Cycling Computers & Aux Compatible Accessories
Liked 3,302 Times
Is there already a site with a simple comprehensive list that has which cycling computers are compatible with regarding accessories?
IE:
Cateye QWC
Garmin Edge 530
Garmin Edge 830
Garmin Edge 1030
Garmin Edge 130
Garmin Edge 130 Plus
Garmin 1030 Plus
Garmin Edge 1040 Solar
Hammerhead Karoo 2
Wahoo Elemnt Original Gen1
Wahoo Elemnt Bolt
Wahoo Elemnt Roam
Then a list of which one of the above is compatible with:
Varia (?)
Bontrager (?)
Lezyne (?)
If anything, a "popular" computer brand pick & there compatible "common" accessories might be just all that is needed.
I'll start the list:
This Link Could Be Beneficial.
https://www.thisisant.com/directory/
Wahoo Elemnt Bolt works with Garmin Varia Radar
Wahoo Elemnt Roam works with Garmin Varia Radar
IE:
Cateye QWC
Garmin Edge 530
Garmin Edge 830
Garmin Edge 1030
Garmin Edge 130
Garmin 1030 Plus
Hammerhead Karoo 2
Wahoo Elemnt Bolt
Wahoo Elemnt Roam
Varia (?)
Bontrager (?)
Lezyne (?)
-YMMV
-YMMV
What does it mean for a 530 (as an example) to be "compatible with" Lezyne? Aren't those other computers?
Liked 3,302 Times
I didn't assign a compatibility list to anything, just drafted brand names. The list would be easy to compile from actual users of the devices.
So those that have a computer working with a light or radar, that would be where the list starts to help others.
-YMMV
-YMMV
Liked 5,404 Times
It'd be a pain to keep up to date. But hey, if you are volunteering!
Likes For Iride01:
In the meantime, you can learn about all of those devices and more at DCRainmaker.com or by looking the computer up with its manufacturer, or on google.
Liked 3,302 Times
Knowing which device works Ant+ with another is the objective.
-YMMV
-YMMV
Liked 3,302 Times
I can't tell you if my Garmin 130 is compatible with "Bontrager (?)" unless you tell me what you're trying to find out. Do you want to know if you can put two computers on the same handlebar? Or are you worried a Bontrager saddle would prevent the computer from knowing your distance?
I'm actually surprised it's not something already documented.
-YMMV
-YMMV
Liked 3,302 Times
Liked 3,302 Times
I actually am hoping to use my hodgepodge setup for a few more months, but I wouldn't mind finding front & rear lights (rear with radar) that syncs with a modern Wahoo unit. A great bright (to see while riding) ANT+ support seems sketchy with wahoo computers, but I might not know where to look.
-YMMV
-YMMV
https://support.wahoofitness.com/hc/...EMNT-BOLT-ROAM
ELEMNT, BOLT, and ROAM can now pair with rear view radar systems (like the Garmin Varia) following the same pairing procedure as any other ANT+ sensor (instructions here).
Bad news!
Note: Other ANT+ enabled tail lights (without radar functions) like those from Bontrager are not supported.
Liked 3,302 Times
I'd really like to try the Bryton radar unit & find a bright front unit that pairs with the wahoo too. I might be wishful thinking..
-YMMV
-YMMV
Because of the uncertainty I would only buy it from a store with a generous return policy.
I'm in the market for a headlight myself. I'm looking at the Garmin one by default because I know it will work and I like the mount. But I feel like there's probably a better value.
Likes For Seattle Forrest:
I have a Garmin Edge 1040 and it pairs (obviously) just fine with the Varia RTL 515 I have. It also pairs and allows control of the Bontrager Ion 200 RT front light. When I turn on the Garmin it turns on the Varia and the Ion and away I go...
Now if I could just get it to pair and allow control over the GoPro that would be sweet..
Likes For raqball:
Liked 5,404 Times
If you already have the stuff and they communicate over ant+ then just see if you can pair them. If the device can handle that type of ant+ sensor then it'll pair. If not it won't pair.
If you don't have the stuff, then simply buy stuff that you already can determine that they'll work together. And that really isn't hard to do. Just read the description and specs.
If a sensor, device or other thing can communicate with Ant+ they'll be telling you that it does. Ant+, I believe, requires royalties for it's use, so they'd want you to know.
Liked 1,498 Times
Liked 3,302 Times
Haters are going to hate, complainers are no different. If we all catered to them, we might not be legally allowed to have & use a bicycle.
-YMMV
-YMMV
Likes For Troul:
Liked 1,498 Times
The marginal information (about uncommon uses) is work to collect and maintain.
It’s not worth doing (compared to other things people could do instead). That is, somebody who has the appropriate experience has to make a choice between serving a bigger audience and a smaller one for the time they have.
Not doing the not-so-worthwhile task isn’t “catering to complainers” since there’s nothing to complain about.
Anyway, you really have to figure out “what’s in it” for the mysterious people you want work from. That it might be useful to you is a weak motivation. (All that work isn’t that useful to you: it’s way too broad.)
Kind of sounds like you are complaining.
I thought this is the point to participate in this BF. For example; I have a ACME GPS Super bike computer and want to pair it to a Watch-all 2000 radar. Has anyone tried this combination as the documentation I have read does not indicate they are compatible? I emailed the manufactures and they refuse to respond.
What am I missing here?
Liked 3,302 Times
The information that most people need is readily available.
We got to install microwave ovens, custom kitchen deliveries.
We got to move these refrigerators, we got to move these color TVs.
How's that saying go about assuming?
-YMMV
-YMMV
Likes For Troul:
Liked 1,498 Times
The list would have to be updated. So, it's ongoing effort.
You don't know the definition of "complaint" (one is "the expression of dissatisfaction"). Asking for something is some form of expression of being dissatisfied with its absence. Obviously.
Liked 1,498 Times
The OP isn't asking about one compatibility. He's asking for all of them (most of which he wouldn't be interested in).
He should have done what you "did" here: asked a specific question.
Liked 5,404 Times
Just a simple statement that it'd be more work for someone to look up all that information and publish it someplace as well and keep it current for all things new. And besides, it's really an easy thing to find out yourself once you get out of the abstract world of wondering and start making decisions of what you might wish to use with each other.
Besides, I noticed that you haven't volunteered to make this list. If you lack a website to publish it, then just make a thread here and maybe it'll become a sticky.
Liked 3,302 Times
Certainly no hate in that reply you quoted and I fail to see any complaining in it either.
If someone has X & Y, & possibly a Z working together, that person would post a reply with such info [ie: Brands, models, series/submodels if applicable] & the original post reflects the info.
if a person is looking for the helpful information, they can ctrl find within this thread or scroll down the list.
this thread was that purpose, to assemble the information as its received.
The complaining, criticism without understanding the intent, & assumptions are uncalled for. If you don't have helpful information to contribute to this thread, your wasting your time more than anyone else in this thread.
-YMMV
-YMMV
