Reflectors for toe clips
Unsurprisingly my MKS Sylvans came without extra plates/reflector holders that are shown on Zefal installation guide. Does anyone know what are these?
Liked 3,313 Times
What?
Likes For Oakman:
Whenever I encounter those, I take them off and throw them away, along with all the other reflectors.
Liked 5,404 Times
Sad that people object to reflectors so much. They really do seem to be some of the first things I notice bringing my attention to a bicycle and cyclist when I'm driving at night. And when those reflectors on the pedals are going up and down, it makes it very quickly apparent what I'm about to encounter.
Likes For Iride01:
I lost all my front lights on my bike once, also had no reflectors on the front. The lights/reflectors on the back still worked fine, however facing crazy drivers trying to beat their personal speed records on a dark twisty narrow rural road was not the most pleasant experience of my life.
Liked 3,313 Times
You don't need reflectors if you don't ride at night.
Liked 509 Times
Liked 4,188 Times
The usual issue with pedal reflectors and toe clips is that most current reflectors are rather cheap injected plastic and the bolt heads tend to compress into the plastic bodies (of the reflectors). Since so few riders do much follow up check over/fine tuning after the initial miles of any new item's use this results in loose reflectors. Adding the stress of the toe clips to the system just hastens the loosening (especially when the reflector is also made of plastic). My suggestion is to revisit the reflector/toe clip hardware soon after the install just to make sure all is tight.
I won't argue about using reflectors in any location. Do know that the cube cut style (which is pretty much any CPSC approved reflector) has a best angulation WRT the incoming light source. Just like the popular LED flashers the unit really works best when it is at 90* to that incoming light (or with flashers with the following driver's eyes). So while reflective stuff is good there's a range of (of attachment/aiming angle) actual effectiveness to consider. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Liked 3,480 Times
By now they might have discarded the last of them, but for a long while just about every bike shop had a bucket of these that they couldn't decide whether to save or not
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Did you know that it is actually illegal in Europe to ride a bike without reflectors at night? It is also illegal to sell complete bikes without reflectors where I live.
Droid on a mission
Liked 314 Times
No offence to US based cyclists, but your national cycling habits might not be always relevant for the rests of the world.
Likes For JoeTBM:
Same here in the U.S. Laws vary by state but many states even require both lights and reflectors when riding in low light conditions. Some of us don't ride at night so we take our reflectors off. Bike shops have to sell them with reflectors.
Liked 4,188 Times
It would be interesting to learn of this forum's member's stats WRT where they live. Each member can include their location, but the vast majority don't make this public, just like they use fake names Andy
AndrewRStewart
AndrewRStewart
Liked 3,480 Times
FWIW - in the USA it's a bit complicated. Federal rules apply to bikes as sold new, while state rules apply to the bike as used. So, while new bicycles must be sold with front, rear, wheel, and pedal reflectors, different rules apply once they leave the shop. In most states reflectors aren't needed except at night, and usually that requirement is only for front and rear reflectors. This dichotomy contributes to pedal reflectors being a poor stepchild, with nobody being very committed to them.
Also, as Andy mentioned, there's often a conflict when mounting toe clips, so even those retaining the rear facing pedal reflectors discard the front facing one. This isn't really an issue, because the shoe often blocks the sight line, and the risks of lack of visibility generally relate to approaches from the side, ie, a car coming from a side road. In these cases, reflectors become much less effective, approaching zero, since there are no headlights pointed in their direction.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
They are most certainly not useless. I take mine off because I don't ride at night, but if you've ever come up behind a bike at night with pedal reflectors, they're actually quite effective and a good supplement to lighting.
Likes For Jeff Neese:
