Repair Stand help
Repair Stand help
I am wanting to do more of my own maintenance and repairs on my bikes. Looking for suggestions and a little guidance. I have a budget of 300.00.
BillMc
BillMc
Quoted: 2026 Post(s)
Liked 1,096 Times
Is that $300 just for the repair stand or is it to cover both the stand and required tools? If for the stand alone, the Park PCS 9 or PS 10 stands are very good and nicely within your budget.
Likes For HillRider:
BIllMc
Sr Member on Sr bikes
Do you have an Aldi grocery store near you? Check there. They’ve had them in the past (I wasn’t sure about it so I went and checked it out). I already have a Park stand, but sure enough they carried them. For less than $50 (US), they looked pretty sturdy and versatile too. Others in these forums were using them and gave good reports. Tried to search online but am seeing notes that they’re out of stock online, but are available in stores.
https://offers.kd2.org/en/us/aldi/peXXZ/
Dan
Dan
Quoted: 33 Post(s)
Liked 94 Times
I've been using a Feedback Sports Ultralight stand for a couple of years...works great. I picked mine up lightly used off ebay for @ $180 shipped.
Ultralight Bike Repair Stand | Feedback Sports
Likes For kwb377:
senior member
Just got this one from Park a couple months ago - have it mounted on a wooden beam in the garage - they also have a sister model that mounts to a work bench - happy with it so far .
PRS-4W-2 Deluxe Wall Mount Repair Stand | Park Tool
Quoted: 645 Post(s)
Liked 797 Times
Amazon has a bunch of stands from <$100, in clouding a number of Park stands in the $200s. Park stands are pretty much the standard. Consider also what kind of stand you want - the clamp style that, if you have a carbon bike, is pretty much limited to seatpost clamping, or the type that supports the bottom bracket and clamps the fork ends
Likes For Litespud:
Quoted: 6337 Post(s)
Liked 4,932 Times
Use the money to get a power meter or something useful while riding. Just continue to hang the bike from it's saddle nose or top tube off the corner of a table. <grin>
senior member
Many of our local bike shops have Park floor mounted repair stands but the guys do the nose hang anyway
Quoted: 3621 Post(s)
Liked 3,046 Times
Likes For smd4:
Bikes: Trek Domane SL5
Quoted: 25 Post(s)
Liked 41 Times
Dan
Dan
Likes For Fendertele:
Quoted: 2376 Post(s)
Liked 2,904 Times
A good repair stand is the best tool decision I have made over the years. Mine in an older park P....someting 10, it folds, is is super stable for any maintenance that you can do.
big fan of the park ones. buy once and user forever
Likes For squirtdad:
Quoted: 2596 Post(s)
Liked 3,129 Times
I used the original Park repair stand in the bike stores where I worked for decades. Very nice, but I'm just as happy with my Aldi stand. In fact, I slightly prefer the clamping mechanism on the latter. I haven't seen any of those stands in any of the three Aldi locations on my bike riding routes for a few months, but Amazon likely has equivalent stands available.
Tip for using the Aldi stand and equivalent light repair stands: don't spread the stabilizer legs more than about the circumference of a road bike wheel, or a bit less. That spread is sufficiently stable for most repair jobs, and spreading the legs wider just means you'd trip over them.
By the way, of interest for those questioning the methods used by nose hang/rope from ceiling mechanics: a number of the top bike repair shops in Europe are known to use the rope hang method. They use heavy-duty jigs for building frames but apparently never saw the need for super-heavy repair stands, maybe because 50-plus-pound balloon-tire bikes never caught on there.
Liked 13 Times
I purchased this off of Amazon. It costs $83 and I am very happy with it. I haven't seen the Aldi stands in the stores by me for quite sometime. I would have purchased that if it was available. Heard good things about the stand.
https://www.amazon.com/CXWXC-Mechani.../dp/B08KLDN46C
Mad bike riding scientist
Quoted: 6269 Post(s)
Liked 4,296 Times
Edit: the link above is incorrect. The link above is for the cheaper stand. The PCS-4-1 is the stand with the best clamp. It’s more expensive but worth the cost.
Stuart Black
Stuart Black
Likes For cyccommute:
Method to My Madness
Quoted: 2051 Post(s)
Liked 1,544 Times
The Park Tool stands have slightly better clamps, but the Feedback Sports stands are lighter and more portable.
Bikes: 1974 Masi GC, 1982 Trek 728 (aka 720), 1992 Trek Multitrack 750
Quoted: 123 Post(s)
Liked 225 Times
Good on you billmc40. Having even a cheapo bike stand, and the Park stands are several cuts above that, will change the drudgery of doing bike repairs into something that is just downright fun and oh so rewarding. It will change your life (your bicycle life anyways ).
Quoted: 123 Post(s)
Liked 225 Times
I purchased one of these from Home Depot last year. Has been more than adequate. 81 USD
https://www.homedepot.com/p/Bicycle-...1TDI/314111906
Quoted: 1955 Post(s)
Liked 2,200 Times
After a number of years I finally bought a work stand. There are a few aspects that I would consider; ease of use including clamping and stability/stoutness.
I do not have a Park stand but my impression is that it is a tough durable stand that is quite stable.
I bought a Feedback Sports stand and for me it works well. I don’t think it is a tough/stable as a Park stand, but it is light and easy to setup and clamp/unclamp. For higher torque work; i.e. bottom brackets I use a wheel on the ground to add stability.
Personally I’d stay away from cheap stands. If a stand is a pain to use, it won’t be used except when necessary.
For example, I don’t need a stand to lube a chain, but it sets up so quickly that there is little lost time and it does make it easier. And it makes it nice to do a once over on the bike without going through a production.
John
Edit added: Clamping a top tube is considered a no-no. But I do it all the time since I can lightly dial in the pressure with the clamp. If I had to remove the seatpost and use a dummy post everytime, I would prop the bike against something and not use the stand except when absolutely necessary.
John
Liked 4,296 Times
I’ve used the newer type of clamp shown in the link and can’t figure out how to make it ratchet like the old one. I usually end up unscrewing the clamp while holding the bike and there is a lot of unscrewing to do. Even more fiddly.
The Park clamp is just a lever that only needs a slight pull to fully release the bike and a slight push to securely clamp the bike.
Stuart Black
Stuart Black
Liked 4,296 Times
Stuart Black
Stuart Black
Liked 2,200 Times
Clamping the top tube with the clamp pressure set too high is a no-no. The beauty of the Park clamp is that it is very adjustable. I clamp the top tube of my tandem (carefully!) because clamping a seatpost on that bike makes the stand unstable. Everything else is clamp on the seatpost, however.
I am not as familiar with the Park stands. A neighbor had one with a lever (cam) clamp and that seemed like an easy way to destroy a frame tube. He rode mtb’s and always clamped on the seatpost.
I don’t think the folding Park stands use that clamp. The reasons I got the Ultralight stand were stand weight and the speed knob (?).
John
Quoted: 114 Post(s)
Liked 119 Times
Quoted: 645 Post(s)
Liked 797 Times
Thanks. That’s good to know.
John
John
Liked 4,296 Times
John
John
The Park cam clamp isn't ideal - mine offers three settings for three tube width ranges - fortunately two of the settings work OK for my oversize Ti tubing and my narrower steel tubing, respectively. This would be less than ideal with a CF frame, but it doesn't hurt the metal frames, apart from trashing one decal high on the seat tube
Stuart Black
Stuart Black
