Headlight Attached to Computer Mount But It's Too Big
Hey guys,
I got one of these computer mount with the headlight attachment for my Victagen headlights. The headlight is too long and is sitting on the computer mount attachment, so I can't angle it low enough to the ground so I don't blind people. Do you guys know if there is a headlight attachment that offers more depth to provide more clearance for my headlight? I've attached two photos below for reference. Thank you!
Thread Killer
Quoted: 3213 Post(s)
Liked 1,752 Times
Search GoPro style mount extension….there are many.
Likes For chaadster:
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 276 Post(s)
Liked 461 Times
If you have a Garmin computer get theirs though it takes up handlebar space. There are others made of aluminum that are long enough for Garmin and other computers with room under for light mounts. These are also stiff enough not to vibrate. So the computer stays I focus. That’s my experience. I do like how the stem plate mount look.
Henderson, NV
Bikes: Trek Alpha 3700, GT STS DH, Raleigh Grand Prix, Fisher Montare, Fisher CR-7, Fisher Aquila, Diamondback Sorrento, The Bike Beat Revolution, KHS XC 504R
Quoted: 327 Post(s)
Liked 617 Times
Can you flip the mounting tab around. It looks like it will move the light forward.
Likes For Desert Ryder:
Quoted: 33 Post(s)
Liked 94 Times
If you angle that light down any further, you'll be illuminating the area directly in front of your wheel. The only thing that does is allow you a split second to try and identify an object before you hit it.
Bikes: 2023 S-Works Tarmac SL7 Dura-Ace Di2, 2022 Cervelo Caledonia-5 SRAM Rival etap AXS, 2019 Specialized Sirrus Elite Alloy, 1977 Schwinn Super LeTour 12.2, 85 Bianchi Limited Shimano New 600EX
Quoted: 25 Post(s)
Liked 50 Times
Have you tried flipping the mount upside down? Not sure if that would set your computer too low?
Likes For Bici Veloce:
Ideally, I'm looking for the headlight/gopro attachment that is a bit longer so it provides the clearance. Is there such a thing or are these adapters all the same size?
Quoted: 5234 Post(s)
Liked 3,609 Times
can't please all the ppl, all the time. meaning there will always be someone who doesn't like your light. you might also consider a DIY beam cutoff hood, to reduce the upward light scatter
Liked 3,089 Times
Remove the headlight attachment from the base mount. Remove the computer mount from bicycle, turn it upside down & install it on to bicycle. Then remove the base mount from computer mount & install it on the other side of the computer mount. Lastly, install the headlight attachment to the base mount. Adjust the headlight as needed.
-Oh Hey!
-Oh Hey!
