Help finding a gravel frame
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Long story short…I infected a fellow Army officer with the gravel bug. He bought a “budget” bike a year ago, and he has been steadily logging the kms and incrementally upgrading things. It’s got GRX600 level components (FSA crank) on the drivetrain but low end cable operated FM disc brakes. He bought a set of take off wheels from me at the beginning of the summer…and now he’s searching for hydraulic levers to mate to a set of GRX400 FM calipers I’ve got on my bench that were never mounted to a build I was doing last year. Tonight we were talking about continuing to upgrade a frame that supposedly fits 42mm tires (it does with 2mm clearance at the chain stays, which makes me nervous), or buy a new frame and rebuild the bike on that frame, or buy a whole new bike. I told him a frame might be a better (most economical) option.
So, here we are. His budget is 1000€, give or take few ducats. I’m gonna start looking. But opinions/ideas are welcome. Current frame is Al. He’s not fixated on a material, per se, but I’ve told him it should at least clear a 47mm x 700c. 650b is not as important, but it could give future options. Send ideas, please.
Sunshine
Quoted: 11058 Post(s)
Liked 7,614 Times
https://www.ribblecycles.co.uk/ribbl...ku=BDCGRAORFRS
Price is right. 45mm clearance.
Quoted: 532 Post(s)
Liked 621 Times
The hub spacing is modern standard: 12x100 F, 12x142 R. Thru axles can be sourced if the current ones won't work (which I've advised him to replace anyhow due to a wonky design of the built in levers).
Come across a number of frames in the past, just have to remember them.
Start with the Nordest Albarda and Super Albarda. Steel; carbon fork separate on site.
A bit hefty frame weight for steel. Super Albarda is more the long mtb frame type. Both frames do 700x50.
Bike24 has an XL Veloheld Icon frameset in stock. [The small size there doesn't take the 700x50].
Alu with carbon fork: Finna Landscape in stock. 700x50.
Their 853 Explorer frameset is avail also in a couple sizes, but 700x48.
What's the general frame size of rider?
Likes For tangerineowl:
Quoted: 1447 Post(s)
Liked 2,034 Times
if your friend does not go the hydraulic disc brake route - a couple options :
TRP Spyre
TRP Hy/Rd
Spyre is a dual piston / rebuildable mechanic caliper that will work with majority of drop bar / short pull levers
Hy/Rd is a cable actuated hydraulic caliper
TRP Spyre
TRP Hy/Rd
Quoted: 532 Post(s)
Liked 621 Times
OM boy
Bikes: a bunch
Quoted: 547 Post(s)
Liked 698 Times
maybe check out the Yoeleo framesets ?
https://www.yoeleobike.com/collectio...-wheels-frames
topnotch specs, and will accommodate up to 700 x 53...
given the current strength of the USD vs Euro, price is a bit higher than your limit... but maybe sold cheaper on the continent...
Ride On
Yuri
Ride On
Yuri
Goldsprint in Germany has the steel frame+fork Pelago Stavanger frameset. 700x50 with those hub specs.
I guess that's more on the cruisy ride style frame.
One alternative frame type you could look into is a beachracer frameset. Alu frame with carbon fork.
These days they're marketing some of them as more beach+[local]gravel crossover bikes.
e.g. Wikkit frameset models; sold through BeachBastards shop in NL. No idea on pricing tho.
Would suit a 1x build. They easily clear a 29x2.2.
Note they have a long frame reach.
There's one outfit in NL that does a scandium/alu frame with that clearance, that can be done 2x or 1x, but it seems they only offer complete builds of it.
Here's that 2x scandium 29x2+ frameset in NL, incase they....er....win the lotto or something
https://www.klaassencycles.com/Razor-multipurpose
Quoted: 532 Post(s)
Liked 621 Times
There's a few secondhand alu frame beachracers on the NL and Belgium classifieds.
A number under a grand for a complete bike.
Could purchase a cheap complete, just for the frameset if you like.
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 276 Post(s)
Liked 246 Times
You could look at Planet X free ranger frame set. it is supposed to clear 48c with 700c
mine clears 52-584 barzo and 45-622 without mudguards
I cleared 50-584 and 42-622 with mud guards (I haven't tried 52-584 yet)
The Tempest (TI frame) is supposed to have the same clearances. Being Ti, is supposed to be more comfy and outside routing makes the assembly and maintenance much simpler.
They will have a steel frame set soon
Likes For Fentuz:
Quoted: 532 Post(s)
Liked 621 Times
Planet X is on the shortlist.
