly replied with shrugged shoulders, "They are racers."
Good or Bad I just can't help greasing the hell outta all the stuff I maintain...
Likes For zandoval:
