What folding bike size?
Bikes: Diamondback Haanjo Trail, Fuji Team Road
Quoted: 160 Post(s)
Liked 68 Times
I'm considering using mass transit for my commute and possibly incorporating a bike in the mix. I want to buy a used folding bike but have no idea what size I need or if those sizes translate from manufacturer to manufacturer.
I ride a 58cm road bike and am in "Clydesdale" territory.
Are they all fairly universal and you just get a tall stem and seat post? Are those little tires going to hold my 250lbs and bag?
Thanks
Paul
Thanks
Paul
Bikes: Origami Gazelle, Origami Crane 8, Origami Cricket 7
Quoted: 463 Post(s)
Liked 412 Times
Have to checked with the transit company to see what their requirements and limitations are? If not, start there.
Small wheels are stronger that large wheels, that is not your problem. You need to look for a bike with a higher rated weight capacity, this may be hard to determine on the second-hand market. Simply adding a longer seat post may help, but make sure that the seat post is also rated for your weight.
Paul Pinigis
Owner of Origami Bicycle Company
Paul Pinigis
Thanks
Paul
Thanks
Paul
Schwinnasaur
A few things you should know about folding bikes - Manufactures inflate their height capacity by just considering the height of the seat to the pedal. They do not consider your physical ability to ride with a handlebar lower than the seat. You usually have to ask for reach and handlebar height. 20 inch folders that accept 50 mm tires ride more comfortably in bad road conditions, but are larger when folded than 16 inch folders. This makes a big difference for multimodal commuting on buses and trains.20 inch folders usually fit fine in cars.
Likes For Schwinnsta:
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
It's possible to get 50mm tires for 16" bicycles. Just as with the 20" bicycles though, you need to use a rim diameter that the wider tire is available for. The 305 size apparently accepts the 16" tire that comes in 50mm.
Schwinnasaur
I know that, but the problem with is that they still don't ride well enough due to their smaller diameter. The last two times I made a trip over the handlebars was aboard my Brompton due to a pothole and a major obstacle that I thought I could ride over. The pothole was filled with water. It was raining. The obstacle incident was operator error. Also, you take harder jolts as your wheel diameter decreases. For me and my environment, urban bombs cape, 406x50 is the first size that works really well.
Palmer
Quoted: 1704 Post(s)
Liked 1,889 Times
Quoted: 463 Post(s)
Liked 412 Times
Paul Pinigis
Paul Pinigis
Likes For Pinigis:
iti biking
From the looks of things, the 6-speed Dahon HIT uses a freewheel hub 126mm wide. This will limit any opportunities later to upgrade it. The 9-speed Bull uses a cassette hub to a wider modern standard, meaning that it can be more easily maintained or upgraded. Combined with the fact that it comes with the rack and fenders to make it a useful form of transport rather than a toy or sporting goods, I would definitely chose the Bull over the HIT.
Likes For Ron Damon:
Part-time epistemologist
Thanks
Paul
Thanks
Paul
A narrative on bicycle driving.
Likes For invisiblehand:
