Questions about Bar End Shifters
OldSchool
I have a road bike with full Nuovo Record group, 7 speed with Sachs freewheel. Interested in moving from down tube shifters to bar end shifters. Since this is purely friction shifting, can I use vintage Suntour bar ends? And on the Suntour bar ends, must they be pure friction bar ends without ratcheting (clicking) or can I also use the kind that ratchets with clicking? Wasn't sure whether the ratcheting kind are only compatible with Suntour derailleurs. Trying to get up to speed on this. Never worked with bar ends before and, based on what I've read, I think I would prefer Suntour to Campy. Did Campy even make bar end shifters in the 6 or 7 speed era? Thanks for any information.
Quoted: 891 Post(s)
Liked 2,325 Times
I have Campagnolo bar end shifters on one of my classics and they work fine , they should handle a 7 speed FW although I haven't tried. The SunTour Power Shifter type bar ends with the ratcheting sound work well . My daughter has them on her bike and I believe a six speed FW with no problem. I prefer down tube shifting myself but as I said I have the bar ends on one bike because it came that way . It always takes me a few shifts for my muscle memory to quit reaching down to shift when I ride that bike.
Likes For Kabuki12:
Quoted: 1172 Post(s)
Liked 449 Times
The older style SunTour BarCons are friction only with micro clicks. I never had a set but anybody I knew that had them loved them. The “Accushift” generation ones have settings for indexing SunTour Accushift 6 or 7 speed compatible freewheels or cassettes. AFAIK this function can be defeated and the knob turned for friction only. I have a set of these I got from an eBay seller on the island of Cyprus - I had hope of setting up an indexed SunTour touring bike but never got around to it yet.
Quoted: 28 Post(s)
Liked 60 Times
Suntour bar-ends will work fine with vintage campy. The suntour micro-ratchet bar ends are a great design, the ratchets help counter-act the cable/spring tension of the rear derailleur so less friction is needed at the shifter to hold the RD in gear, makes for a lighter touch to the shifting and with consistent amount of tension to move the shifter up/down through the full range.
Campy did make vintage bar-end shifters in the pre-index shift era , similar primitive friction mechanism as their downtube shifters that never worked as well as other improved designs.
Likes For GrayJay:
ambulatory senior
Quoted: 1957 Post(s)
Liked 3,673 Times
Suntour barcons will work with pretty much anything up to and including 10 speed stuff. I use them everywhere. Having said that I have never used them with sram.
Quoted: 3261 Post(s)
Liked 2,577 Times
Since you might be asking in the future, the Shimano L600 Fingertips will go at least 8. I can't remember if I've tried them with a 9 speed setup.
Likes For seypat:
Quoted: 1652 Post(s)
Liked 852 Times
FYI,
Simplex also made a lot of bar end shifters. They even had a model that had retrofriction function....
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Likes For Chombi1:
Suntour Barcons are great. I like to set them as light as possible without ghost-shifting. The small locknuts that hold the lever tension are prone to wandering off, so it’s advisable to use blue Loctite on them.
Likes For due ruote:
Quoted: 2368 Post(s)
Liked 1,760 Times
Don't worry about compatibility with the ratcheting action of Suntour Power shifters. Not only should the chain, cogs and derailleur have enough tolerance to handle it, the ratcheting only works in the "pull" direction. So if you hit a click stop that's a little off, you can always push the shifter to make a micro-adjustment. It's a little hard to explain in words, but once you've used them, in both directions, the idea will.... er.... click.
Likes For madpogue:
Quoted: 1621 Post(s)
Liked 2,240 Times
Likes For SJX426:
OldSchool
Thank you to all who replied for all the beneficial information and pictures. Very helpful. Thanks again.
Should I assume their adjustment is just the torque applied to the pivot nut on the shift lever? Mine are a nice comfortable stiffness (for confidence reasons) but I wouldn't might lightening them a touch.
Likes For Einzelherz:
Quoted: 1118 Post(s)
Liked 1,345 Times
They fall out when someone tightens the screw on the the other side (to increase the friction) and fails to re-tighten the locknut.
Likes For oneclick:
feros ferio
Quoted: 1403 Post(s)
Liked 1,355 Times
First, note that some of the newer SunTour barcons do not have a true friction mode. This was a huge disappointment for me. My best shot is to reverse them, putting the "rear" shifter in its pseudo-friction mode and using it for the front derailleur.
I am a huge fan of the first-generation SunTour barcons.
I have been missing the external locknut on my Peugeot -- no problem whatsoever.
Likes For John E:
Quoted: 405 Post(s)
Liked 595 Times
Keep your down tube shifters in a safe place cos you might want to go back to them real soon. I've tried a variety of bar ends on a variety of bikes for a variety of purposes. I have never found a place that I kept them for more than a very short time. No more for me, thanks.
So plan ahead JIC you get the "that sux" feeling too
Extraordinary Magnitude
Quoted: 2610 Post(s)
Liked 1,718 Times
Commence to jigglin’ huh?!?!
Liked 1,718 Times
A lot of older shifters (specifically Suntour) had indexed shifting for the rear and ratcheting shifting for the front. Notice the Barcons I posted above- one says "Accushift," the other says "Power Shifter." Suntour called their ratcheting action "Power Shifters."
Liked 1,718 Times
Shimano had a patent on that type of indexing/friction switch- Suntour kept the switch, but had a "Light Indexing" setting- it just didn't click quite as robustly.
